Manual Chapter : Power specifications - i11000S (i11400-DS/i11600-DS/i11800-DS)
Applies To:
Show Versions Show Versions
BIG-IP APM
  • 15.1.0, 15.0.1, 15.0.0, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
Manual Chapter
This table lists power specifications for i11000S (i11400-DS/i11600-DS/i11800-DS) Series platforms.
Item
Single power supply
Dual power supply
Idle power draw (AC power)
110VAC input: 295W
220VAC input: 290W
110VAC input: 305W
220VAC input: 295W
Typical power draw (AC power; 50% load; temp 25°C)
110VAC input: 435W
220VAC input: 425W
110VAC input: 435W
220VAC input: 430W
Maximum power draw (AC power)
110VAC input: 575W
240VAC input: 560W
110VAC input: 565W
240VAC input: 560W
Typical heat generated (AC power)
110VAC input: 1485 BTU/hour
220VAC input: 1455 BTU/hour
220VAC input: 1470 BTU/hour
Maximum heat generated (AC power)
1965 BTU/hour
1930 BTU/hour
Specifications are subject to change without notification.
