Manual Chapter : Power specifications - i4000 (i4600/i4800) Series
Applies To:
Show Versions Show Versions
BIG-IP APM
  • 16.0.0, 15.1.0, 15.0.1, 15.0.0, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
Manual Chapter
This table lists power specifications for i4000 (i4600/i4800) Series platforms.
Item
Single power supply
Dual power supply
Idle power draw (AC power)
110VAC input: 95W
220VAC input: 90W
110VAC input: 95W
220VAC input: 95W
Typical power draw (AC power; 50% load; temp 25°C)
110VAC input: 130W
220VAC input: 125W
110VAC input: 130W
220VAC input: 130W
Typical power draw (DC power; 50% load; temp 25°C)
48VDC input: 135W
48VDC input: 145W
Maximum power draw (AC power)
110VAC input: 165W
220VAC input: 160W
110VAC input: 160W
220VAC input: 160W
Maximum power draw (DC power)
48VDC input: 165W
48VDC input: 180W
Typical heat generated (AC power)
110VAC input: 445 BTU/hour
220VAC input: 430 BTU/hour
220VAC input: 445 BTU/hour
Typical heat generated (DC power)
48VDC input: 465 BTU/hour
48VDC input: 495W
Maximum heat generated (AC power)
565 BTU/hour
550 BTU/hour
Maximum heat generated (DC power)
565 BTU/hour
615 BTU/hour
Specifications are subject to change without notification.
