Manual Chapter :
Configure bundling for 40GbE QSFP+
interfaces using tmsh
Applies To:
Show Versions
BIG-IP AAM
- 15.1.2, 15.1.1, 15.0.1, 15.0.0, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP APM
- 16.1.2, 16.1.1, 16.1.0, 16.0.1, 16.0.0, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.1.0, 15.0.1, 15.0.0, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
You can use
tmsh
to configure bundling for the 40GbE
QSFP+ interfaces on a platform. When you disable bundling, you can use the
40GbE ports as individual 10GbE ports.- Open the TMOS Shell (tmsh).tmsh
- Change to the network module.netThe system prompt updates with the module name:user@bigip01(Active)(/Common)(tmos.net)#
- Configure bundling for a specific interface.modify interface <interface-key> bundle [ enabled | disabled ]
