Manual Chapter : Configure FEC for 100GbE interfaces using tmsh
Applies To:
Show Versions Show Versions
BIG-IP AAM
  • 15.0.1, 15.0.0, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP APM
  • 16.0.0, 15.1.0, 15.0.1, 15.0.0, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
Manual Chapter
If your upstream switch does not support Reed-Solomon Forward Error Correction (RS-FEC), you can use
tmsh
to disable it for the 100GbE interfaces on your platform.
RS-FEC is intended to be enabled with 100GBASE-SR links and disabled for 100GBASE-LR4 links.
  1. Open the TMOS Shell (
    tmsh
    tmsh
  2. Change to the network module.
    net
    The system prompt updates with the module name:
    user@bigip01(Active)(/Common)(tmos.net)#
    user@bigiq01(Active)(/Common)(tmos.net)#
  3. Configure FEC for a specific interface using this syntax.
    modify interface <interface_key>
    forward-error-correction
    enabled
    disabled
