Manual Chapter : Configure bundling for 100GbE interfaces using tmsh
Applies To:
Show Versions Show Versions
BIG-IP DNS
  • 15.0.1, 15.0.0, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP PEM
BIG-IP AFM
BIG-IP Analytics
BIG-IP ASM
BIG-IP APM
BIG-IP LTM
Manual Chapter
You can use
tmsh
to configure bundling for the 100GbE QSFP28 interfaces on the platform at either 100GbE or 40GbE speeds.
The i10010 platform does not support breaking out the 100GbE interfaces (that is, disabling bundling).
  1. Open the TMOS Shell (
    tmsh
    tmsh
  2. Change to the network module.
    net
    The system prompt updates with the module name:
    user@bigip01(Active)(/Common)(tmos.net)#
    user@bigiq01(Active)(/Common)(tmos.net)#
  3. Configure bundling for a specific interface using this syntax.
    modify interface <interface_key>
    bundle
    enabled
    disabled
    bundle-speed
    100G
    40G
    not-supported
    The default value of
    bundle-speed
    is determined by the interface type. Unbundled interfaces have
    bundle-speed
    set to
    not-supported
