Manual Chapter : Power specifications - i11000 (i11600/i11800) Series
Applies To:
Show Versions Show Versions
BIG-IP APM
  • 16.0.0, 15.1.0, 15.0.1, 15.0.0, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
Manual Chapter
This table lists power specifications for i11000 (i11600/i11800) Series platforms.
Item
Single power supply
Dual power supply
Idle power draw (AC power)
110VAC input: 340W
220VAC input: 330W
110VAC input: 340W
220VAC input: 330W
Typical power draw (AC power; 50% load; temp 25°C)
110VAC input: 460W
220VAC input: 440W
110VAC input: 455W
220VAC input: 440W
Maximum power draw (AC power)
110VAC input: 575W
240VAC input: 550W
110VAC input: 570W
240VAC input: 550W
Typical heat generated (AC power)
110VAC input: 1570 BTU/hour
220VAC input: 1505 BTU/hour
110VAC input: 1555 BTU/hour
Maximum heat generated (AC power)
1965 BTU/hour
1945 BTU/hour
Specifications are subject to change without notification.
