Manual Chapter :
Power
specifications - i15000/i15000N (i15600/i15800/i15800-N) Series
Applies To:
Show Versions
BIG-IP AAM
- 15.1.2, 15.1.1, 15.0.1, 15.0.0, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP APM
- 16.1.2, 16.1.1, 16.1.0, 16.0.1, 16.0.0, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.1.0, 15.0.1, 15.0.0, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
Power
This table lists power specifications for
i15000/i15000N (i15600/i15800/i15800-N) Series platforms.
Item | Single power supply | Dual power supply |
Idle power draw (AC
power) | 110VAC input: 640W
220VAC input: 630W | 110VAC input: 655W
220VAC input: 645W |
Idle power draw (DC
power) | 48VDC input: 635W | 48VDC input: 650W |
Typical power draw (AC power;
50% load; temp 25°C) | 110VAC input: 870W
220VAC input: 850W | 110VAC input: 885W
220VAC input: 875W |
Typical power draw (DC power;
50% load; temp 25°C) | 48VDC input: 880W | 48VDC input: 875W |
Maximum power draw (AC
power) | 110VAC input: 1100W
220VAC input: 1065W | 110VAC input: 1110W
220VAC input: 1100W |
Maximum power draw (DC
power) | 48VDC input: 1120W | 48VDC input: 1100W |
Typical heat generated (AC
power) | 110VAC input: 2970 BTU/hour
220VAC input: 2905 BTU/hour | 110VAC input: 3020 BTU/hour
220VAC input: 2990 BTU/hour |
Typical heat generated (DC
power) | 48VDC input: 3005
BTU/hour | 48VDC input: 2990
BTU/hour |
Maximum heat generated (AC
power) | 3755 BTU/hour | 3790 BTU/hour |
Maximum heat generated (DC
power) | 3825 BTU/hour | 3755 BTU/hour |
Specifications are subject to change without
notification.
