Manual Chapter : Logging SIP DoS Events to IPFIX Collectors
Applies To:
  • BIG-IP AFM
    17.1.0, 17.5.0, 21.0.0, 21.1.0
You can configure the BIG-IP system to log information about SIP denial-of-service (SIP DoS) events and send the log messages to remote IPFIX collectors.
IPFIX is a set of IETF standards. The BIG-IP system supports logging of SIP DoS events over the IPFIX protocol . IPFIX logs are raw, binary-encoded strings with their fields and field lengths defined by IPFIX templates. IPFIX collectors are external devices that can receive IPFIX templates and use them to interpret IPFIX logs.
The configuration process involves creating and connecting the following configuration objects:
Object Reason
Pool of IPFIX collectors Create a pool of IPFIX collectors to which the BIG-IP system can send IPFIX log messages.
Destination Create a log destination to format the logs in IPFIX templates, and forward the logs to the IPFIX collectors.
Publisher Create a log publisher to send logs to a set of specified log destinations.
Perform these tasks to configure IPFIX logging of SIP DoS events on the BIG-IP system.
Note: Enabling IPFIX logging impacts BIG-IP system performance.
  1. Assemble a pool of IPFIX collectors
  2. Create an IPFIX log destination
  3. Create a publisher
  4. Create a custom DNS DoS protection logging profile
  5. Logging DoS/DDoS Events for a Protected Object
Before creating a pool of IPFIX collectors, gather the IP addresses of the collectors that you want to include in the pool. Ensure that the remote IPFIX collectors are configured to listen to and receive log messages from the BIG-IP system.
You can create a pool of IPFIX collectors to which the system can send IPFIX log messages.
  1. On the Main tab, click Local Traffic > Pools.
    The Pool List screen opens.
  2. Click Create.
    The New Pool screen opens.
  3. In the Name field, type a unique name for the pool.
  4. Using the New Members setting, add the IP address for each IPFIX collector that you want to include in the pool:
    1. Type the collector’s IP address in the Address field, or select a node address from the Node List.
    2. Type a port number in the Service Port field.
      By default, IPFIX collectors listen on UDP or TCP port 4739 and Netflow V9 devices listen on port 2055, though the port is configurable at each collector.
    3. Click Add.
  5. Click Finished.
A log destination of the IPFIX type specifies that log messages are sent to a pool of IPFIX collectors. Use these steps to create a log destination for IPFIX collectors.
  1. On the Main tab, click System > Logs > Configuration > Log Destinations.
    The Log Destinations screen opens.
  2. Click Create.
  3. In the Name field, type a unique, identifiable name for this destination.
  4. From the Type list, select IPFIX.
  5. From the Protocol list, select IPFIX or Netflow V9, depending on the type of collectors you have in the pool.
  6. From the Pool Name list, select an LTM pool of IPFIX collectors.
  7. From the Transport Profile list, select TCP, UDP, or any customized profile derived from TCP or UDP.
  8. The Template Retransmit Interval is the time between transmissions of IPFIX templates to the pool of collectors. The BIG-IP system only retransmits its templates if the Transport Profile is a UDP profile.
    An IPFIX template defines the field types and byte lengths of the binary IPFIX log messages. The logging destination sends the template for a given log type (for example, NAT44 logs or customized logs from an iRule) before sending any of those logs, so that the IPFIX collector can read the logs of that type. The logging destination assigns a template ID to each template, and places the template ID into each log that uses that template.
    The log destination periodically retransmits all of its IPFIX templates over a UDP connection. The retransmissions are helpful for UDP connections, which are lossy.
  9. The Template Delete Delay is the time that the BIG-IP device should pause between deleting an obsolete template and re-using its template ID. This feature is helpful for systems that can create custom IPFIX templates with iRules.
  10. The Server SSL Profile applies Secure Socket Layer (SSL) or Transport Layer Security (TLS) to TCP connections. You can only choose an SSL profile if the Transport Profile is a TCP profile. Choose an SSL profile that is appropriate for the IPFIX collectors’ SSL/TLS configuration.
    SSL or TLS requires extra processing and therefore slows the connection, so we only recommend this for sites where the connections to the IPFIX collectors have a potential security risk.
  11. Click Finished.
Ensure that at least one destination associated with a pool of remote log servers exists on the BIG-IP system.
Create a publisher to specify where the BIG-IP system sends log messages for specific resources.
  1. On the Main tab, click System > Logs > Configuration > Log Publishers.
    The Log Publishers screen opens.
  2. Click Create.
  3. In the Name field, type a unique, identifiable name for this publisher.
  4. For the Destinations setting, select a destination from the Available list, and move the destination to the Selected list.
    Note: If you are using a formatted destination, select the destination that matches your log servers, such as Remote Syslog, Splunk, or IPFIX.
    Important: If you configure a log publisher to use multiple logging destinations, then, by default, all logging destinations must be available in order to log to each destination. Unless all logging destinations are available, no logging can occur. If you want to log to the available logging destinations when one or more destinations become unavailable, you must set the logpublisher.atomic db key to false. If all the remote high-speed log (HSL) destinations are down (unavailable), setting the logpublisher.atomic db key to false will not work to allow the logs to be written to local-syslog. The logpublisher.atomic db key has no effect on local-syslog.
  5. Click Finished.
Create a custom logging profile to log DNS DoS events and send the log messages to a specific location.
  1. On the Main tab, click Security > Event Logs > Logging Profiles.
    The Logging Profiles list screen opens.
  2. Click Create.
    The Create New Logging Profile screen opens.
  3. In the Profile Name field, type a unique name for the logging profile.
  4. In the Logging Profile Properties, select the DoS Protection check box.
    The DoS Protection tab opens.
  5. In the DNS DoS Protection area, from the Publisher list, select the publisher that the BIG-IP system uses to log DNS DoS events.
    You can specify publishers for other DoS types in the same profile, for example, for SIP or Application DoS Protection.
  6. Click Create.
    The logging profile is created.
Now you created a logging profile so that the BIG-IP system can log messages about SIP DoS events and send the log messages to a pool of IPFIX collectors.
Assign this custom DNS DoS logging profile to a protected object.
Assign a logging profile to a protected object when you want the system to log DoS events.
  1. On the Main tab, click Security > DoS Protection > Protected Objects.
  2. Click the name of the protected object for which you want to log DoS events.
    The Properties pane opens on the right.
  3. In the Network & General area, for Logging Profiles, move the logging profile to assign from the Available list into the Selected list.
    You can create, and modify log publishers in System > Logs > Configuration > Log Publishers.
  4. Click Save.
The system logs DoS events for the protected object.
You can review DoS event logs at Security > Event Logs > DoS and select the type of DoS event log to view.
