Manual Chapter : Power specifications - i10000 (i10600/i10080) Series
Applies To:
Show Versions Show Versions
BIG-IP APM
  • 16.0.0, 15.1.0, 15.0.1, 15.0.0, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
Manual Chapter
This table lists power specifications for i10000 (i10600/i10080) Series platforms.
Item
Single power supply
Dual power supply
Idle power draw (AC power)
110VAC input: 290W
220VAC input: 285W
110VAC input: 300W
220VAC input: 295W
Idle power draw (DC
/HVDC
power)
48VDC input: 285W
240VDC input: 310W
380VDC input: 315W
48VDC input: 295W
240VDC input: 320W
380VDC input: 325W
Typical power draw (AC power; 50% load; temp 25°C)
110VAC input: 405W
220VAC input: 400W
110VAC input: 415W
220VAC input: 410W
Typical power draw (DC
/HVDC
48VDC input: 400W
240VDC input: 420W
380VDC input:425W
48VDC input: 405W
240VDC input: 430W
380VDC input: 430W
Maximum power draw (AC power)
110VAC input: 520W
240VAC input: 510W
110VAC input: 525W
240VAC input: 520W
Maximum power draw (DC
/HVDC
power)
48VDC input: 510W
240VDC input: 525W
380VDC input: 535W
48VDC input: 510W
240VDC input: 535W
380VDC input: 535W
Typical heat generated (AC power)
110VAC input: 1385 BTU/hour
220VAC input: 1365 BTU/hour
110VAC input: 1420 BTU/hour
220VAC input: 1400 BTU/hour
Typical heat generated (DC
/HVDC
power)
48VDC input: 1365 BTU/hour
240VDC input: 1435 BTU/hour
380VDC input: 1455 BTU/hour
48VDC input: 1745 BTU/hour
240VDC input: 1470 BTU/hour
380VDC input: 1470 BTU/hour
Maximum heat generated (AC power)
220VAC input: 1775 BTU/hour
220VAC input: 1795 BTU/hour
Maximum heat generated (DC
/HVDC
power)
48VDC input: 1385 BTU/hour
240VDC input: 1795 BTU/hour
380VDC input: 1830 BTU/hour
240VDC input: 1830 BTU/hour
Specifications are subject to change without notification.
