Manual Chapter :
F5 Access for iOS session variables
Applies To:
Show Versions
BIG-IP APM
- 17.1.1, 17.1.0, 17.0.0, 16.1.5, 16.1.4, 16.1.3, 16.1.2, 16.1.1, 16.1.0, 16.0.1, 16.0.0, 15.1.10, 15.1.9, 15.1.8, 15.1.7, 15.1.6, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.0.1, 15.0.0, 14.1.5, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0, 12.1.4
F5 Access for iOS
session variablesThe following table contains a list of session variables and their
attributes.
Session variable | Description |
session.client.type | Indicates the client type, for example
Standalone . |
session.client.platform | Indicates the platform type, such as iOS |
session.client.app_id | The app ID for the client. For F5 Access for iOS this is
com.f5.Edge-Client . |
session.client.app_version | The app version for the client. For F5 Access 3.0.1 this is
3.0.1 . |
session.user.agent | Indicates the browser, device type, and operating system version of the client,
as well as the version of F5 Access. |
session.client.model | Indicates the model name of the mobile device. For example, iPhone |
session.client.platform_version | Indicates the platform and version of the mobile device. For example, 11.1 |
session.client.jailbreak | Indicates the jailbreak status of the device. 0
indicates the device is not jailbroken, 1 indicates the
device is jailbroken, and an empty response indicates that the status of the device is
unknown. |
session.client.biometric_fingerprint | Indicates whether the device supports biometric fingerprint authentication.
1 indicates that a fingerprint is configured,
0 indicates that a fingerprint is not configured, or
the device does not support fingerprint authentication. |
session.client.vpn_scope | Indicates the scope of the VPN tunnel. The result is
device for a device-wide VPN connection, and
per-app for a per-app VPN. |
session.client.vpn_tunnel_type | Indicates the type of VPN tunnel. For F5
Access for iOS, this is L3 . |
session.client.vpn_start_type | Indicates how the VPN connection was initiated.
session.client.version | Indicates the client protocol version. For iOS, the value is always
2.0 . |
session.client.device_passcode_set | Indicates whether the user has a device unlock passcode, PIN, or biometric
authentication configured. The results is 1 if a device
lock is configured, and 0 if it is not. |
session.client.browscap_info | Specifies the browser information presented. For example,
uimode=7&ctype=Standalone &cversion=2.0&cjs=0&cactivex=0
&cplugin=0&cplatform=iOS&cpu=ARM |
session.client.hostname | This is the device host name (for example,
SandysiPhone ). |
session.client.js | Indicates whether the device used Web Logon mode to log on. The result is
1 if Web Logon Mode was used, and
0 if it was not. |
session.client.mdm_device_unique_id, session.client.unique_id | This value is provided by an MDM with the MdmDeviceUniqueId or
UDID attribute. If both attributes are provided,
MdmDeviceUniqueId takes preference. If neither is provided this
session variable is not present. If this field is provided by the MDM, both session
variables are present. An example value is
RC1KQLCJFOJEEM0XIOB3P52OMUQ3UN9Y3SDA5RWR . |
session.client.mdm_assigned_id | This value is provided by the MDM in the MdmAssignedId
attribute. If this attribute is not provided, the session variable is not
present. |
session.client.mdm_instance_id | The value is provided by the MDM in the MdmInstanceId
present. |
session.client.mdm_device_wifi_mac_address | The value is provided by the MDM in the
MdmDeviceWifiMacAddress or WiFiMAC attribute.
If both attributes are provided, MdmDeviceWifiMacAddress takes
preference. If neither attribute is provided, the session variable is not present.
session.client.mdm_device_serial_number | The value is provided by the MDM in the MdmDeviceSerialNumber
or SerialNumber attribute.If both attributes are provided,
MdmDeviceSerialNumber takes preference. If neither attribute is
provided, the session variable is not present. |
