Updated Date: 07/07/2026
Updating the JavaScript engine
Updating the JavaScript engine enables the BIG-IP system to discover new types of generic malware.
On the Main tab, click Security > Security Updates > Fraud Protection Service > Engine Update.
The Engine Update screen appears.
Choose one of the following delivery modes:
- Select Automatic if you want to download and install an engine update from the Update server if it is available.
- Select Manual if you want to perform an engine update from an update file you receive from F5. If you set Delivery Mode to Manual, the Upload File setting appears.
- If you set Delivery Mode to Manual, at the Upload File field click the browse button to upload the engine update file you received from F5 support.
Note: Setting Delivery Mode to Manual is a temporary setting and only valid as long as you are in the update screen. When you leave the update screen, Delivery Mode reverts back to Automatic.
If you received a notification that updates are available or have uploaded an engine update file that you received from F5 support, click the Install Updates button to install the update.
Note: The engine update takes from 2-4 hours to take effect.
In addition to the notice that is displayed if the daily update check determines that an update is available, you can also check for available updates by clicking the Check for Engine Updates button.
The Check for Engine Updates button is useful in the case where a new update has become available after the daily check was performed. If you click this button and an update is available, you will receive a notification.
