Manual Chapter : Re-license a BIG-IP device with the same license
Applies To:
  • BIG-IQ Centralized Management
    7.0.0
If you make a change to an assigned BIG-IP license (for example, if you purchase an add-on key for a license), you’ll need to re-license the BIG-IP device the license is associated with.
Use this procedure to re-license a managed BIG-IP device.
  1. On the left, click LICENSE MANAGEMENT > Licenses.
  2. Click the license name.
  3. Select the check box next to the license and click the Refresh button.
BIG-IQ re-licenses the BIG-IP device to which this license was previously assigned to.
