Manual Chapter :
Common commands for BFD routing configuration
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
There are a number of common BFD commands that you can use to perform BFD routing
configuration. To use these commands, you use the IMI Shell within
tmsh
.Protocol | Sample command line sequence | Result |
BGP4 | bigip (config-if)#
neighbor 1.1.1.1 fallover bfd
multihop | Enables multi-hop bidirectional forwarding detection to BGP neighbor 1.1.1.1 . |
OSPFv2 | bigip (config)#
bfd all-interfaces | Enables single-hop bidirectional forwarding detection for all OSPF neighbors. |
area 1 virtual-link 3.3.3.3 fallover
bfd | Enables multi-hop bidirectional forwarding detection to OSPF router 3.3.3.3 . |
IS-IS | bigip (config-if)#
bfd all-interfaces | Enables bidirectional forwarding detection for all IS-IS neighbors. |
