Manual Chapter :
Common commands for enabling multicast routing
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
There are several commands that you can use to enable multicast routing. To use these
commands, you access the IMI Shell within
tmsh
.Sample command line sequence | Result |
bigip (config-if)>en | Enables multicast functionality. |
bigip (config-if)#conf t | Enables configuration functionality. |
bigip (config-if)#ip pim dense-mode | Enables IPv4 PIM dense-mode functionality. |
bigip (config-if)#ipv6 pim dense-mode | Enables IPv6 PIM dense-mode functionality. |
bigip (config-if)#ip pim sparse-mode | Enables IPv4 PIM sparse-mode functionality. |
bigip (config-if)#ipv6 pim sparse-mode | Enables IPv6 PIM sparse-mode functionality. |
bigip (config-if)#ip pim sparse-dense-mode | Enables IPv4 PIM sparse-dense-mode functionality. |
bigip (config-if)#ipv6 pim sparse-dense-mode | Enables IPv6 PIM sparse-dense-mode functionality. |
