Manual Chapter : System Settings
Applies To:
  • F5OS-A
    1.8.4-HR-1, 1.8.4
System Settings
You can access system settings in the webUI.
You can view active system alarms and events in the webUI and CLI.
The Alarms & Events screen lists alert information for system components (such as PSU, firmware, and LCD) that have currently crossed a performance or health threshold. Use this screen to identify the specific component that is affected.
  1. Log in to the webUI using an account with admin access.
  2. On the left, click SYSTEM SETTINGS > Alarm & Events.
  3. Choose from one of these actions:
    • To refresh the alarms or events list, click the Refresh icon on the right of the screen.
    • To display events result by time preference, click the down arrow next to the Refresh icon and select a value from the list. The default value is one hour. For example, select five minutes to display any event that occurred in the last five minutes.
    • To display events by severity, select a value from the Severity list. The default value is INFORMATIONAL.
      Option Description
      Emergency Emergency system panic messages
      Alert Serious errors that require administrator intervention
      Critical Critical errors, including hardware and file system failures
      Error Non-critical, but possibly important, error messages
      Warning Warning messages that should be logged and reviewed
      Notice Messages that contain useful information, but might be ignored
      Informational Messages that contain useful information, but might be ignored
      Debug Detailed messages used for troubleshooting
You can view information about active system alarm conditions from the CLI.
  1. Connect using SSH to the management IP address.
  2. Log in to the command line interface (CLI) of the system using an account with admin access.
    When you log in to the system, you are in user (operational) mode.
  3. View a list of active system alarm conditions.
    show system alarms | tab
    This example shows a power supply unit (PSU) redundancy fault:
    appliance-1# show system alarms | tab
    ID     RESOURCE        SEVERITY  TEXT                           TIME CREATED
    65793  psu-1           ERROR     PSU fault detected             2022-06-01-11:11:11.999825828 UTC
You can access management interface settings in the webUI.
You can view or change settings for the management interface from the webUI.
  2. On the left, click SYSTEM SETTINGS > Management Interface.
  3. For DHCP, select either Enabled or Disabled.
  4. Under IPv4 and IPv6, you can configure either one management IP address type or both types for the system:
    1. For IP Address, enter IP addresses in the appropriate sections for IPv4 or IPv6, or in both sections, if using both.
      The supported IPv4 format is, for example, 192.0.2.101. The supported IPv6 format is, for example, 2001:DB80:3238:DFE1:63::FEFB
    2. For Prefix Length, enter or select the prefix length.
      For Prefix Length, enter or select the prefix length. The prefix length values must be between 0 and 32 for IPv4 and between 0 and 128 for IPv6.
    3. For Gateway, enter the gateway IP address.
  5. Under Interface Settings, you can configure the management port:
    1. For State, select either Enabled or Disabled.
    2. For Auto-negotiation, select either Enabled or Disabled.
      If you enable auto-negotiation, port speed and duplex mode are set automatically.
    3. For Port Speed, select one of these options: SPEED_1GB, SPEED_10MB, or SPEED_100MB.
    4. For Duplex Mode, select FULL or HALF.
  6. Click Save.
You can configure the management interface from the CLI.
  1. Connect to the system using a management console or console server.
    Note: The default baud rate and serial port configuration is 19200/8-N-1.
  3. Change to config mode.
    config
    The CLI prompt changes to include (config).
  4. Enable and set general properties for the management interface.
    interfaces interface mgmt config { disabled | enabled } description <*interface-description*>
    In this example, you enable the management interface, add a description, and set the type:
    appliance-1(config)# interfaces interface mgmt config enabled description
      "Mgmt Interface"
  5. Exit to the top level of the configuration hierarchy.
    top
  6. Configure Ethernet properties for the management interface.
    interfaces interface mgmt config auto-negotiate { false | true } duplex-mode { FULL | HALF } port-speed { SPEED\_1GB | SPEED\_10MB | SPEED\_100MB }
    appliance-1(config)# interfaces interface mgmt config auto-negotiate true
      duplex-mode FULL port-speed SPEED_1GB
  7. Commit the configuration changes.
    commit
  8. Return to user (operational) mode.
    end
  9. Verify that the management interface is configured.
    show interfaces interface mgmt
    A summary similar to this example displays:
    appliance-1# show interfaces interface mgmt
     state name  mgmt
     state type  ethernetCsmacd
     state enabled true
     state oper-status UP
     ethernet state auto-negotiate true
     ethernet state duplex-mode FULL
     ethernet state port-speed SPEED_1GB
     ethernet state hw-mac-address 00:12:a1:34:56:78
     ethernet state negotiated-duplex-mode FULL
     ethernet state negotiated-port-speed SPEED_1GB
You can access settings for hardening the security of your system in the webUI.
