Manual Chapter :
About replacing a drive in single-drive system
Applies To:
Show Versions
BIG-IP AAM
- 15.1.2, 15.1.1, 15.0.1, 15.0.0, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP APM
- 16.1.2, 16.1.1, 16.1.0, 16.0.1, 16.0.0, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.1.0, 15.0.1, 15.0.0, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
For iSeries platforms that include only one drive by
default, the drive is located in drive bay 1, and you must install the
replacement drive back into drive bay 1. You must also power down the system
when replacing a drive as part of routine maintenance or in the event of a
drive failure.
The replacement storage drive
provided by
F5
does not come with
pre-installed software. You will need to create a bootable USB flash drive to
install software onto the drive. Alternately, you can use a PXE server to
install the software. For more information, see K13117: Performing a clean
installation of BIG-IP 11.x - 16.x.
