Manual Chapter : AC power supply LEDs
Applies To:
Show Versions Show Versions
BIG-IP APM
  • 16.0.0, 15.1.0, 15.0.1, 15.0.0, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
Manual Chapter
The LEDs located on the AC power supplies indicate the operating state of the power supplies
Input LED
Output LED
Condition
green solid
green solid
Normal operation
off
off
Fault: Input UV
off
amber solid
Not valid
green solid
amber solid
Warning: VSB OC
Fault: SC, OC, VOUT OV/UV
green solid
amber blinking
Warning: VOUT OC, VOUT OV/UV
Fault: VSB OC, VSB SC
green blinking
amber solid
Fault: Input OV
green blinking
amber blinking
Warning: Input OV, Input UV
green blinking
off
Not valid
green solid
green blinking
PS_ON_L is high
green solid
off
PS_KILL PSU not inserted
OV - Over Voltage; OTP - Over Temperature Protection; UV - Under Voltage; OC - Over Current; VSB - Standby Voltage