An allow list enables you to specify either specific IPv4 or IPv6 addresses, ports, or a netmask as an accepted source that can access the system.
When the IP address is configured and saved to the system allow list, only traffic coming from that IP address and port is accepted by the system’s management interface. You can also edit or delete entries in the allow list after you have configured them.
You can configure the system allow list from the webUI. To edit an existing allow list entry, select the IP address that you want to edit. You cannot change the designated name, but you can change all other fields.
  2. On the left, click SYSTEM SETTINGS > System Security.
  3. In the Allowed IP Addresses area, click Add to add an IP address to the allow list.
  4. For Name, enter a descriptive name for the IP address.
  5. For IPv4/IPv6, select IPv4 or IPv6.
  6. For Address, enter the IP address to be added to the allow list.
  7. For Prefix Length, enter or select the prefix length.
    The prefix length values must be between 1 and 32 for IPv4 and between 1 and 128 for IPv6.
  8. For Port, select a port number for the IP address.
    Available options are:
    • ALL: Allow all traffic on this IP address.
    • 443 (HTTPS): Allow only HTTP with SSL traffic on this IP address.
    • 80 (HTTP): Allow only HTTP traffic on this IP address.
    • 8888 (RESTCONF): Allow only RESTCONF traffic on this IP address.
    • 161 (SNMP): Allow only SNMP traffic on this IP address.
    • 7001 (VCONSOLE): Allow only VCONSOLE traffic on this IP address.
    • 22 (SSH): Allow only SSH traffic on this IP address.
  9. Click Save & Close.
You can configure the system allow list from the CLI.
  1. Log in to the command line interface (CLI) of the system using an account with admin access.
  2. Change to config mode.
    config
  3. Configure the system to allow traffic only from specified IP addresses.
    system allowed-ips allowed-ip <*allowlist-profile-name*> config { ipv4 | ipv6 } address <*ip-address*> port <*port-number*> prefix-length <*subnet-prefix-length*>
    Important: This is applicable only for ports 161 (SNMP), 8888 (RESTCONF), 443 (HTTPS), 80 (HTTP), 7001 (VCONSOLE), and 22 (SSH).
    This example adds a specified IPv4 address to the system allow list:
    appliance-1(config)# system allowed-ips allowed-ip test config
      ipv4 address 192.0.2.33 port 161 prefix-length 32
    This example adds a netmask to the system allow list:
      ipv4 address 192.0.2.0 port 161 prefix-length 24
    This example restricts access to the management interface (SSH) to only the specified IP address:
      ipv4 address 192.0.2.33 port 22 prefix-length 32
  4. Commit the configuration changes.
    commit
You can run the system in appliance mode. Appliance mode adds a layer of security removing user access to Root and Bash. Enabling appliance mode disables all Root and Bash shell access for the system.
You can enable appliance mode at each of these levels:
  • System
  • Tenant
Appliance mode is disabled at all levels, by default. You can enable it from the webUI or the CLI. The appliance mode option for the system is available to users with admin access under SYSTEM SETTINGS > General in the webUI. For tenants, it is available in the webUI under TENANT MANAGEMENT > Tenant Deployments.
These are the effects of enabling appliance mode at each of the different levels.
System-level appliance mode
  • Root or Bash access is disabled on the system.
  • Console access: Root or Bash access is disabled on the system. Users can log in to the system CLI from the console using an admin account.
Tenant appliance mode
  • Root access to the tenant is disabled by all means. Bash access is disabled for users (with a terminal shell flag enabled) inside the tenant.
  • Users can access the tenant only through the webUI or the CLI.
  • Tenant console access: Users can log in to the CLI from the virtual console using an admin account (with a terminal shell flag enabled).
You can enable or disable appliance mode from the webUI. Enabling the appliance mode will disable all root and Bash shell access.
