Manual Chapter : About creating a bootable USB flash drive on an iSeries system
Applies To:
Show Versions Show Versions
BIG-IP APM
  • 16.0.0, 15.1.0, 15.0.1, 15.0.0, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
Manual Chapter
You can use
mkdisk
, which is included in the
F5®
software installation ISO image file, to create a bootable USB flash drive that contains an
F5
software ISO image. You can then use this bootable USB flash drive to install or upgrade a system when you either do not have the installation image on the storage drive, or when you cannot access the storage drive. Additionally, you can use the USB flash drive to recover the system.
