Manual Chapter :
BIG-IP Edge Client and F5 Access for
macOS
Applies To:
Show Versions![Show Versions](/etc/designs/pcx/techdocs/images/expandversions.gif)
BIG-IP APM
- 17.1.0, 17.0.0, 16.1.5, 16.1.4, 16.1.3, 16.1.2, 16.1.1, 16.1.0, 16.0.1, 16.0.0, 15.1.10, 15.1.9, 15.1.8, 15.1.7, 15.1.6, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.1.0, 15.0.1, 15.0.0, 14.1.5, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0
macOS
Requirements for client installation and use on Mac
The table lists requirements for installing and using client components on a macOS
system. These requirements apply to the Network Access client component that is downloaded from
the browser and to BIG-IP
Edge Client for Mac and F5 Access for macOS.
Requirement |
Specification |
Browser |
For App Tunnels to work, the browser must have Java enabled. For installation,
Java is optional. The client uses Java to streamline the installation process only.
Without Java, users can manually download and install the client packages. Java App Tunnels are supported on Edge Client only. |
Installation privilege |
The remote user must have superuser authority, or, must be able to supply an
administrative password to successfully install the Network Access client. |
About browser-based connections from Linux, Mac, and Windows clients
For Linux, Mac OS X, and Windows-based systems, the Network Access client component is
available for automatic download from the BIG-IP system.
The client component supports secure remote web-based access to the network. It
is not the same as the customizable client package that is associated with the connectivity
profile.
The first time a remote user starts Network Access, APM® downloads a
client component. This client component is designed to be self-installing and self-configuring.
If the browser does not meet certain requirements, APM prompts the user to download the client
component and install it manually.
Overview: Configuring and installing Edge Client for Mac
Users of BIG-IP
Edge Client®for Mac can connect securely and automatically to your network
while roaming using the automatic reconnect, password caching, and location awareness features of
Edge Client. You can customize the client package; you must download it and make it available to
users as hosted content on the BIG-IP system, or through another delivery mechanism.
About Edge Client
location awareness
The BIG-IP Edge Client provides a location-awareness feature. Using
location awareness, the client connects automatically only when it is not on a specified
network. The administrator specifies the networks that are considered in-network, by adding
DNS suffixes to the connectivity profile. With a location-aware client enabled, a user with
a corporate laptop can go from a corporate office, with a secured wireless or wired network
connection, to an offsite location with a public wireless network connection, and maintain
a seamless connection to allowed corporate resources. Network location-awareness can be
triggered to run because of various reasons, such as IP changes and network interfaces
starting up or shutting down. In reconnect mode, Edge Client might briefly establish a VPN
tunnel before the network location-awareness feature can disconnect it. The Edge Client
matches DNS suffixes reported by the system API to detect network location.
During a network
switch, such as changing Wifi connections, Edge Client with network location-awareness must
detect whether the new connection is local or remote. During this detection timeframe,
there is a brief amount of time that Edge Client does not block certain external websites
and can be reachable during the network switch.
About Edge Client
automatic reconnection
BIG-IP Edge Client provides an automatic reconnection feature.
This feature attempts to automatically reconnect the client system to corporate network
resources whenever the client connection drops or ends prematurely.
Configuring a connectivity profile for Edge Client for
macOS
Update the connectivity profile in your
Network Access configuration to configure security settings, servers, and
location-awareness for BIG-IP Edge Client for macOS.
- On the Main tab, click.A list of connectivity profiles displays.
- Select the connectivity profile that you want to update and clickEdit Profile.The Edit Connectivity Profile popup screen opens and displays General Settings.
- From the left pane of the popup screen, selectWin/Mac Edge Client.Edge Client settings for Mac and Windows-based systems display in the right pane.
- Retain the default (selected) or clear theSave Servers Upon Exitcheck box.Specifies whether Edge Client maintains a list of recently used user-entered APM servers. Edge Client always lists the servers that are defined in the connectivity profile, and sorts them by most recent access, whether this option is selected or not.
- To enable the client to launch an administrator-defined script on session termination, selectRun session log off scriptcheck box. The administrator specifies parameters which are passed by Edge Client to the script file. These parameters are defined by the session variablesession.edgeclient.scripting.logoff.params. The client retrieves parameters from BIG-IP after session establishment. The administrator has the flexibility to set up variable values according to policy branching. Each time the Edge Client closes an APM session, the configured script is invoked. On macOS, the script is located at/Library/Application Support/F5Networks/EdgeClient/Scripting/onSessionTermination.bat.TheRun session log off scriptcheck box is cleared by default.
