Manual Chapter : System Controller Management
Applies To:
  • F5OS-C
    1.6.0
A VELOS chassis contains a redundant pair of system controllers. Together, the system controllers provide a high bandwidth interconnect between blades, as well as external management connectivity to the blades. Each system controller has a front-panel serial console and a front panel Ethernet management port. System controllers operate in an active-active state when routing traffic between blades, but otherwise operate in a active-standby state for management functions.
During initial configuration, you assign these three management IP addresses to the system controllers:
  • Floating IP address
  • System controller 1 management IP address
  • System controller 2 management IP address
The floating IP address should be the primary management address for the system, so that connections go to the active system controller. You can use the floating IP address to manage the system from the webUI, system controller CLI, or REST APIs. In some cases, such as for troubleshooting, you might log in to an individual system controller IP address, as opposed to the floating IP address.
The system controllers are designed to work together as a redundant, high availability pair.
One of the system controllers is designated as active (or the primary node) and the other as standby. The system controllers act as an active-standby pair for system management and as an active-active pair with regard to traffic processing on the backplane. Each system controller handles half of the traffic in the chassis; if a system controller is not available, the available bandwidth of the chassis is halved. Centralized management functions include hosting the primary (floating) IP address and providing the webUI, CLI, and REST API interfaces that you use to configure and manage the VELOS system.
The default mode for system controller high availability (HA) is Auto, which lets the system select the system controller that is best suited at the time to be the active system controller. This is the recommended setting.
It is possible to set a preference for either system controller to be active, however, this should rarely be necessary. When you do specify a preference for a particular system controller, that system controller will become active if it is in a healthy operational state. If the preferred controller is not present or unhealthy, the non-preferred system controller becomes active. When the preferred system controller returns to an available state, a switchover occurs.
You should not need to change system controller high availability (HA) to something other than the default configuration (Auto), but you can opt to change the configuration or initiate a failover from the active controller to the standby from the system controller webUI.
  1. Log in to the VELOS system controller webUI using an account with admin access.
  2. On the left, click SYSTEM SETTINGS > Controller Management.
  3. For the Preferred Node field, select System Controller 1 or System Controller 2 to act as an active system controller, or choose Auto (recommended).
    Note: Changing the Preferred Node configuration creates a failover event and ends the session if you select the system controller that is currently acting as the standby. Wait 30 seconds and then start a new session with either the floating IP address or the active system controller IP address after the change has completed.
    Hardware health conditions of the system controllers always take precedence. If one of the system controllers is not healthy, the chassis partition will ignore the preference and synchronize with the healthy system controller.
  4. To force a failover to occur immediately, click Failover.
    Note: The Failover button is available only when Preferred Node field is set to Auto.
    You would do this only if you want the current standby system controller to become the active system controller.
You can change the preferred system controller high availability (HA) mode from either the system controller or chassis partition CLI.
  1. Connect using SSH to the system controller floating management IP address or chassis partition management IP address.
  2. Log in to the command line interface (CLI) of the system controller or chassis partition using an account with admin access.
    When you log in to the system, you are in user (operational) mode.
  3. Change to config mode.
    config
    The CLI prompt changes to include (config).
  4. Change system controller high availability/redundancy to a specified mode.
    system redundancy config mode [ auto | prefer-1 | prefer-2 }
    These redundancy modes are available:
    Option Description
    auto System chooses preferred mode automatically. This is the default value.
    prefer-1 Prefer controller-1 to be active.
    prefer-2 Prefer controller-2 to be active.
    This example shows configuring controller-1 as the preferred active system controller from the system controller CLI:
    syscon-1-active(config)# system redundancy config mode prefer-1
  5. Commit the configuration changes.
    commit
You can view the status of system controller high availability (HA) from either the system controller or chassis partition CLI.
  3. Show the current HA configuration for the system controllers.
    show system redundancy
    A summary similar to this example displays when run on a system controller:
    syscon-1-active# show system redundancy
    system redundancy state mode auto
    system redundancy state current-active controller-1
    NAME          NAME
    controller-1  -
    controller-2  -
The Controller Management screen on the system controller webUI includes options for updating system controller software.
