Manual Chapter :
NATs for outbound connections
Applies To:
Show Versions
BIG-IP AAM
BIG-IP APM
BIG-IP Analytics
BIG-IP Link Controller
BIG-IP LTM
BIG-IP PEM
BIG-IP AFM
BIG-IP DNS
BIG-IP ASM
The previous section summarized how a BIG-IP® system normally load
balances incoming traffic, and translates the source IP address in a response back to the
virtual address.
Sometimes, however, an internal node needs to initiate a connection, rather than simply respond
to a request. When a node on an internal network initiates a connection, the connection is
considered to be an
outbound
connection. In this case, because the outgoing packets
do not represent a response to a load-balanced request, the packets do not pass through a virtual
server, and therefore the system does not perform the usual source IP address translation.Without a NAT, the source IP address is a non-routable address. With a NAT, however, Local Traffic Manager translates the internal node’s private class IP
address to a public IP address, to which the external node can then route its response.
For example, suppose an internal node (such as a mail server) has a private class IP address
of
172.16.20.1
. You can create a NAT designed to translate the private
class address 172.16.20.1
to a public source address of your choice
(such as 207.10.1.101
). Consequently, whenever the internal node
172.16.20.1
initiates a connection destined for a node on the
external network, the system translates that source address of
172.16.20.1
to its public address
(207.10.1.101
).Sample NAT for an outbound connection
In this example, the NAT provides a way for an internal node to initiate a connection to a node on an external network, without showing a private class IP address as the source address.
A NAT has two settings;
NAT Address
and Origin
Address
. In this example:- The NAT address is207.10.1.101, and the origin address is172.16.20.1.
- The connection is an outbound connection, meaning that the connection is being initiated from the internal network, through Local Traffic Manager, to the external network.
- Local Traffic Manager translates the origin address to the NAT address.
- The origin address and the NAT address are source addresses.
A NAT always represents a one-to-one mapping between a public address and a private class address. However, if you would like to map multiple internal nodes to a single public address, you can use a secure network translation address (SNAT) instead of a NAT. You can use SNATs for outbound connections only.
