Updated Date: 07/07/2026
Configuring Remote High-Speed Logging of DoS Protection Events
You can configure the BIG-IP system to log information about BIG-IP system denial-of-service (DoS) events, and send the log messages to remote high-speed log servers.
Important: The BIG-IP Advanced Firewall Manager (AFM) must be licensed and provisioned before you can configure DoS Protection event logging. Additionally, for high-volume logging requirements, such as DoS, ensure that the BIG-IP system sends the event logs to a remote log server.
This illustration shows the association of the configuration objects for remote high-speed logging of DoS Protection events.
When configuring remote high-speed logging of DoS Protection event logging, it is helpful to understand the objects you need to create and why, as described here:
| Object | Reason | Applies to |
| Pool of remote log servers | Create a pool of remote log servers to which the BIG-IP system can send log messages. | Creating a pool of remote logging servers. |
| Destination (unformatted) | Create a log destination of Remote High-Speed Log type that specifies a pool of remote log servers. | Creating a remote high-speed log destination. |
| Destination (formatted) | If your remote log servers are the ArcSight, Splunk, IPFIX, or Remote Syslog type, create an additional log destination to format the logs in the required format and forward the logs to a remote high-speed log destination. | Creating a formatted remote high-speed log destination. |
| Publisher | Create a log publisher to send logs to a set of specified log destinations. | Creating a publisher. |
| DNS logging profile | Create a custom DNS logging profile to define the data you want the BIG-IP system to include in the DNS logs and associate a log publisher with the profile. | Creating a custom DoS Protecttion Logging profile. |
| protected object (also called virtual server) | Associate a custom DNS profile with a protected object to define how the system logs the DNS traffic that the protected object processes. | Configuring a protected object to perform DoS Protection event logging. |
Before creating a pool of log servers, gather the IP addresses of the servers that you want to include in the pool. Ensure that the remote log servers are configured to listen to and receive log messages from the BIG-IP system.
At the top of the screen, click Configuration.
On the Main tab, click Local Traffic > Pools.
The Pool List screen opens.
Click Create.
The New Pool screen opens.
In the Name field, type a unique name for the pool.
Using the New Members setting, add the IP address for each remote logging server that you want to include in the pool:
Type an IP address in the Address field, or select a node address from the Node List.
Type a service number in the Service Port field, or select a service name from the list.
Note: Typical remote logging servers require port
514. -
Click Add.
Click Finished.
Before creating a remote high-speed log destination, ensure that at least one pool of remote log servers exists on the BIG-IP system.
Create a log destination of the Remote High-Speed Log type to specify that log messages are sent to a pool of remote log servers.
On the Main tab, click System > Logs > Configuration > Log Destinations.
The Log Destinations screen opens.
Click Create.
In the Name field, type a unique, identifiable name for this destination.
From the Type list, select Remote High-Speed Log.
Important: If you use log servers such as Remote Syslog, Splunk, or ArcSight, which require data be sent to the servers in a specific format, you must create an additional log destination of the required type, and associate it with a log destination of the Remote High-Speed Log type. With this configuration, the BIG-IP system can send data to the servers in the required format.
The BIG-IP system is configured to send an unformatted string of text to the log servers.
From the Pool Name list, select the pool of remote log servers to which you want the BIG-IP system to send log messages.
From the Protocol list, select the protocol used by the high-speed logging pool members.
Click Finished.
Ensure that at least one remote high-speed log destination exists on the BIG-IP system.
Create a formatted logging destination to specify that log messages are sent to a pool of remote log servers, such as Remote Syslog, Splunk, or IPFIX servers.
Click Create.
From the Type list, select a formatted logging destination, such as Remote Syslog, Splunk, or IPFIX.
The Splunk format is a predefined format of key value pairs.
The BIG-IP system is configured to send a formatted string of text to the log servers.
If you selected Remote Syslog, then from the Syslog Format list select a format for the logs, and then from the High-Speed Log Destination list, select the destination that points to a pool of remote Syslog servers to which you want the BIG-IP system to send log messages.
Important: For logs coming from Access Policy Manager (APM), only the BSD Syslog format is supported.
If you selected Splunk or IPFIX, then from the Forward To list, select the destination that points to a pool of high-speed log servers to which you want the BIG-IP system to send log messages.
Click Finished.
Ensure that at least one destination associated with a pool of remote log servers exists on the BIG-IP system.
Create a publisher to specify where the BIG-IP system sends log messages for specific resources.
On the Main tab, click System > Logs > Configuration > Log Publishers.
The Log Publishers screen opens.
Click Create.
In the Name field, type a unique, identifiable name for this publisher.
For the Destinations setting, select a destination from the Available list, and click << to move the destination to the Selected list.
Note: If you are using a formatted destination, select the destination that matches your log servers, such as Remote Syslog, Splunk, or ArcSight.
Click Finished.
Create a custom logging profile to log DoS Protection events and send the log messages to a specific location.
On the Main tab, click Security > Event Logs > Logging Profiles.
The Logging Profiles list screen opens.
Click Create.
The Create New Logging Profile screen opens.
In the Logging Profile Properties, select the DoS Protection check box.
The DoS Protection tab opens.
In the DNS DoS Protection area, from the Publisher list, select the publisher that the BIG-IP system uses to log DNS DoS events.
You can specify publishers for other DoS types in the same profile, for example, for SIP or Application DoS Protection.
Click Finished.
Assign this custom DoS Protection Logging profile to a protected object.