The Software Install Status screen on the system controller webUI enables you to monitor the progress of the updates to system controllers and the chassis partitions software.
For more information about installing or upgrading system controllers, see VELOS Systems: Installation and Upgrade at the F5OS Knowledge Center.
Before you begin, consider creating a backup of the system controller configuration before you update the system. Configuration file backups are stored in configs/. To export the configuration file, use File Utilities or the file export command. For more information, see Complete backup and restore overview.
Before you begin, you must also have imported the updated system controller software image before you can do the update. Go to Software Management > Controller Images to import the software image file.
You can update system controller software while the system is up and running with only a brief interruption from the system controller webUI. The system applies the software update automatically to the system controllers one at a time in a rolling update. F5 recommends, however, that you perform the update during a maintenance window.
  3. In the Update Software section, for Update System Controller Software:
    • To install a full F5OS-C version release, select Bundled.
    • To install F5OS-C and service version releases independently, select Unbundled.
  4. For ISO Image, select the full version release ISO image.
    This field is available when Bundled is selected.
  5. To enable out-of-service upgrades, click Show Advanced Options, then for Allow Out-of-Service Upgrades, select True.
    Choose this option if you want to either downgrade to a software version that does not support rolling upgrades (for example, software prior to F5OS-C software version 1.2.0) or reduce system controller upgrade time, but with a cost-of-service outage.
  6. For Base OS Version, select the F5OS version.
    This field is available when Unbundled is selected.
  7. For Service Version, select the service version release.
  8. Click Save.
    The system displays a confirmation dialog confirming whether to update the system controllers.
  9. Click OK to continue with the update.
    When updating from 1.2.x to a greater release: first, the system updates the standby system controller, reboots it, and then the standby becomes the active system controller. You will have to log in again after the failover occurs. The system then updates the other system controller (now in standby), and no other interruptions occur.
    Note: F5 recommends updating the system during a maintenance window. Do not perform any configuration operations while the system is being updated.
The system controllers are both updated. Traffic is interrupted briefly during the failover from one system controller to the other. If the update is not successful, the system reverts to the last working software version on both system controllers. You can monitor the update progress on the System Settings > Software Installation Status screen.
You can view the software installation status for the system controllers and the chassis partitions from the system controller webUI.
  2. On the left, click SYSTEM SETTINGS > Software Install Status.
Software installation status is shown for both system controllers and the chassis partitions. You can see whether a recent installation was successful and view what software version is running.
Before you begin updating the system, consider creating a backup of the system controller configuration. Configuration file backups are stored in configs/. To export the configuration file, use File Utilities from the webUI or the file export command. For more information, see Complete backup and restore overview.
Before you can do the update, you must also have imported the updated system controller software image. To import the software image file, use File Utilities from the webUI or the file import command.
You can update system controller software while the system is up and running from the CLI. The system applies the software update automatically to the system controllers one at a time in a rolling update. F5 recommends, however, that you perform the update during a maintenance window.
  1. Connect to the system using a management console or console server.
    Note: The default baud rate and serial port configuration is 19200/8-N-1.
  2. Log in to the command line interface (CLI) of the system controller using an account with admin access.
  3. Verify that the image you want to install is listed, and the status is ready.
    show image
    This verifies that the ISO is imported properly to the image server on the system controllers, and the system controllers can access these images when it reboots.
