Updated Date: 07/07/2026
Legal notices
20Publication Date
This document was published on February 27, 2020.
Copyright © 2020, F5 Networks, Inc. All rights reserved.
F5 Networks, Inc. (F5) believes the information it furnishes to be accurate and reliable. However, F5 assumes no responsibility for the use of this information, nor any infringement of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent, copyright, or other intellectual property right of F5 except as specifically described by applicable user licenses. F5 reserves the right to change specifications at any time without notice.
For a current list of F5 trademarks and service marks, see http://www.f5.com/about/guidelines-policies/trademarks/.
All other product and company names herein may be trademarks of their respective owners.
This product may be protected by one or more patents indicated at: https://f5.com/about-us/policies/patents
This product is not currently available in the U.S.
This product may include cryptographic software. Under the Export Administration Act, the United States government may consider it a criminal offense to export this product from the United States.
This is a Class A product. In a domestic environment this product may cause radio interference, in which case the user may be required to take adequate measures.
This equipment has been tested and found to comply with the limits for a Class A digital device pursuant to Part 15 of FCC rules. These limits are designed to provide reasonable protection against harmful interference when the equipment is operated in a commercial environment. This unit generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instruction manual, may cause harmful interference to radio communications. Operation of this equipment in a residential area is likely to cause harmful interference, in which case the user, at his own expense, will be required to take whatever measures may be required to correct the interference.
Any modifications to this device, unless expressly approved by the manufacturer, can void the user’s authority to operate this equipment under part 15 of the FCC rules.
This Class A digital apparatus complies with Canadian ICES-003.
This product conforms to the IEC, European Union, ANSI/UL and Canadian CSA standards applicable to Information Technology products at the time of manufacture.
