Updated Date: 10/27/2026
Health Engine API and Metadata Reference
This reference describes the heuristic script metadata fields, data sources, suite files, the system health recommendations API, the result file structure, the database storage model, and the severity levels used by the F5OS health engine.
Each heuristic script declares a metadata block that the engine reads at load time. The following table lists all supported metadata fields.
| Field | Type | Description |
id |
string | Unique identifier for the heuristic (for example, H00001). |
name |
string | A short, human-readable title that describes what the heuristic does. |
description |
string | A detailed description of what the heuristic does. Can be an empty string. |
tags |
array of strings | Labels used for filtering (for example, data-path, control-plane, drives, aom). |
role |
string | The platform role where the script runs. Values: appliance, partition, blade, chassis. |
platforms |
array of strings | Supported platform hardware types. Uses the F5OS HAL hostType value. |
triggers |
array of strings | System events that activate the heuristic (for example, firmware update complete, blade powered on). |
mode |
string | Execution mode. Examples: container:h-engine, remote:10.0.0.1. |
os_version |
string | A semver expression that specifies which F5OS versions the script supports. |
impact |
string | Qualitative impact level of the heuristic. |
engine_version |
string | Engine version constraint string. |
is_containerized |
boolean | Set to true when mode begins with container:. |
is_remote |
boolean | Set to true when mode begins with remote:. |
parameters |
object | Default parameter values declared in the heuristic metadata. |
The engine supports heuristic scripts written in Starlark, a Python-like language. Starlark scripts use the .pyh file extension.
Heuristic scripts can access the following system interfaces to inspect live platform data:
| Data source | Description |
| F5OS confd API | Query configuration and operational state through the confd interface. |
| Docker daemon | Inspect container status and configuration. |
| File system | Read files and directories on the platform. |
| Platform services | Access data from platform-hal, platform-fwu, diag-agent, and other PSF services. |
| tmstat database | Query internal platform statistics. |
| F5OS log files | Read and analyze log data. |
Heuristic scripts can produce the following types of output:
| Output type | Description |
| Log messages | Internal diagnostic messages used by F5 for troubleshooting. Not directly visible to customers. |
| Result items | Conditions detected by the script, each with a severity level. |
| Action items | Recommended or automated actions based on detected conditions. |
| Files | Files written to the logging directory by the script. |
A suite file groups one or more heuristics into a single file. Use suite files to define a reusable set of heuristics that you want to run together.
When you provide a suite file to the engine, it loads and runs all the heuristics defined in that file.
The health engine exposes health recommendations through the system health API. Use this to view recommended actions for each node.
show system health recommendations nodes node recommendationExample output:
NODE NAME ID TIMESTAMP COMPONENT ACTION DESCRIPTION SEVERITY
blade-2 A.69d5f9e2.1b 2026-04-08T07:01:20Z blade service-restart [S00002]: The platform-fwu service needs to be restarted error
A.69d5f9e2.1c 2026-04-08T07:01:20Z blade service-restart [S00002]: The platform-monitor service needs to be restarted error
controller-1 C.1.1.69ddefe5.25 2026-04-14T07:43:05Z controller service-restart [S00012]: The name-service-ldap service needs to be restarted error
C.1.1.69ddefe5.26 2026-04-14T07:43:05Z controller service-restart [S00012]: The platform-monitor service needs to be restarted errorThe following actions can appear in health recommendations:
| Action | Description |
| Restart a node | Restart a blade, controller, or appliance. |
| Shut down a node | Shut down a blade, controller, or appliance. |
| Capture a qkview | Generate a qkview for further analysis. |
| Restart a service | Restart a specific platform service. |
| Generate or clear an alarm | Create or remove an alarm on the system. |
| Generate an event | Create a system event. |
| Adjust logging level | Change the logging verbosity for a component. |
| Update diag-agent component health | Update the health status of a component in the diag-agent model. |
Some actions run automatically. Actions that could affect system performance or operation appear as recommendations only and are not performed automatically.
For the complete list of actions, data fields, and automation behavior, see Health engine actions reference.
The engine writes results to JSON files after each run.
| File | When created |
${log-dir}/results.json |
Once per run of the h-engine tool. |
${log-dir}/<heuristic-id>.<iteration>/result.json |
Once per heuristic script run, unless --skip-results is specified. |
The top-level structure contains three objects:
"runner": { ... },
"heuristics": [ ... ],
"results": { ... }
}| Object | Description |
runner |
Describes how the run was configured and how long it took. |
heuristics |
Lists the heuristic scripts that were loaded and executed. |
results |
Contains the aggregated results from all heuristic scripts in the run. |
startTime |
string (RFC 3339) | When the run started. |
duration |
number | Total run duration in seconds. |
options |
object | Configuration options for the run (see below). |
logDirectory |
string | Path to the log output directory. |
randomizeList |
boolean | Whether the heuristic execution order was randomized. |
repeatCount |
integer | Number of times to repeat the run. |
repeatDuration |
integer | Duration-based repeat interval. |
stopOnError |
boolean | Whether to stop the run when an error occurs. |
stopOnFailure |
boolean | Whether to stop the run when a failure occurs. |
concurrency |
integer | Number of heuristics to run concurrently. |
verbose |
boolean | Whether verbose logging is enabled. |
debug |
boolean | Whether debug logging is enabled. |
perHeuristicResults |
boolean | Whether per-heuristic result files are written. |
Each entry in the heuristics array contains the following fields:
id |
string | Unique identifier for the heuristic. |
name |
string | Short title of the heuristic. |
description |
string | Detailed description of the heuristic. |
path |
string | File path to the heuristic script. |
tags |
array of strings | Filtering tags. |
role |
string | Platform role where the script runs. |
Results are keyed by heuristic ID. Each value is an array of execution results. A heuristic appears more than once in the array when --repeat-count or --repeat-duration is used.
