Manual Chapter : Power specifications - i7000F (i7820-DF)
Applies To:
Show Versions Show Versions
BIG-IP APM
  • 16.0.0, 15.1.0, 15.0.1, 15.0.0, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
Manual Chapter
This table lists power specifications for i7000F (i7820-DF) Series platforms.
Item
Single power supply
Dual power supply
Idle power draw (AC power)
110VAC input: 240W
220VAC input: 235W
110VAC input: 245W
220VAC input: 250W
Idle power draw (DC
/HVDC
power)
48VDC input: 235W
240VDC input: 250W
380VDC input: 255W
48VDC input: 245W
240VDC input: 260W
380VDC input: 260W
Typical power draw (AC power; 50% load; temp 25°C)
110VAC input: 355W
220VAC input: 345W
110VAC input: 360W
220VAC input: 355W
Typical power draw (DC
/HVDC
48VDC input: 350W
240VDC input: 350W
380VDC input: 355W
48VDC input: 355W
240VDC input: 360W
380VDC input: 365W
Maximum power draw (AC power)
110VAC input: 465W
240VAC input: 450W
110VAC input: 470W
240VAC input: 460W
Maximum power draw (DC
/HVDC
power)
48VDC input: 460W
240VDC input: 450W
380VDC input: 455W
48VDC input: 465W
240VDC input: 460W
380VDC input: 465W
Typical heat generated (AC power)
110VAC input: 1215 BTU/hour
220VAC input: 1180 BTU/hour
110VAC input: 1230 BTU/hour
220VAC input: 1215 BTU/hour
Typical heat generated (DC
/HVDC
power)
48VDC input: 1195 BTU/hour
240VDC input: 1195 BTU/hour
380VDC input: 1215 BTU/hour
48VDC input: 1215 BTU/hour
240VDC input: 1230 BTU/hour
380VDC input: 1250 BTU/hour
Maximum heat generated (AC power)
220VAC input: 1590 BTU/hour
220VAC input: 1605 BTU/hour
Maximum heat generated (DC
/HVDC
power)
48VDC input: 1570 BTU/hour
240VDC input: 1540 BTU/hour
380VDC input: 1555 BTU/hour
48VDC input: 1590 BTU/hour
240VDC input: 1570 BTU/hour
380VDC input: 1590 BTU/hour
Specifications are subject to change without notification.