- To enable the client to display a warning before launching the pre-defined script on session termination, selectShow warning to user before launching scriptcheck box.This is selected by default.
- To support automatic reconnection without the need to provide credentials again, allow password caching.
- Select theAllow Password Cachingcheck box.This check box is cleared by default.The remaining settings on the screen become available.
- From theSave Password Methodlist, selectdiskormemory.If you selectdisk, Edge Client caches the user's password (in encrypted form) securely on the disk where it is persisted even after the system is restarted or Edge Client is restarted.If you selectmemory, Edge Client caches the user's password within the BIG-IP Edge Client application for automatic reconnection purposes.If you selectmemory, thePassword Cache Expiration (minutes)field displays with a default value of 240.
- If thePassword Cache Expiration (minutes)field displays, retain the default value or type the number of minutes to save the password in memory.
- To enable automatic download and update of client packages, from theComponent Updatelist, selectyes(default).If you selectyes, APM updates Edge Client software automatically on the client system when newer versions are available. This option applies to updates for these components only: BIG-IP Edge Client, component installer service, DNS relay proxy service, and user logon credentials access service.
- Beginning BIG-IP version 16.0.0, connectivity profile has optionalOAuth Settingsthat Edge Client will use for authenticating Native Apps using OpenID Connect specification. When OAuth is configured, the end-users are required to authenticate via the OAuth authentication flow. This OIDC support provides consistent authentication experience by enabling two-factor verification and Single Sign-On across Browser and Edge Client.For security reasons, when configuring for OAuth settings, ensure that the BIG-IP local traffic policy enforces HTTPS by redirecting HTTP requests to HTTPS for a virtual server on the BIG-IP system. Refer OIDC RFC for details on OAuth 2.0 Authorization Framework.
- From the left pane of the popup screen, selectOAuth Settings.
- Select the OAuth provider in theProviderlist. If you selectNone, OAuth configuration is disabled.
- Specify the OAuth Client ID identifier in theClient IDfield. The client identifier is not a secret and is exposed by the BIG-IP APM virtual server. OAuth configuration is disabled if client ID is not specified.
- Specify the OAuth client secret in theClient Secret (Public)field. The authorization server defines this string. All printable ASCII characters from 0x20 to 0x7E are allowed.
- Specify the scopes that will be requested by the client in theScopesfield. The value of the scope parameter is expressed as a list of space-delimited, case-sensitive strings defined by the authorization server. When using multiple strings, the order does not matter. All printable ASCII characters are allowed excluding quote (") and backslash (\).
- In theComplete Redirection URIfield, enter the optional URI for OAuth client to be directed to when authentication completes or fails. The default APM page is used if this URI is not specified. The URI should start with "https://", "http://" or "/".
Refer sectionConfiguring policies for OAuth client and resource serverin theBIG-IP Access Policy Manager: OAuth Concepts and Configurationfor details on adding an OAuth Resource Server to the access policy. - Specify the list of APM servers to provide when the client connects.The servers you add here display as connection options in the BIG-IP Edge Client.Users can select from these servers or they can type a hostname.
- From the left pane of the popup screen, selectServer List.A table displays in the right pane.
- ClickAdd.A table row becomes available for update.
- You must type a host name in theHost Namefield.Typing an alias in theAliasfield is optional.
- ClickUpdate.The new row is added at the top of the table.
- Continue to add servers, and when you are done, clickOK.
- Specify DNS suffixes that are in the local network.Providing a list of DNS suffixes for the download package enables Edge Client to support the autoconnect option. WithAuto-Connectselected, Edge Client uses the DNS suffixes to automatically connect when a client is not on the local network (not on the list) and automatically disconnect when the client is on the local network.DNS suffixes specified here are considered local network suffixes and conform to the rules specified for the local network. The BIG-IP Edge Client uses these suffixes when the user clicks the Auto-Connect option. The administrator configured DNS suffixes are compared with the DNS suffixes present on the system to detect the network access connection. When the BIG-IP Edge Client detects that it is on one of the specified internal networks, the client is idle and does not connect. When the BIG-IP Edge Client detects the network as a remote, the client attempts to establish a Network Access VPN connection.
- From the left pane of the popup screen, selectLocation DNS List.Location DNS list information is displayed in the right pane.
- ClickAdd.An update row becomes available.
