Manual Chapter : 250W AC power supply unit (PSU) LEDs
Applies To:
Show Versions Show Versions
F5OS-A
  • 1.5.0, 1.4.0, 1.3.2, 1.3.1, 1.3.0, 1.2.0, 1.1.1, 1.1.0, 1.0.1, 1.0.0
Manual Chapter
The LEDs located on 250W AC power supply units (PSUs) indicate PSU operating state.
Input LED
Output LED
Condition (PWR-0334-xx)
green solid
green solid
Normal operation
off
off
Fault: Input UV
off
amber/yellow solid
Not valid
green solid
amber/yellow solid
Warning: VSB OC
Fault: SC, OC, VOUT OV/UV
green solid
amber/yellow blinking
Warning: VOUT OC, VOUT OV/UV
Fault: VSB OC, VSB SC
green blinking
amber/yellow solid
Fault: Input OV
green blinking
Warning: Input OV, Input UV
green blinking
off
Not valid
green solid
green blinking
PS_ON_L is high
green solid
off
PS_KILL PSU not inserted
OV - Over Voltage; OTP - Over Temperature Protection; UV - Under Voltage; OC - Over Current; VSB - Standby Voltage
