Manual Chapter :
About IP macro attribute in dynamic template
Applies To:
Show Versions
BIG-IP APM
- 17.1.0
BIG-IP Link Controller
- 17.1.0
BIG-IP LTM
- 17.1.0
BIG-IP AFM
- 17.1.0
BIG-IP ASM
- 17.1.0
The
ip-macro
attribute distinguishes an IKE peer as a dynamic template. Each IKE peer requires a dedicated traffic-selector and IPsec policy. The ip-macro
attribute in IKE peer means the triple: ike-peer
, traffic-selector
, and ipsec-policy
is a template.Variables within
ip-macro
allow configuration generalization by replacing placeholder values. The ip-macro
attribute has up to three placeholder values: peer-ip
, peer-port
, and/or dynamic-ip
. For all three, the values act as variables. Wherever placeholder values for these appear in configuration, they will be replaced with the actual values when a tunnel is negotiated. For example, the peer's IP address
can be represented as a Martian IP address (from subnet 192.0.2.x) which acts as a variable. When peer-ip=192.0.2.1
appears inside ip-macro
, this means 192.0.2.1 is a variable that acts as a placeholder for the actual peer IP address
seen at negotiation time. During IKE negotiation, configuration will be generated that replaces the 192.0.2.1 with the peer's actual IP address
. The notation in ip-macro
declares the variables. The schema requires an IP address, so a Martian IP address like 192.0.2.1 is used to satisfy the syntax requirements. This approach avoids using the
<peer-ip>
variable, which would be considered invalid in terms of syntax. Following are examples for attribute
ip-macro
:net ipsec ike-peer <peer-name> { ... ip-macro="peer-ip=192.0.2.1 peer-port=234" peers-id-value 192.0.2.1 my-id-value <BIG-IP address> remote-address 192.0.2.1 ... }
net ipsec ike-peer <peer-name> { ... ip-macro="peer-ip=192.0.2.1 peer-port=234 dynamic-ip=192.0.2.13" remote-port 234 address-list '<IP address list value>' peers-id-value 192.0.2.1 my-id-value <BIG-IP address> remote-address 192.0.2.1 ... }
The Presented ID Value (my-id-value) and the Verified ID Value (peers-id-value) settings are mandatory configuration elements for IKEv2 tunnels. Configure these settings to maintain reliable IPsec connectivity between a BIG-IP system and a remote device.
The value of
peer-ip
inside ip-macro
defines the IP address that acts as a placeholder for a remote peer's IP address. For example, if the peer-ip
is 192.0.2.1
, then everywhere 192.0.2.1
appears, the system replaces this with the remote peer's actual IP address
which acts as the tunnel remote endpoint address.The
peer-ip
can be any IP address from the Martian IP addresses in the 192.0.2.x
subnet, as these addresses will never be used by real devices and the subnet is reserved for example documentation only.The
remote-port
variable is used to specify the remote peer's port number, the template value declares 234
as a placeholder for the actual peer-port
. The peer-port
is useful for NAT when more
than one remote peer can appear behind the same firewall IP address. The actual source port number is substituted where 234
appears as the value of a port. The
peer-port
can be any value from the reserved port numbers. According to IANA port number assignments, ports 225
to 241
are reserved and therefore can be used as dummy placeholder values.The
dynamic-ip
variable is only used when the remote
peer requests for an allocated IP address. This variable is a prediction that the remote peer will always request for an allocated IP, which
will get allocated from the address-list
attribute in the IKE peer.If the
peer-ip
is 192.0.2.1
, dynamic-ip
is 192.0.2.13
, and peer-port
is 234
, then 192.0.2.1
is a placeholder variable for the peer's actual IP address, 192.0.2.13
is a placeholder variable for an IP address
allocated by the BIG-IP from an address pool, and 234
is a placeholder value for the peer's actual port number. Use the
destination-ip
placeholder in a traffic selector to protect traffic through a tunnel using an allocated address. The following conditions must be met:- The remote peer intends to use an allocated address for traffic protected by a tunnel.
- The IKE peer has anaddress-listattribute to define an address pool for IP allocation.
- The IKE peer has anip-macrothat declares adynamic-ipvariable like192.0.2.13.It is recommended to only use192.0.2.13for dynamic IP address.
When all these conditions are met, the IKE peer will allocate an IP address from the address pool defined in
address-list
, and substitute that address for the placeholder value wherever it appears.