- Type a name and clickUpdate.Type a DNS suffix that conforms to the rules specified for the local network.The new row displays at the top of the table.
- Continue to add DNS names and when you are done, clickOK.
- ClickOK.The popup screen closes, and the Connectivity Profile List displays.
Customizing a downloadable client package for Mac
Customize a Mac client package for a connectivity profile to specify whether to
launch BIG-IP
Edge Client after a user logs in to the Mac.
- Select a connectivity profile.
- Click the arrow on theCustomize Packagebutton and selectMac.The Customize Mac Client Package screen displays.
- Retain the selection or clear theAuto launch BIG-IP Edge Client after User Log Incheck box.
- Click Download.The customized package,BIGIPMacEdgeClient.zip, is downloaded to your client. It is available for you to distribute.
If you plan to distribute Mac client packages to your users and you customize
multiple Mac client packages (for different connectivity profiles), you need to rename
or otherwise organize the packages. Otherwise, your download location contains packages
named
BIGIPMacEdgeClient.zip(1)
, and so on.Downloading the ZIP file for Edge Client for Mac
You can download a Mac Client package and distribute it to clients.
- ClickDownload.The screen closes and the package,BIGIPMacEdgeClient.zip, downloads.
The ZIP file includes a Mac installer package (PKG) file and configuration settings.
Specifying applications to start on a Mac
The launch application feature specifies a client application that starts when the
client begins a Network Access session. You can use this feature when you have remote
clients who routinely use Network Access to connect to an application server, such as a
mail server.
- On the Main tab, click.The Network Access Lists screen opens.
- In the Name column, click the name of the network access resource you want to edit.
- To configure applications to start for clients that establish a Network Access connection with this resource, clickLaunch Applicationson the menu bar.
- ClickAddto add an application list.
- In theApplication Pathfield, typeopen.
- In theParametersfield, type a parameter.For example, type-a/Applications/ie.app http://www.f5.com.
- From theOperating Systemlist, selectMac.
- ClickFinishedto add the configuration.
Now when remote users with assigned resources make a Network Access connection, the
application you configured starts automatically.
Editing the log level for Edge Client on Mac
You can edit log settings in the configuration file on Mac systems.
- In the~/Library/F5Networksdirectory, open thef5networks.conffile.
- Edit the settings to change the log level.For debugging purposes, set the values to 48.
About connection options on Edge Client for Mac
With Edge Client's enhanced user interface, the client minimizes to the
status menu on the right end of the menu bar. You can quickly access connection options by
clicking on the Edge Client icon.
User interface on a Mac
![Screenshot Edge Client for Mac](/content/dam/projects/techdocs/edge-client-7-2-3/bigip/images/edge_client_connected_on_login.png/_jcr_content/renditions/original)
BIG-IP Edge Client for Mac icon menu has the following settings.
- Turn VPN On
- Starts and maintains a secure access connection at all times, regardless of the network location. This setting is disabled in an Always connected mode.
- Turn VPN Off
- Temporarily disconnects from the VPN without logging the user out. The login session remains active and allows a user to establish a VPN without the need for re-authentication by clickingTurn VPN On. This setting is disabled in an Always connected mode.
- Manage VPN Servers
- Allows a user to add, edit, and delete servers. BIG-IP Edge Client populates a list of all the servers available for users’ connections. Users can select from these servers, or they can add a server by typing its name and address.
- Preferences
- Allows a user to customize different settings such as notifications, auto-connect, and showing a welcome or splash screen when starting Edge Client.
- Notifications
- Displays alert about an error, pending authentication or an auto-update. This option is accessed from the Preferences screen and is enabled by default. Alert appears in the top-right corner of the screen and the Notifications pane, accessed by clicking the Notification Center icon.
- Auto-Connect
- Starts a secure access connection as needed. This option is accessed from the Preferences screen and is disabled by default. A user can enable Auto-Connect when the administrator has configured the Network Location Awareness feature.When the computer is on an enterprise network, the client disconnects and remains active in the status menu. In this case, the Edge Client icon menu displays the messageIn Enterprise Network, and theTurn VPN Onoption is not available. When the computer moves outside the enterprise network, the login session remains active, and the VPN connection establishes automatically without the need for re-authentication. Authentication is required only when a new session is created.
- View Details
- Allows a user to view details of the VPN connection, DNS Configuration, Routing Table, IP Configuration, and other settings.
- Quit BIG-IP Edge Client
- Disconnects the VPN, logs out the user, and exits the application. This setting not available in an Always connected mode.
