Updated Date: 07/07/2026
Filtering for specific BIG-IP devices
From each BIG-IQ screen that contains a list of items, you can easily find specific items. For example, after you discover several devices, you might want to find a specific device by its name or IP address. To do this, you start by filtering on certain properties. Filtering on a specific criteria saves you time by allowing you to view only those items that contain the criteria you specify.
At the top of the screen, click Devices.
On the left, click BIG-IP DEVICES.
To search for a specific object, in the Filter field at the top right of the screen, type all or part of an object’s name and click the filter icon.
BIG-IQ refreshes the screen to show only those devices that contain the property you filtered on.
To remove the filter, click the X icon next to it.
