Manual Chapter :
Boot the iSeries
system from a bootable USB flash drive
Applies To:
Show Versions
BIG-IP AAM
- 15.1.2, 15.1.1, 15.0.1, 15.0.0, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP APM
- 16.1.2, 16.1.1, 16.1.0, 16.0.1, 16.0.0, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.1.0, 15.0.1, 15.0.0, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
Boot the iSeries
iSeries
system from a bootable USB flash driveBefore you boot the F5 system to the
Maintenance OS (MOS), be sure that you have console access to the system,
either through a console server or directly through a serial connection.
Once you boot to the MOS, you lose
connection with the system over SSH on the management
port.
You can use a bootable USB flash
drive as the installation source to install or upgrade an
F5
system.- Insert the flash drive into the USB port of the target system.
- Boot the target system.The device automatically boots to the MOS on the attached USB flash drive.
