Manual Chapter :
Power
specifications - i7000F (i7820-DF)
Applies To:
Show Versions
BIG-IP AAM
- 15.1.2, 15.1.1, 15.0.1, 15.0.0, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP APM
- 16.1.2, 16.1.1, 16.1.0, 16.0.1, 16.0.0, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.1.0, 15.0.1, 15.0.0, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
Power
This table lists power specifications for i7000F
(i7820-DF) Series platforms.
Item | Single power supply | Dual power supply |
Idle power draw (AC
power) | 110VAC input: 240W
220VAC input: 235W | 110VAC input: 245W
220VAC input: 250W |
Idle power draw (DC /HVDC
power) | 48VDC input: 235W 240VDC input: 250W 380VDC input: 255W | 48VDC input: 245W 240VDC input: 260W 380VDC input: 260W |
Typical power draw (AC power;
50% load; temp 25°C) | 110VAC input: 355W
220VAC input: 345W | 110VAC input: 360W
220VAC input: 355W |
Typical power draw (DC /HVDC
power; 50% load; temp 25°C) | 48VDC input: 350W 240VDC input: 350W 380VDC input: 355W | 48VDC input: 355W 240VDC input: 360W 380VDC input: 365W |
Maximum power draw (AC
power) | 110VAC input: 465W
240VAC input: 450W | 110VAC input: 470W
240VAC input: 460W |
Maximum power draw (DC /HVDC
power) | 48VDC input: 460W 240VDC input: 450W 380VDC input: 455W | 48VDC input: 465W 240VDC input: 460W 380VDC input: 465W |
Typical heat generated (AC
power) | 110VAC input: 1215 BTU/hour
220VAC input: 1180 BTU/hour | 110VAC input: 1230 BTU/hour
220VAC input: 1215 BTU/hour |
Typical heat generated (DC /HVDC
power) | 48VDC input: 1195 BTU/hour 240VDC input: 1195 BTU/hour 380VDC input: 1215 BTU/hour | 48VDC input: 1215 BTU/hour 240VDC input: 1230 BTU/hour 380VDC input: 1250 BTU/hour |
Maximum heat generated (AC
power) | 220VAC input: 1590 BTU/hour | 220VAC input: 1605 BTU/hour |
Maximum heat generated (DC /HVDC
power) | 48VDC input: 1570 BTU/hour 240VDC input: 1540 BTU/hour 380VDC input: 1555 BTU/hour | 48VDC input: 1590 BTU/hour 240VDC input: 1570 BTU/hour 380VDC input: 1590 BTU/hour |
Specifications are subject to change without
notification.