User Interface when OAuth is configured
Edge Client for macOS supports authentication of Native Apps using OpenID
the OAuth authentication flow. The Edge Client User Interface displays the VPN status while the
OAuth authentication is in progress.
User interface on a Mac when OAuth is in progress
![Screenshot Edge Client for Mac when OAuth is progress](/content/dam/projects/techdocs/edge-client-7-2-3/bigip/images/edge-client-status-while-oauth-in-progress1.png/_jcr_content/renditions/original)
BIG-IP Edge Client for Mac icon menu has the following additional settings
in an OAuth flow:
- Cancel Authentication
- Allows a user to cancel authentication manually if OAuth 2.0 is configured, and the user authentication using the OAuth flow is in progress.
- Retry Authentication
- Allows the user to retry authentication manually if the browser window has accidentally closed before the user is authenticated using the OAuth 2.0 flow.
- VPN: Waiting for authentication in browser...
- Indicates that the user authentication using the OAuth 2.0 flow is in progress.
Overview: Always
connected mode for macOS
BIG-IP Edge Client provides Always Connected mode for macOS. This feature
allows you to specify that the client is always connected to the VPN, and allows you to configure
exclusion addresses to grant connectivity when the VPN is not connected. The FWCTL service in
always connected mode manages the connectivity. To configure and install Always Connected mode
for macOS, you must create a config file for the exclusion list and prepare the Edge Client
installation package for macOS.
About FWCTL service and exclusion list
macOS has a network Packet Filter (PF) firewall that is installed and
disabled by default. FWCTL is the PF Firewall management service for macOS that is bundled and
installed along with Edge Client installation. When the VPN is disconnected, the firewall becomes
active, and the FWCTL service ensures that the user can only access the list of addresses in the
whitelist. The FWCTL service is configured when the Edge Client installation package
is customized for download
for macOS. - Default firewall rules
- The following default firewall rules are applied when the firewall is enabled. A static exclusion rule overrides these default rules.
- Allow all incoming traffic
- Block all outgoing traffic
- Allow all traffic on the loopback interface
- Allow all UDP traffic on port 68 for DHCP protocol
- Allow all UDP and TCP traffic on port 53 for DNS protocol
- Allow all traffic to captive portal probe destination configured on the system
- APM virtual destinations are excluded
- Static Exclusion List
- The static exclusion list is an XML file in which you specify the destination hosts. All traffic is allowed to the destinations you add to the exclusion list. The config file must be namedf5fwctl.xmland placed in the/Library/Application Support/F5Networks/directory. The exclusion list supports the following data format.
- IPv4 or IPv6 address (preferred)
- Hostname
- HTTP or HTTPS URL
- Port number may be included to the hostname, IP address and HTTP or HTTPS URL separated by ':' (colon)
- An example entry is:
- <ITEM>vpn.example.com</ITEM>
- <ITEM>10.1.1.1</ITEM>
- <ITEM>http://www.mydomain.com</ITEM>
- When an IP address, Hostname or URL is specified, complete access to the endpoint is given, and requests can be sent to multiple ports on the server with the same IP address, whereas when a port is specified, access is given to only to that particular port.Static exclusion list does not support subnet mask or network address.
- Configured firewall settings
- The following settings are configured to enable and disable the firewall rules.
- Enable firewall when VPN is disconnected
- Disable firewall when VPN is connected
- Disable firewall when inside a corporate network
- When firewall is enabled, only the FWCTL firewall rules are in effect. The static exclusion rule overrides the default firewall rules. Use<FLUSH_RULES>false</FLUSH_RULES>in thef5fwctl.xmlfile to keep the connection alive. This option is TRUE by default.
- When firewall is disabled, the default firewall rules remain in effect.
- Periodic re-evaluation of static exclusion list
- The FWCTL service does a periodic re-evaluation of the static exclusion and APM server host lists, and updates the firewall rules in the following cases.
- changes in the static exclusion list
- changes in the APM server configuration file
- network change event
The FWCTL service caches IP addresses for re-evaluation of exclusion and APM server host lists for the period of DNS TTL (time-to-live) or Maximum TTL - whichever is smaller. By default, maximum TTL is 30 minutes. The cache expires when the DNS server is changed. When the cache expires, the FWCTL service resolves IP addresses and updates the firewall rules if there is any change. When an IP address cannot be resolved, the FWCTL service builds the firewall rules using previously resolved addresses (if any). The FWCTL service retries unresolved hosts in a 15 seconds interval. The DNS TTL can be configured in theWhen the IP address list is unchanged, the FWCTL service does not update the firewall rule.f5fwctl.xmlfile.
