Manual Chapter : Script Management
Applies To:
  • BIG-IQ Centralized Management
    6.0.1
Script Management
BIG-IP version 13.0 has Advanced Shell (bash) and Traffic Management Shell (tmsh) access disabled by default. BIG-IQ supports only requests from users with bash access, so before you can run scripts on BIG-IP version 13.0, you must enable it. For more information, refer to article K16413: Enabling Advanced Shell or tmsh access for BIG-IQ user accounts on AskF5 at: https://support.f5.com/csp/article/K16413.
From BIG-IQ Centralized Management, you can create scripts to run on your managed devices. For example, you could create a script that changes the syslog settings for multiple devices. Not only does this ensure those devices all have the same configuration, it saves you time too, because you don’t have to log in to and configure each device individually. You can save the scripts you create so you can run them in the future and you can share them with your colleagues.
  1. At the top of the screen, click Devices.
  2. On the left, click SCRIPT MANAGEMENT > Scripts.
  3. Near the top of the screen, click the Add button.
  4. In the Name and Description fields, type a name and optional description to identify this script.
  5. Into the Script field, type the commands or cut and paste a script you have saved elsewhere.
  6. Click the Save & Close button.
The new script is added to the list on the Scripts screen.
After you create a script, you can run it from BIG-IQ Centralized Management.
Run a script to quickly apply the same changes to several of your managed BIG-IP devices without requiring individual logins.
  3. Select the check box next to the script you want to run, and then click the Run button near the top of the screen.
  4. In the Name and Description fields, type a name and an optional description to identify this task.
  5. For the Timeout setting, specify the number of seconds for BIG-IQ to attempt running the script before canceling the task.
  6. For the Devices setting, move the devices you want to run this script on from the Available list to the Selected list.
  7. Click the Run button at the bottom of the screen.
You can monitor and view the results of the task on the Execution Log screen.