| Field | Type | Present when | Description |
runResult |
string | Always | Overall outcome (see runResult values below). |
startTime |
string (RFC 3339) | Always | When this heuristic execution started. |
duration |
number | Always | Execution time in seconds. |
iteration |
number | Always | Iteration index when repeating (1-based). |
results |
array | Always | Diagnostic result items emitted by the script. |
actions |
array | Always | Recommended action items emitted by the script. |
inputValue |
object | Non-null | Arbitrary input values set by the script. |
outputValue |
object | Non-null | Arbitrary output values produced by the script. |
error |
string | On script error | Error message when the script raised an uncaught exception. |
backtrace |
string | On script error | Starlark stack trace when the script raised an uncaught exception. |
files |
array of strings | Non-empty | Paths to files written into the logging directory by the script. |
environment |
object | Non-empty | Key/value environment snapshot for this execution (for example, HE_LOG_DIR). |
| Value | Meaning |
passed |
The heuristic ran to completion. No result items with severity error or higher were emitted. |
failure |
One or more result items with severity error, critical, alert, or emergency were emitted. |
error |
The script raised an uncaught exception. |
Each entry in the results array contains the following fields:
timestamp |
string (RFC 3339) | Always | When the result was generated. |
severity |
string | Always | Syslog-aligned severity level (see severity levels below). |
message |
string | Always | Human-readable description of the condition. |
value |
any | Non-null | Optional measured value associated with the result. |
"runner": {
"startTime": "2026-04-15T20:31:00Z",
"duration": 3.142,
"options": {
"logDirectory": "/var/log/h-engine/run_20260415.203100",
"randomizeList": false,
"repeatCount": 0,
"repeatDuration": 0,
"stopOnError": false,
"stopOnFailure": false,
"concurrency": 0,
"verbose": false,
"debug": false,
"perHeuristicResults": true
"heuristics": [
"id": "H00001",
"name": "Platform check",
"description": "Verifies the platform type is supported",
"path": "inventory/H00001.pyh",
"tags": ["platform"],
"role": "appliance"
"results": {
"H00001": [
"runResult": "passed",
"startTime": "2026-04-15T20:31:01Z",
"duration": 0.042,
"iteration": 1,
"results": [
"timestamp": "2026-04-15T20:31:01Z",
"severity": "info",
"message": "Platform is rSeries appliance",
"value": "appliance-1"
"actions": [],
"environment": {
"HE_LOG_DIR": "/var/log/h-engine/run_20260415.203100/H00001"
"heuristic": {
"id": "H00040",
"name": "Disk utilization check",
"description": "Alerts when disk utilization exceeds threshold",
"path": "inventory/H00040.pyh",
"tags": ["storage"],
"role": "appliance"
"result": {
"runResult": "failure",
"startTime": "2026-04-15T20:31:02Z",
"duration": 0.105,
"iteration": 1,
"results": [
"timestamp": "2026-04-15T20:31:02Z",
"severity": "error",
"message": "Disk utilization is 98%, threshold is 90%",
"value": 98
"actions": [
"severity": "critical",
"action": "generate-alarm",
"recommend": true,
"message": "Disk utilization exceeds threshold",
"data": {
"alert": "disk-high",
"source": "H00040"
"value": 98
"environment": {
"HE_LOG_DIR": "/var/log/h-engine/run_20260415.203100/H00040"
}The engine writes a log file for each run to the following default directory:
/var/log/h-engine/run_<date/time>The health engine can store run results to a SQLite database and retrieve run history. This provides a persistent record of past runs beyond the JSON result files.
- The engine writes run results to a SQLite database file called
agent.db. - You can retrieve past run results from the database to review diagnostic history.
- When the diag-agent runs the health engine, results are stored in
agent.dbautomatically. The content of this database is included in qkview captures.
| Execution context | Storage behavior |
| Diag-agent | Results are stored in agent.db and included in qkview captures automatically. |
Command line (h-engine) |
Results are written to JSON files in the log directory. |
The health engine uses standard syslog severity levels. Severity levels from emergency through error cause the run result to report as failure. Levels from warning through debug do not.
| Value | Causes run failure | Meaning |
emergency |
Yes | System is unusable. |
alert |
Yes | Immediate action required. |
critical |
Yes | Critical condition. |
error |
Yes | A problem was detected. |
warning |
No | Warning condition; the system is still healthy. |
notice |
No | Normal but significant event. |
info |
No | Informational. |
debug |
No | Debug information only. |
Heuristic scripts can target the following component types:
- Blade
- Controller
- Appliance
- Tray
- PSU (Power Supply Unit)
- PSU controller
- Drive