Network Location Awareness based on DNS Suffixes
The following options used for
DISCONNECTED_VPN_TRAFFIC_OPTION
in the Edge Client configuration file
decide the behavior of the firewall when the VPN is not connected.Disconnected VPN Traffic Option |
Behavior |
Description |
0 |
Block |
Enable firewall irrespective of whether the user is in an
enterprise or non-enterprise LAN. Any connectivity will be blocked until the
user establishes VPN. |
1 |
Allow |
The firewall is not installed. The user can connect to the
external networks even when VPN is not established. |
2 |
AllowInLan |
Disable firewall only in an enterprise LAN. The user can
connect to external networks in an enterprise LAN which is determined by the
NLA configuration. If the user is not in enterprise LAN and if VPN is not
established, the firewall will remain active. |
Any other value |
Block |
If any other value is set, it is ignored and will default
to 0, blocking any connectivity until the user establishes VPN. |
No value set |
Block |
If no value is set, it will default to 0, blocking any
Option missing |
Block |
If this option is missing, it will default to 0, blocking
About Edge Client Profile Options
The NLA feature is enabled when the option
is set to
2
(Allow in Enterprise LAN) in the Edge Client configuration file. The
firewall reads the configured DNS suffixes and performs NLA on the matching suffixes. When
suffixes match, the network is detected as a corporate network and the firewall rules are
disabled, thereby allowing all traffic. The NLA service only runs at startup or when a network
connection changes.Edge Client profile with DNS suffixes for Always Connected NLA
The following is a sample Edge Client profile with DNS suffixes:
<?xml version="1.0" encoding="UTF-8"?> <PROFILE VERSION="2.0"> <ALWAYS_CONNECTED_MODE>YES</ALWAYS_CONNECTED_MODE> <DISCONNECTED_VPN_TRAFFIC_OPTION>3</DISCONNECTED_VPN_TRAFFIC_OPTION> <LOCATIONS> <CORPORATE> <DNSSUFFIX>domain1.com</DNSSUFFIX> </CORPORATE> <CORPORATE> <DNSSUFFIX>domain2.com</DNSSUFFIX> </CORPORATE> <CORPORATE> <DNSSUFFIX>*.domain2.com</DNSSUFFIX> </CORPORATE> </LOCATIONS> </PROFILE>
Creating a config file for FWCTL
Create an XML file for the FWCTL
service.
- Populate the exclusion list with an IP address, hostname, URL, FLUSH RULES and DNS TTL. Following is a sample config file:<?xml version="1.0" encoding="UTF-8"?> <CLIENT_CONFIGURATOR> <STONEWALL_EXCLUSIONS> <ITEM>vpn.example.com</ITEM> <ITEM>10.1.1.1</ITEM> <ITEM>http://www.mydomain.com</ITEM> </STONEWALL_EXCLUSIONS> <DNS_TTL>30</DNS_TTL> <FLUSH_RULES>false</FLUSH_RULES> </CLIENT_CONFIGURATOR>
- Name the config filef5fwctl.xml.
- Place the file in the/Library/Application Support/F5Networks/directory.
Installing Always
On Edge Client on macOS
To configure and install Always Connected mode for
- Install theAPM client.isoavailable from downloads.f5.com to the BIG-IP APM server.
- From the left pane of the popup screen, select.
- Add one or more DNS names for the Enterprise Network and clickOK.
- Clear theAuto launch BIG-IP Edge Client after User Log Incheck box.
- Extract the content of the zip file on a macOS system.
- Place the config filef5fwctl.xmlcreated for the exclusion list in the same location asmac_edgesvpn.pkgfile.
- Createopt-fwctl(an empty file - 'touch opt-fwctl'), and place it in the same locations asmac_edgesvpn.pkgfile.
- Double click the filemac_edgesvpn.pkgto install the Edge Client.
When Edge Client installation completed, the
FWCTL application and the related files and modules are downloaded to the
/Applications/BIG-IP Edge
Client.app/Contents/Resources
directory.Uninstalling Edge
Client in Always Connected mode
To uninstall Edge Client installed in Always
Connected mode, perform the following steps:
Dragging and
dropping the Edge Client application to the trash for uninstalling is not supported
in Always Connected mode.
- Open the terminal application as an administrative user.
