Manual Chapter :
DC power supply unit (PSU) LEDs
Applies To:
Show Versions
BIG-IP AAM
- 15.1.2, 15.1.1, 15.0.1, 15.0.0, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP APM
- 16.1.2, 16.1.1, 16.1.0, 16.0.1, 16.0.0, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.1.0, 15.0.1, 15.0.0, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
The LEDs located on the DC power supply units (PSUs) indicate the operating state of the
PSUs.
Input LED | Output/Fault LED | Condition (PUB-0342-01 and later) |
green solid | green solid | Normal operation |
off | off | Fault: Input UV |
off | amber solid | Not valid |
green solid | amber solid | Fault: Fan, OTP, OC, VOUT OV/UV, VSB OV/UV |
green solid | amber blinking | Warning: FAN, OTP, OC, VOUT OV/UV, VSB OV/UV |
green blinking | amber solid | Fault: Input OV |
green blinking | amber blinking | Warning: Input OV/UV |
green blinking | off | Not valid |
green solid | green blinking | PS_ON_L is high |
green solid | off | PS_KILL PSU not inserted |
OV - Over Voltage; OTP - Over Temperature Protection; UV - Under Voltage;
OC - Over Current; VSB - Standby Voltage
