Manual Chapter :
Common commands for BFD base configuration
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
There are two common BFD commands that you can use to perform BFD base configuration.
To use these commands, you use the IMI Shell within
tmsh
.Sample command line sequence | Result |
bigip (config-if)# bfd interval 100 minrx 200 multiplier 4 | Sets desired Min Tx, required Min Rx, and detect Multiplier. |
bigip (config)# bfd slow-timer 2000 | Sets BFD slow timer to two seconds. |
