Manual Chapter :
Configure bundling for 100GbE interfaces using
tmsh
Applies To:
Show Versions
BIG-IP AAM
- 15.1.2, 15.1.1, 15.0.1, 15.0.0, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP APM
- 16.1.2, 16.1.1, 16.1.0, 16.0.1, 16.0.0, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.1.0, 15.0.1, 15.0.0, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
tmsh
You can use
tmsh
to configure bundling
for the 100GbE QSFP28 interfaces on the platform at either 100GbE or 40GbE speeds.
The i10010 platform
does not support breaking out the 100GbE interfaces (that is, disabling
bundling).
- Open the TMOS Shell (tmsh).tmsh
- Change to the network module.netThe system prompt updates with the module name:user@bigip01(Active)(/Common)(tmos.net)#
- Configure bundling for a specific interface using this syntax.modify interface <interface-key>bundle[enabled|disabled]bundle-speed[100G|40G|not-supported]The default value ofbundle-speedis determined by the interface type. Unbundled interfaces havebundle-speedset tonot-supported.