Note: The appliance mode option for tenants is available in the webUI under TENANT MANAGEMENT > Tenant Deployments.
  3. Under the Shell & LCD Access section, for the Appliance Mode area, select either Enabled or Disabled. By default Disabled will be selected.
    The default value is Disabled.
  4. Click Save.
You can configure appliance mode from the CLI if you want to disable all root and Bash shell access.
Note: For greater security, it is highly recommended that you configure the system to run in appliance mode.
Note: The appliance mode option for tenants is available in the CLI using the tenants tenant <*tenant-name*> config appliance-mode command sequence.
    config
  4. Enable appliance mode.
    system appliance-mode config [ disabled | enabled ]
    In this example, you enable appliance mode on the system controllers:
    appliance-1(config)# system appliance-mode config enabled
  5. Commit the configuration changes.
    commit
With appliance mode disabled, enabling the deny root SSH option will restrict the root user from accessing the appliance through SSH. However, root users can still be able to access the appliance system using the console. This provides a maintenance window for ‌system administrators without compromising on ‌system security through ‌SSH.
Note: All users excluding root users can access the appliance through SSH. If appliance mode is enabled, it overrides the deny root SSH option.
You can enable or disable root SSH from the webUI. Configuring deny root SSH to Enabled will disable the root SSH access but allows console root access.
  2. On the left navigation pane, click SYSTEM SETTINGS > System Security.
  3. In the Shell & LCD Access section, select either Enabled/Disabled from the Deny Root SSH field dropdown.
  4. Click Save.
You can configure deny root SSH mode from the CLI to disable the root SSH access. However, it allows console root access.
    config
  4. Disable appliance mode.
    In this example, you disable appliance mode on the system controllers:
    appliance-1(config)# system appliance-mode config disabled
  5. Enable deny root SSH mode.
    system security deny-root-ssh config [ disabled | enabled ]
    In this example, you enable deny SSH mode on the system controllers:
    appliance-1(config)# system security deny-root-ssh config enabled
  6. Commit the configuration changes.
    commit
The LCD touchscreen enables you to view system status and manage the system without attaching a console or network cable. You can configure the LCD to meet security requirements by changing to a more restrictive operational mode.
The LCD touchscreen supports these modes:
Allows access to all options.
Allows access only to management and setup options. A padlock icon displays next to limited options.
Does not allow access to any options and displays only an image to indicate that the LCD touchscreen is disabled.
You can configure the operational mode of the touchscreen LCD from the webUI.
  3. In the LCD area, for Mode, select one of these options:
    • Select Disabled to not allow access to any options; displays only an image to indicate that the LCD touchscreen is disabled.
    • Select Secure to allow access only to management and setup options; displays a padlock icon next to limited options.
    • Select Standard to allow access to all options.
  4. Click Save.
Cryptographic agility on F5 rSeries systems enables you to replace cryptographic implementations for the httpd and sshd services. This applies to the F5OS management interface.
You can configure the cryptographic implementations on the system for the httpd and sshd services from the webUI.
  3. In the Services area, for httpd Cipher Suites, enter the SSL cipher suites used for the httpd service.
    You can specify more than one cipher suite by separating the cipher suite names with a colon.
  4. For sshd Ciphers, enter the ciphers to use for the sshd service.
    For example, aes128-cbc or aes128-ctr. The cipher string can take several additional forms. It can consist of a single cipher suite or a list of cipher suites containing a certain algorithm, or cipher suites of a certain type. You can combine lists of cipher suites into a single cipher string by enclosing them in square brackets and delimiting them with a space.
  5. For sshd KEX Algorithms, enter the key exchange algorithms used for the sshd service.
    For example, diffie-hellman-group14-sha1 or diffie-hellman-group14-sha256. You can combine lists of KEX algorithms into a single string by enclosing them in square brackets and delimiting them with a space.
  6. For sshd MAC Algorithms, enter the MAC algorithms used for the sshd service.
    For example, hmac-sha2-512 or AEAD_AES_128_GCM. You can combine lists of MAC algorithms into a single string by enclosing them in square brackets and delimiting them with a space.