- To start a privileged session, type thesudo-icommand.
- When prompted, enter your administrator password.
- To start the uninstallation script, type the following command:/Applications/BIG-IP\ Edge\ Client.app/Contents/Resources/uninstall.sh
When the uninstall of Edge Client completes,
the FWCTL application and all related files and modules are removed from the
system.
About Touch-ID support for macOS
BIG-IP Edge Client supports the use of Touch ID to log in for Touch ID
enabled macOS devices. Previously, for a returning user, when the
Save Password
was enabled, the login credentials
were auto-filled, giving unauthorized users access to resources on an unlocked device. The new
Touch ID support on macOS allows you to provide fingerprint as device authentication, thereby
preventing unauthorized users from getting VPN access. After the user scans the fingerprint, the
password is retrieved, and login credentials are auto-filled without requiring any user
interaction. For macOS devices that do not have Touch ID capability or that do not have
any fingerprints enrolled, the user experience is the same as before, with the password being
retrieved and credentials auto-filled when the user tries to log in.
The following conditions are required to use this feature:
- EnableAllow Password Cachingto Disk to cache the user's password.Click. From theSave Password Methodlist, selectdiskto cache the user's password (in encrypted form) securely on the disk.
- macOS Edge Client is running on a Touch ID compatible device with an enrolled fingerprint.
- The user has allowedSave Passwordon the logon page.
Using Touch-ID on macOS
When logging in for the first time, the user enters the password. These
credentials are then saved in the keychain. With the next login, a logon page displays an
auto-filled user name and prompts for fingerprint authentication. The user then scans the
fingerprint, auto-filling the password from the keychain.
When the touch ID is locked out after failed attempts, the system offers a
fallback option and requires the user to enter the device password. The user can choose the
Use Password
option at any time during authentication attempts. About OIDC Support in Edge Client for macOS
the OAuth authentication flow. The OAuth 2.0 Authorization Framework describes the method of
authorization and defines client, resource server, and identity provider roles. OpenID Connect is
built on top of OAuth 2.0 and complements the OAuth 2.0 Authorization framework.
The OIDC support provides consistent authentication experience by enabling two-factor
verification and Single Sign-On across Browser and Edge Client. It provides:
- Ability to use security keys (Yubikey) as an additional factor of authentication for Edge Client (For example, U2F).
- Ability to support password-less authentication through public key registration and authentication.
- Single Sign-On for Edge Client and other enterprise apps that share a common IDP.
OAuth Settings
using which administrators can
specify the OIDC authorization server discovery endpoint, Client ID, Scopes, and the Complete
Redirection URI. For security reasons, when configuring
The OAuth authorization flow for Native Apps using the browser is as follows:
- The Edge Client queries the authorization server details from BIG-IP and opens the browser tab with the authorization request.
- The authorization endpoint receives the authorization request, authenticates the user, and obtains authorization.
- The authorization server then issues an authorization code to the redirect URI.
- The Edge Client receives the authorization code and responds with HTTP 302 redirect URI to theComplete Redirection URIpage on the BIG-IP APM or external web server.
- The browser issues a request to theComplete Redirection URIpage and receives a response from the BIG-IP APM or external web server.
- The Edge Client presents the authorization code at the token endpoint, which validates the authorization code and issues the tokens requested.
- The Edge Client provides a token in the session authorization request to BIG-IP APM.
- The BIG-IP system allows or denies access to the APM session.
When the Edge Client opens the browser for OAuth 2.0 authentication, the client displays the
status as
browser..
, indicating that the browser has been opened for the authentication, and the
Edge Client is waiting for the authorization code. In case of an error, a window with a BIG-IP
logout page and an error message are displayed.About Network Access features for Mac clients
Access Policy Manager (APM) supports all of the primary Network Access
features for Mac clients, except for Drive Mappings and some endpoint security features.
For endpoint security support, refer to
BIG-IP
APM Client Compatibility Matrix
on AskF5 at http://support.f5.com/
. For information about Network Access features, refer to
BIG-IP Access Policy Manager: Network Access
on AskF5 at
. VPN component installation and log locations on a Mac
On Macintosh operating systems, the client installs the VPN components and writes VPN
logs to the locations listed in the table.
VPN component |
Location |
Network Access plugin |
/Library/Internet Plugins/ |
Endpoint Security (client checks) |
~/Library/Internet Plugins/ |
VPN logs are written to the following directory:
~/Library/Logs/F5Networks
