Manual Chapter : Power specifications - i800 (i850)i2000 (i2600/i2800) Series
Applies To:
Show Versions Show Versions
BIG-IP APM
  • 16.0.0, 15.1.0, 15.0.1, 15.0.0, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
Manual Chapter
i800 (i850)
i2000 (i2600/i2800)
Series
This table lists power specifications for
i800 (i850)
i2000 (i2600/i2800)
Series platforms.
Item
Single power supply
Dual power supply
Idle power draw (AC power)
110VAC input: 70W
220VAC input: 70W
110VAC input: 80W
220VAC input: 75W
Typical power draw (AC power; 50% load; temp 25°C)
110VAC input: 95W
220VAC input: 95W
110VAC input: 100W
220VAC input: 100W
Typical power draw (DC power; 50% load; temp 25°C)
48VDC input: 105W
48VDC input: 115W
Maximum power draw (AC power)
110VAC input: 120W
220VAC input: 120W
110VAC input: 120W
220VAC input: 120W
Maximum power draw (DC power)
48VDC input: 125W
48VDC input: 140W
Typical heat generated (AC power)
110VAC input: 325 BTU/hour
220VAC input: 345 BTU/hour
Typical heat generated (DC power)
48VDC input: 360 BTU/hour
48VDC input: 395W
Maximum heat generated (AC power)
410 BTU/hour
410 BTU/hour
Maximum heat generated (DC power)
430 BTU/hour
480 BTU/hour
Specifications are subject to change without notification.