  7. For sshd Host Key Algorithms, enter the host key algorithms used for the sshd service.
    The following secure host key algorithms are supported when system is in non-FIPS mode and these are non-configurable:
    S.No Host key algorithms
    1 rsa-sha2-512
    2 rsa-sha2-256
    3 ecdsa-sha2-nistp256
    4 ssh-ed25519
    5 ssh-rsa
    Note: By default, the ssh-rsa host key algorithm is disabled. However, it can be enabled during ‌system setup if necessary.
  8. Click Save.
You can show the current crypto configuration on the system from the CLI.
  3. Show the current configuration.
    show system security services service state
    appliance-1# show system security services service state
    system security services service httpd
     state ssl-ciphersuite ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:
     ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:
     DHE-DSS-AES256-GCM-SHA384:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA256:DHE-RSA-AES256-SHA:DHE-DSS-AES256-SHA:DHE-RSA-CAMELLIA256-SHA:DHE-DSS-CAMELLIA256-SHA:ECDH-RSA-AES256-GCM-SHA384:ECDH-ECDSA-AES256-GCM-SHA384:ECDH-RSA-AES256-SHA384:ECDH-ECDSA-AES256-SHA384:ECDH-RSA-AES256-SHA:ECDH-ECDSA-AES256-SHA:AES256-GCM-SHA384:AES256-SHA256:AES256-SHA:CAMELLIA256-SHA:PSK-AES256-CBC-SHA:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:DHE-DSS-AES128-GCM-SHA256:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES128-SHA256:DHE-DSS-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA:DHE-RSA-CAMELLIA128-SHA:DHE-DSS-CAMELLIA128-SHA:ECDH-RSA-AES128-GCM-SHA256:ECDH-ECDSA-AES128-GCM-SHA256:ECDH-RSA-AES128-SHA256:ECDH-ECDSA-AES128-SHA256:ECDH-RSA-AES128-SHA:ECDH-ECDSA-AES128-SHA:AES128-GCM-SHA256:AES128-SHA256:AES128-SHA:CAMELLIA128-SHA:PSK-AES128-CBC-SHA
    system security services service sshd
     state ciphers [ aes128-cbc aes128-ctr aes128-gcm@openssh.com aes256-cbc aes256-ctr
      aes256-gcm@openssh.com ]
     state kexalgorithms [ diffie-hellman-group14-sha1 diffie-hellman-group14-sha256
     diffie-hellman-group16-sha512 ecdh-sha2-nistp256 ecdh-sha2-nistp384 ecdh-sha2-nistp521 ]
    state ssl-ciphersuite ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-DSS-AES256-GCM-SHA384:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA256:DHE-RSA-AES256-SHA:DHE-DSS-AES256-SHA:DHE-RSA-CAMELLIA256-SHA:DHE-DSS-CAMELLIA256-SHA:ECDH-RSA-AES256-GCM-SHA384:ECDH-ECDSA-AES256-GCM-SHA384:ECDH-RSA-AES256-SHA384:ECDH-ECDSA-AES256-SHA384:ECDH-RSA-AES256-SHA:ECDH-ECDSA-AES256-SHA:AES256-GCM-SHA384:AES256-SHA256:AES256-SHA:CAMELLIA256-SHA:PSK-AES256-CBC-SHA:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:DHE-DSS-AES128-GCM-SHA256:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES128-SHA256:DHE-DSS-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA:DHE-RSA-CAMELLIA128-SHA:DHE-DSS-CAMELLIA128-SHA:ECDH-RSA-AES128-GCM-SHA256:ECDH-ECDSA-AES128-GCM-SHA256:ECDH-RSA-AES128-SHA256:ECDH-ECDSA-AES128-SHA256:ECDH-RSA-AES128-SHA:ECDH-ECDSA-AES128-SHA:AES128-GCM-SHA256:AES128-SHA256:AES128-SHA:CAMELLIA128-SHA:PSK-AES128-CBC-SHA
    state ciphers       [ aes128-cbc aes128-ctr aes128-gcm@openssh.com aes256-cbc aes256-ctr aes256-gcm@openssh.com ]
    state kexalgorithms [ diffie-hellman-group14-sha1 diffie-hellman-group14-sha256 diffie-hellman-group16-sha512 ecdh-sha2-nistp256 ecdh-sha2-nistp384 ecdh-sha2-nistp521 ]
    state host-key-algorithms [ ecdsa-sha2-nistp256 rsa-sha2-256 rsa-sha2-512 ssh-ed25519 ssh-rsa ]
You can configure the sshd service from the CLI.
