Manual Chapter : Power specifications - i5000 (i5600/i5800) Series
Applies To:
Show Versions Show Versions
BIG-IP APM
  • 16.0.0, 15.1.0, 15.0.1, 15.0.0, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
Manual Chapter
This table lists power specifications for i5000 (i5600/i5800) Series platforms.
Item
Single power supply
Dual power supply
Idle power draw (AC power)
110VAC input: 195W
220VAC input: 190W
110VAC input: 205W
220VAC input: 205W
Idle power draw (DC power)
48VDC input: 195W
48VDC input: 205W
Typical power draw (AC power; 50% load; temp 25°C)
110VAC input: 265W
220VAC input: 260W
110VAC input: 265W
220VAC input: 265W
Typical power draw (DC power; 50% load; temp 25°C)
48VDC input: 260W
48VDC input: 265W
Maximum power draw (AC power)
110VAC input: 330W
220VAC input: 325W
110VAC input: 330W
220VAC input: 325W
Maximum power draw (DC power)
48VDC input: 320W
48VDC input: 320W
Typical heat generated (AC power)
110VAC input: 905 BTU/hour
220VAC input: 890 BTU/hour
220VAC input: 905 BTU/hour
Typical heat generated (DC power)
48VDC input: 890 BTU/hour
48VDC input: 905 BTU/hour
Maximum heat generated (AC power)
220VDC input: 1130 BTU/hour
Maximum heat generated (DC power)
48VDC input: 1095 BTU/hour
Specifications are subject to change without notification.
