Manual Chapter : Revert to default configuration of the partition
Applies To:
Show Versions Show Versions
F5OS
  • 1.1.1, 1.1.0
Manual Chapter
If you want to preserve the chassis partition configuration, back up the existing system configuration of the partition and any tenants before you restore the default. Then export the backup to an HTTPS server where it will be available if you need it later.
If you want to restore a chassis partition to its default configuration, you can do that from the partition CLI.
  1. Log in to the command line interface (CLI) of the chassis partition using an account with admin access.
    When you log in to the system, you are in user (operational) mode.
  2. Change to config mode.
    config
    The CLI prompt changes to include
    (config)
  3. Clear all existing configuration and regenerate the default configuration.
    system database reset-to-default proceed yes
    system database reset-to-default proceed yes result Database reset-to-default successful.
The chassis partition now has the default configuration as if it was just created. You need to reconfigure it as needed and deploy tenants.