    config
  4. Configure the sshd service.
    system security services service sshd config ciphers [ <*string*> ] kexalgorithms [ <*string*> ] macs [ <*string*> host-key-algorithm [ <*string*> ]
    These are the available configuration options:
    Option
    Description
    ciphers
    User-specified ciphers. For example, aes128-cbc or aes128-ctr. The cipher string can take several additional forms. It can consist of a single cipher suite or a list of cipher suites containing a certain algorithm, or cipher suites of a certain type. You can combine lists of cipher suites into a single cipher string using the + character as a logical AND operation.
    kexalgorithms
    User-specified key exchange algorithms. For example, diffie-hellman-group14-sha1 or diffie-hellman-group14-sha256. You can combine lists of KEX algorithms into a single string using the + character as a logical AND operation.
    macs
    User-specified MAC algorithms. For example, hmac-sha2-512 or AEAD_AES_128_GCM. You can combine lists of MAC algorithms into a single string using the + character as a logical AND operation.
    host-key-algorithms
    User-specified host key algorithms. For example, ecdsa-sha2-nistp256 rsa-sha2-256 rsa-sha2-512 ssh-ed25519 ssh-rsa.
    This example shows configuring the sshd service:
    appliance-1(config)# system security services service ssh config ciphers [ aes128-ctr aes256-cbc ]
      kexalgorithms [ ecdh-sha2-nistp521 echd-sha2-nistp384 ] macs [ hmac-sha1 ] host-key-algorithm [ ecdsa-sha2-nistp256 rsa-sha2-256 rsa-sha2-512 ssh-ed25519 ssh-rsa]
    commit
After you commit the change, you are prompted to confirm the change. The service will then restart.
You can configure the SSL cipher suites used for the httpd service from the CLI.
    config
  4. Configure one or more cipher suites for the httpd service.
    system security services service httpd config ssl-ciphersuite <*string*>
    In this example, you indicate that the system uses only the specified cipher suite:
    appliance-1(config)# system security services service httpd config
    In this example, you specify more than one cipher suite by separating the cipher suite names with a colon:
      ssl-ciphersuite ECDHE-RSA-AES128-SHA:ECDHE-RSA-AES256-SHA
    commit
When you configure ciphers for httpd, you can use multiple formats. You can specify a single cipher suite, such as RC4-SHA. You can also represent a list of cipher suites containing a certain algorithm or cipher suites of a certain type using a shortened name. For example, SHA1 represents all cipher suites using the digest algorithm SHA1, and SSLv3 represents all SSLv3 algorithms. You can combine lists of cipher suites into a single cipher string using the + character as a logical AND operation. For example, SHA1+DES represents all cipher suites containing the SHA1 and DES algorithms.
These are the allowed SSL cipher suites for general appliances:
  • ECDHE-RSA-AES256-GCM-SHA384
  • ECDHE-ECDSA-AES256-GCM-SHA384
  • ECDHE-RSA-AES256-SHA384
  • ECDHE-ECDSA-AES256-SHA384
  • DHE-DSS-AES256-GCM-SHA384
  • DHE-RSA-AES256-GCM-SHA384
  • DHE-RSA-AES256-SHA256
  • DHE-DSS-AES256-SHA256
  • DHE-RSA-CAMELLIA256-SHA
  • DHE-DSS-CAMELLIA256-SHA
  • ECDH-RSA-AES256-GCM-SHA384
  • ECDH-ECDSA-AES256-GCM-SHA384
  • ECDH-RSA-AES256-SHA384
  • ECDH-ECDSA-AES256-SHA384
  • AES256-GCM-SHA384
  • AES256-SHA256
  • AES256-SHA
  • CAMELLIA256-SHA
  • PSK-AES256-CBC-SHA
  • ECDHE-RSA-AES128-GCM-SHA256
  • ECDHE-ECDSA-AES128-GCM-SHA256
  • ECDHE-RSA-AES128-SHA256
  • ECDHE-ECDSA-AES128-SHA256
  • DHE-DSS-AES128-GCM-SHA256
  • DHE-RSA-AES128-GCM-SHA256
  • DHE-RSA-AES128-SHA256
  • DHE-DSS-AES128-SHA256
  • DHE-RSA-CAMELLIA128-SHA
  • DHE-DSS-CAMELLIA128-SHA
  • ECDH-RSA-AES128-GCM-SHA256
  • ECDH-ECDSA-AES128-GCM-SHA256
  • ECDH-RSA-AES128-SHA256
  • ECDH-ECDSA-AES128-SHA256
  • AES128-GCM-SHA256
  • AES128-SHA256
  • AES128-SHA
  • CAMELLIA128-SHA
  • PSK-AES128-CBC-SHA
These are the allowed SSL cipher suites for systems that have a FIPS software license applied. It does not apply to the F5 r5900-DF or r10900-DF platforms that have an embedded FIPS hardware security module (HSM).
