Updated Date: 07/07/2026
Importing SSL certificates, keys, and PKCS #12 SSL archive files created outside of BIG-IQ
There might be some cases where you’ve created an SSL certificate, key, or a PKCS SSL archive file on a system other than BIG-IQ Centralized Management. In those cases, you can easily import the certificates, keys, and files to BIG-IQ so you can centrally manage them for your BIG-IP devices.
To import certificates, you must have administrative role access and TMSH or bash shell access.
You can import a single SSL certificate hosted on a discovered BIG-IP device so you can manage it.
At the top of the screen, click Configuration.
On the left, click LOCAL TRAFFIC > Certificate Management > Certificates & Keys.
Near the top of the screen, click the Import button.
From the Import Type List select Certificate
If the silo is anything other than Default, select from the list in the Silo field.
If the partition is anything other than Common, type it into the Partition field.
For the Certificate Namesetting, select Create New or Overwrite Existing.
If you selected Overwrite Existing, select the certificate you want to overwrite.
For the Certificate Source setting:
- To upload the certificate’s file, select Upload File and click the Choose File button to navigate to the certificate file.
- To paste the content of the certificate file, select Paste Text and paste the certificate’s content into the Certificate Source field.
Click the Import button at the bottom of the screen.
The certificate displays in the Certificates & Keys list.
You can now assign this certificate to your managed BIG-IP VE devices.
To import from a BIG-IP device, the device must be discovered by BIG IQ. See Managing BIG-IP Devices from BIG-IQ for more information. You must also have administrative role access and TMSH or bash shell access.
To import from a third party certificate authority (CA) provider, you must integrate the certificate management authority with BIG-IQ. See Integrating Third Party Certificate Management for more information.
You can import existing certificates and keys from external sources, such as discovered BIG-IP devices and third party CA providers.
Click the Import button.
- Import from BIG-IP Devices to import certificates from devices.
- Import from CA Providers to import certificates from a third party CA. Once you select an option, the screen displays a list of devices and providers configured to your system.
Select the check box next to the item(s) on your list from which you would like to import certificates.
For BIG-IP devices, to import certificates with all their related objects (keys and CRLs), select the check box under the Retrieve All Objects column.
Add the username and password in for each select list item.
For multiple list selections that share the same password, add the username per row, and click Edit Multiple.
When you are done, click Import at the bottom of the screen.
The certificates associated with the selected list items are imported to BIG-IQ. You will be able to view the additions in the Certificates and Keys list.
After you import a certificate to BIG-IQ Centralized Management, you can import its associated key pair.
Import a key pair for an SSL certificate you created on a different system so you can centrally manage the certificate from BIG-IQ. This saves you time because you don’t have to log on to individual BIG-IP devices to monitor and deploy certificates.
From the Import Type list, select Key.
For the PKCS12 Name setting, select Create New or Overwrite Existing.
If you selected Overwrite Existing, select the key you want to overwrite.
For the PKCS12 Source setting, click the Choose File button to navigate to the file.
If the file is encrypted, into the PKCS12 Password field, type the password for the file.
If the key is encrypted, into the Key Password field, type the password for the key.
The PKCS12 file displays in the Certificates & Keys list.
Import a PKCS #12 SSL archive file you created on another system to BIG-IQ Centralized Management to centrally manage it. This saves you time because you don’t have to log on to individual BIG-IP devices to monitor or deploy it.
From the Import Type list, select PKCS#12.
For the PKCS12 Name, select Create New or Overwrite Existing.
If you selected Overwrite Existing, select the file you want to overwrite.
For the PKCS12 Source setting, select Upload File and Choose File to navigate to the file.
In the PKCS12 Password field, type the password.
If the key is encrypted, from the Key Security Type list, select Password and type the password for the key in the Key Password field.
Important: If you select Normal, BIG-IQ will store the key as unencrypted, which can put your data at risk.
You can now assign this SSL certificate and key pair to a Local Traffic Manager clientssl or serverssl profile. Before you deploy it to a BIG-IP device, you must add the clientssl or serverssl profile to that device’s LTM pinning policy. For more information about pinning, refer to the topic titled Managing Object Pinning in BIG-IQ: Security . For more information about deployments, refer to the topic titled Deploying Changes in Managing BIG-IP devices from BIG-IQ.
