Manual Chapter : Power specifications - i15000/i15000N (i15600/i15800/i15800-N) Series
Applies To:
Show Versions Show Versions
BIG-IP DNS
  • 15.0.1, 15.0.0, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0, 12.1.4, 12.1.3
BIG-IP PEM
BIG-IP AFM
BIG-IP Analytics
BIG-IP ASM
BIG-IP APM
BIG-IP LTM
Manual Chapter
This table lists power specifications for i15000/i15000N (i15600/i15800/i15800-N) Series platforms.
Item
Single power supply
Dual power supply
Idle power draw (AC power)
110VAC input: 640W
220VAC input: 630W
110VAC input: 655W
220VAC input: 645W
Idle power draw (DC power)
48VDC input: 635W
48VDC input: 650W
Typical power draw (AC power; 50% load; temp 25°C)
110VAC input: 870W
220VAC input: 850W
110VAC input: 885W
220VAC input: 875W
Typical power draw (DC power; 50% load; temp 25°C)
48VDC input: 880W
48VDC input: 875W
Maximum power draw (AC power)
110VAC input: 1100W
220VAC input: 1065W
110VAC input: 1110W
220VAC input: 1100W
Maximum power draw (DC power)
48VDC input: 1120W
48VDC input: 1100W
Typical heat generated (AC power)
110VAC input: 2970 BTU/hour
220VAC input: 2905 BTU/hour
110VAC input: 3020 BTU/hour
220VAC input: 2990 BTU/hour
Typical heat generated (DC power)
48VDC input: 3005 BTU/hour
48VDC input: 2990 BTU/hour
Maximum heat generated (AC power)
3755 BTU/hour
3790 BTU/hour
Maximum heat generated (DC power)
3825 BTU/hour
3755 BTU/hour
Specifications are subject to change without notification.
