Manual Chapter :
System reports (QKView) overview
Applies To:
Show Versions
If you have any concerns about your system operation, you can use the QKView
utility to generate a system report to collect configuration and diagnostic information
from the system.
The QKView file contains machine-readable (JSON)
diagnostic data and combines the data into a single compressed tar.gz format
file. You can upload the QKView file to F5 iHealth at ihealth2.f5.com, where you can get help
verifying proper operation of the system, understanding and troubleshooting
any issues you might be having, and ensuring that the system is operating at
its maximum efficiency.
When generating a QKView from the
CLI, you use the same command to generate a QKView file at both the system/chassis
and the chassis partition levels. To generate a QKView from a remote system, the
commands differ slightly.
For information about generating a QKView for BIG-IP Next or other tenants, see the
documentation on my.f5.com and clouddocs.f5.com.
