Manual Chapter : About replacing a drive in single-drive system
Applies To:
Show Versions Show Versions
BIG-IP APM
  • 16.0.0, 15.1.0, 15.0.1, 15.0.0, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
Manual Chapter
For iSeries platforms that include only one drive by default, the drive is located in drive bay 1, and you must install the replacement drive back into drive bay 1. You must also power down the system when replacing a drive as part of routine maintenance or in the event of a drive failure.
The replacement storage drive provided by
F5®
does not come with pre-installed software. You will need to create a bootable USB flash drive to install software onto the drive. Alternately, you can use a PXE server to install the software. For more information, see
support.f5.com/kb/en-us/solutions/public/13000/100/sol13117.html
