Manual Chapter : Internal Chassis Networking
Applies To:
  • F5OS-C
    1.8.2, 1.8.1
The VELOS system uses an internal chassis network for control plane and management plane communication between firmware and software on the blades and system controllers. Traffic on this internal network is firewall-protected and is not exposed to a customer’s management network.
Internal VELOS chassis networking can use one of two IP address ranges known as RFC6598 and RFC1918. The RFC6598 address range maps the predefined VELOS internal network range to 100.64/12 IP addresses (the default). The RFC1918 range enables you choose one of 16 possible address ranges in the 10.0.0.0/12 address range.
IP addresses in the predefined range are reserved for the internal network and cannot be used for any of these addresses:
  • VELOS management IP addresses for the system controllers, chassis partitions, and tenants
  • Any external service configured on the VELOS system, such as a DNS server and NTP server
  • Source IP addresses of any device used to communicate with the VELOS system (such as a laptop, workstation, or other device that connects)
If your network uses addresses in the default predefined range for any of the above, you will not be able to access the VELOS system using the VELOS management interfaces (including the CLI, webUI, or REST APIs). This is only an issue if you use 100.64.0.0/12 addresses for VELOS management IP addresses, external servers, or source IP addresses described here. To prevent this issue, F5 provides a procedure that enables you to select a different internal IP address range during initial provisioning of a system, as an alternative to using the default range.
The VELOS internal chassis network uses 100.64.0.0/12 addresses. If your network needs to use this range, you can change the range of IP addresses that the internal chassis network implements. Instead, you can choose one of 16 possible address ranges in the 10.0.0.0/12 address range.
Note: It is recommended that you make this change before initial configuration or immediately after.
  1. If you have not performed initial setup of the system and configured management IP addresses, connect using the management console. If setup is already complete, log in using the floating IP address.
  2. Log in to the command line interface (CLI) of the system controller using an account with admin access.
    When you log in to the system, you are in user (operational) mode.
  3. Change to config mode.
    config
    The CLI prompt changes to include (config).
  4. Show the network prefix ranges for network range RFC1918.
    system network config network-range-type RFC1918 prefix ?
  5. Show the network prefix index ranges.
    syscon-1-active(config)# system network config network-range-type RFC1918 prefix ?
    Description:
    The network prefix index is used to select the range of IP addresses
    used internally within the chassis.  The network prefix should be
    selected such that internal chassis addresses do not overlap with
    site-local addresses that are accessible to the chassis.
    Network Prefix Index       Chassis Network Range
    0                          10.[0-15].0.0/12
    1                          10.[16-31].0.0/12
    2                          10.[32-47].0.0/12
    3                          10.[48-63].0.0/12
    4                          10.[64-79].0.0/12
    5                          10.[80-95].0.0/12
    6                          10.[96-111].0.0/12
    7                          10.[112-127].0.0/12
    8                          10.[128-143].0.0/12
    9                          10.[144-159].0.0/12
    10                         10.[160-175].0.0/12
    11                         10.[176-191].0.0/12
    12                         10.[192-207].0.0/12
    13                         10.[208-223].0.0/12
    14                         10.[224-239].0.0/12
    15                         10.[240-255].0.0/12
    Possible completions:
      <unsignedByte, 0 .. 15>[0]
  6. Select the network range to use for internal networking (0-15).
    system network config network-range-type RFC1918 prefix <*0*-*15*>
    This example sets the range to 10.[0-15].0.0/12:
    syscon-1-active(config)# system network config network-range-type RFC1918 prefix 0
  7. Commit the configuration changes.
    commit
  8. Power cycle the chassis.
    Warning: Changing the internal chassis network causes an automatic cluster reinstall process that takes approximately an hour to complete.
  9. Check the status of the cluster installation.
    show cluster install-progress
    A summary similar to this example displays:
    syscon-1-active# show cluster install-progress
    STAGE NAME               STATUS
    AddingBlade              Done
    HealthCheck              Done
    HostedInstall            Done
    MasterAdditionalInstall  Done
    MasterInstall            Done
    NodeBootstrap            Done
    NodeJoin                 Done
    Prerequisites            Done
    ServiceCatalogInstall    Done
    etcdInstall              Done
When the install status is Done for all stages, you can resume configuring the system.
