Manual Chapter :
Power specifications - i11000S
(i11400-DS/i11600-DS/i11800-DS)
Applies To:
Show Versions
BIG-IP AAM
- 15.1.2, 15.1.1, 15.0.1, 15.0.0, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP APM
- 16.1.2, 16.1.1, 16.1.0, 16.0.1, 16.0.0, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.1.0, 15.0.1, 15.0.0, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
This table lists power specifications for i11000S (i11400-DS/i11600-DS/i11800-DS) Series
platforms.
Item | Single power supply | Dual power supply |
Idle power draw (AC power) | 110VAC input: 295W
220VAC input: 290W | 110VAC input: 305W
220VAC input: 295W |
Typical power draw (AC power; 50% load; temp
25°C) | 110VAC input: 435W 220VAC input: 425W | 110VAC input: 435W 220VAC input: 430W |
Maximum power draw (AC power) | 110VAC input: 575W
240VAC input: 560W | 110VAC input: 565W
Typical heat generated (AC power) | 110VAC input: 1485 BTU/hour
220VAC input: 1455 BTU/hour | 110VAC input: 1485 BTU/hour
220VAC input: 1470 BTU/hour |
Maximum heat generated (AC power) | 1965 BTU/hour | 1930 BTU/hour |
Specifications are subject to change without
notification.
