Manual Chapter :
Configuration overview for the PIM protocol
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
The first step in configuring Protocol Independent Multicast (PIM) protocol on the BIG-IP system is to use the IMI Shell within
tmsh
to
configure the protocol for the relevant advanced routing module (PIM).After configuring PIM protocol behavior, you enable the protocol on one or more specific route
domains.
You can find detailed documentation on PIM commands in the AskF5 knowledge base at
http://support.f5.com
