Manual Chapter : Power specifications - i7000 (i7600/i7800) Series
Applies To:
Show Versions Show Versions
BIG-IP APM
  • 15.1.0, 15.0.1, 15.0.0, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
Manual Chapter
This table lists power specifications for i7000 (i7600/i7800) Series platforms.
Item
Single power supply
Dual power supply
Idle power draw (AC power)
110VAC input: 210W
220VAC input: 210W
110VAC input: 225W
220VAC input: 220W
Idle power draw (DC
/HVDC
power)
48VDC input: 205W
240VDC input: 250W
380VDC input: 255W
48VDC input: 215W
240VDC input: 260W
380VDC input: 260W
Typical power draw (AC power; 50% load; temp 25°C)
110VAC input: 300W
220VAC input: 295W
110VAC input: 310W
220VAC input: 305W
Typical power draw (DC
/HVDC
48VDC input: 290W
240VDC input: 340W
380VDC input: 240W
48VDC input: 300W
240VDC input: 350W
380VDC input: 250W
Maximum power draw (AC power)
110VAC input: 390W
240VAC input: 380W
110VAC input: 390W
240VAC input: 390W
Maximum power draw (DC
/HVDC
power)
48VDC input: 370W
240VDC input: 445W
380VDC input: 455W
48VDC input: 380W
240VDC input: 455W
380VDC input: 465W
Typical heat generated (AC power)
110VAC input: 1025 BTU/hour
220VAC input: 1010 BTU/hour
110VAC input: 1060 BTU/hour
220VAC input: 1280 BTU/hour
Typical heat generated (DC/
HVDC power)
48VDC input: 990 BTU/hour
240VDC input: 1165 BTU/hour
380VDC input: 1195 BTU/hour
48VDC input: 1025 BTU/hour
240VDC input: 1195 BTU/hour
380VDC input: 1230 BTU/hour
Maximum heat generated (AC power)
220VAC input: 1045 BTU/hour
220VAC input: 1335 BTU/hour
Maximum heat generated (DC
/HVDC
power)
48VDC input: 1265 BTU/hour
240VDC input: 1520 BTU/hour
380VDC input: 1555 BTU/hour
48VDC input: 1300 BTU/hour
240VDC input: 1555 BTU/hour
380VDC input: 1590 BTU/hour
Specifications are subject to change without notification.
