Manual Chapter :
Legal notices
Applies To:
Show Versions
BIG-IP APM
- 17.0.0, 16.1.2, 16.1.1, 16.1.0, 16.0.1, 16.0.0, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.1.0, 15.0.1, 15.0.0, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0
Legal notices
Publication Date
This document was published on
September 1, 2020
.Publication Number
Copyright
Copyright © 2019, F5 Networks, Inc. All rights reserved.
F5 Networks, Inc. (F5) believes the information it furnishes to be accurate and reliable.
However, F5 assumes no responsibility for the use of this information, nor any infringement
of patents or other rights of third parties which may result from its use. No license is
granted by implication or otherwise under any patent, copyright, or other intellectual
property right of F5 except as specifically described by applicable user licenses. F5
reserves the right to change specifications at any time without notice.
Trademarks
For a current list of F5 trademarks and service marks, see http://www.f5.com/about/guidelines-policies/trademarks/.
All other product and company names herein may be trademarks of their respective
owners.
Patents
This product may be protected by one or more patents indicated at: https://f5.com/about-us/policies/patents
Link Controller Availability
This product is not currently available in the U.S.
Export Regulation Notice
This product may include cryptographic software. Under the Export Administration Act, the
United States government may consider it a criminal offense to export this product from the
United States.
RF Interference Warning
This is a Class A product. In a domestic environment this product may cause radio
interference, in which case the user may be required to take adequate measures.
FCC Compliance
This equipment has been tested and found to comply with the limits for a Class A digital
device pursuant to Part 15 of FCC rules. These limits are designed to provide reasonable
protection against harmful interference when the equipment is operated in a commercial
environment. This unit generates, uses, and can radiate radio frequency energy and, if not
installed and used in accordance with the instruction manual, may cause harmful interference
to radio communications. Operation of this equipment in a residential area is likely to
cause harmful interference, in which case the user, at his own expense, will be required to
take whatever measures may be required to correct the interference.
Any modifications to this device, unless expressly approved by the manufacturer, can void
the user's authority to operate this equipment under part 15 of the FCC rules.
Canadian Regulatory Compliance
This Class A digital apparatus complies with Canadian ICES-003.
Standards Compliance
This product conforms to the IEC, European Union, ANSI/UL and Canadian CSA standards
applicable to Information Technology products at the time of manufacture.
