Manual Chapter :
Configure FEC for 100GbE interfaces using tmsh
Applies To:
Show Versions
BIG-IP AAM
- 15.1.2, 15.1.1, 15.0.1, 15.0.0, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP APM
- 16.1.2, 16.1.1, 16.1.0, 16.0.1, 16.0.0, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.1.0, 15.0.1, 15.0.0, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
If your upstream switch does not
support Reed-Solomon Forward Error Correction (RS-FEC), you can use
tmsh
to disable it for the
100GbE interfaces on your platform. RS-FEC is intended to be enabled with 100GBASE-SR links and disabled for
100GBASE-LR4 links.
- Open the TMOS Shell (tmsh).tmsh
- Change to the network module.netThe system prompt updates with the module name:user@bigip01(Active)(/Common)(tmos.net)#
- Configure FEC for a specific interface using this syntax.modify interface <interface-key>forward-error-correction[enabled|disabled]