    A summary similar to this excerpt displays:
    syscon-1-active# show image
    VERSION OS                                  IN
    CONTROLLER  CONTROLLER  STATUS  DATE        USE
    1.6.0-7890  1           ready   2022-12-28  true
    VERSION
    SERVICE                                     IN
    VERSION
    ISO                                         IN
    1.6.0-7890  1           ready   2022-12-28  false
    VERSION OS                                  IN
    1.6.0-7890  2           ready   2022-12-28  true
    VERSION
    SERVICE                                     IN
    VERSION
    ISO                                         IN
    1.6.0-7890  2           ready   2022-12-28  false
    VERSION OS                                  IN
    PARTITION   CONTROLLER  STATUS  DATE        USE   NAME     ID
    1.6.0-7890  1           ready   2022-12-28  true  default  1
                                                      second   2
                                                      third    3
  4. Change to config mode.
    config
  5. Set the ISO version to the new version.
    system image set-version iso-version <*version*> proceed [ yes | no ]
    Note: By default, you will be prompted to confirm the upgrade. To bypass the confirmation prompt, include proceed yes at the end of the command sequence.
    This example shows upgrading the ISO version:
    syscon-1-active(config)# system image set-version iso-version 1.6.0-7890
  6. When the compatibility check succeeds, type yes to proceed with the installation process.
    response Controller iso version has been set
    Controller will reboot here, wait for reboot to complete and services to come up.
    Check controller networking, cluster status, partition status
The software on the standby system controller updates to the specified version, while the active system controller maintains production functionality of the chassis. After a successful update, the active system controller reboots and switches to standby. Traffic is interrupted briefly during the failover from one system controller to the other, and you will have to log in again after failover occurs. The software then installs on the second system controller. If, for any reason, the update is not successful, the system reverts to the last working software version on both system controllers.
You can cancel an in-progress or pending rolling upgrade of system controller software from the CLI.
    config
  4. Cancel an in-progress software installation.
    system image install-abort
    This example shows canceling and confirming an in-progress software upgrade:
    syscon-1-active(config)# system image install-abort
    You are cancelling rolling upgrade, and may require manual recovery. Do you wish to proceed? [no,yes] yes
    syscon-1-active# show system image
                        SERVICE     ISO      INSTALL
    NUMBER  OS VERSION  VERSION     VERSION  STATUS
    1       1.6.0-7891  1.6.0-7891  -        aborted
    2       1.6.0-7891  1.6.0-7891  -        aborted
With VELOS chassis, blades do not have physical console ports. Each system controller has a physical console port. The system controllers in the chassis provide a terminal service that enables authorized users to access blade consoles over SSH using the chassis floating IP address.
At a high level, these user roles have terminal service access:
Admin
Users with this role can access any terminals in the chassis.
Resource admin
Terminal server admin
Users with this role have terminal server access to all consoles on the system regardless of partition restrictions.
Operator
Partition
Users with this role are not given access to any terminals in the chassis.
Since the chassis terminal service uses SSHD, clients can connect using SSH. The terminal service uses a range of network port numbers to differentiate between connections being requested to the various consoles in the chassis.
You can also access any blade console by selecting the desired blade using the Always-On Management (AOM) Command Menu after you connect a serial cable to either of the system controllers’ console ports. For more information about AOM, see the section entitled About Always-On Managementin the platform guide for your VELOS chassis.
The VELOS chassis terminal service uses a range of network port numbers to differentiate between connections being requested to either the blade or system controller consoles in a chassis.
Console Port number
System controller 1 7100
System controller 2 7200
Blade <1…x> 700x
If you are an authorized user, you can connect to a blade or system controller using the chassis terminal service.
  1. Connect using SSH to the blade or system controller that you want to access.
    ssh <*blade-or-sys-controller-ip-address*> -l admin -p <*port-number*>
    This example opens an SSH session to an IPv4 address as an admin user to the blade in slot 1:
    ssh 192.0.2.10 -l admin -p 7001
    This example opens an SSH session to an IPv4 address as an admin user to the system controller in slot 2:
    ssh 192.0.2.10 -l admin -p 7200
    This example opens an SSH session to an IPv6 address as an admin user to the blade in slot 4:
    ssh 2001:db8:ffff:100::1 -l admin -p 7004
    If there is not already an active terminal session attached to the specified console, you are connected immediately. If there is already an active terminal session attached, you can choose to terminate the existing terminal session and replace it.
When you complete your terminal session to a blade or a system controller, you can terminate your session by typing the Enter ~. (tilde period) command sequence.