When you configure ciphers for sshd, you enclose the cipher string in square brackets and include more than one by separating them with a space. These ciphers are allowed on the system.
  • ecdh-sha2-nistp256
  • ecdh-sha2-nistp384
  • ecdh-sha2-nistp521
  • diffie-hellman-group16-sha512
  • diffie-hellman-group14-sha256
  • diffie-hellman-group14-sha1
For security purposes, you can configure how long management sessions can remain idle before you are logged out of the system. If you are connected using an SSH connection, the system closes the SSH connection after this time expires.
You can configure how long management sessions can remain idle before you are logged out of the system from the webUI. If you are connected using an SSH connection, the system closes the SSH connection after this time expires.
  3. In the Services area, for CLI Idle Timeout, enter a time, in seconds, for how long management sessions can remain idle before they time out.
    A value of 0 (zero) sets the time to infinity, so the user is never logged out. The timeout can be a value from 0 through 4294967 seconds. The default value is 1800 seconds (30 minutes).
  4. Click Save.
You can configure how long management sessions can remain idle before you are logged out of the system from the CLI. If you are connected using an SSH connection, the system closes the SSH connection after this time expires. You can also configure how long the system is inactive for a root user connected to the system or via SSH or console before the user is logged out of the system.
    config
  3. Configure the CLI session idle timeout setting for an admin user connected to the system.
    system settings config idle-timeout <*time-in-seconds*>
    This example sets an idle timeout of 3600 seconds (one hour):
    appliance-1(config)# system settings config idle-timeout 3600
  4. Configure the CLI session idle timeout setting for an admin or a root user connected via either SSH or console.
    system settings config sshd-idle-timeout <*time-in-seconds*>
    A value of 0 (zero) sets the time to infinity, so the user is never logged out. The timeout can be a value from 0 through 8192 seconds. The default value is 0 (zero).
    This example sets an SSH system idle timeout of 3600 seconds (one hour):
    appliance-1(config)# system settings config sshd-idle-timeout 3600
    commit
The Software Management screen on the webUI includes options for uploading, importing and updating Base OS software for the system. It also displays information about the images imports, cluster and firmware install status.
You can manage software images from the webUI.
  2. On the left, click SYSTEM SETTINGS > Software Management.
  3. To import a Base OS image:
    1. Click Import.
      A popup opens.
    2. For URL, enter the URL of the remote image server.
      F5 recommends that the remote host be an HTTPS server with PUT/POST enabled and have a valid CA-signed certificate. You can opt to select the Ignore Certificate Warnings check box if you want to skip the certificate check.
    3. For Username, type the user name for an account on the remote image server, if required.
    4. For Password, type the password for the account, if required.
    5. Select Ignore Certificate Warnings to skip the certificate check.
    6. Click Add Image.
    Note:
    • Depending on the image file size and network availability, the import might take a few minutes. You can view progress of the file transfer under the Image Transfer Status area. When the import is successful, the software image is listed in the webUI.
    • If you want to cancel an in-progress file transfer operation, click Cancel button.
  4. To upload a Base OS image that you have downloaded to your local workstation:
    1. Click Upload.
    2. Navigate to the image file and select it.
    3. Click Open.
  5. To delete a Base OS image, select the image and click Delete.
    Software images that are in use cannot be deleted.
You can view the following information
  • View the status of image imports under Image Transfer Status, which shows information about Remote Host, File, Status, and Time.
  • Status of Cluster upgrade under Cluster Install Status, which include Stage, Status, Timestamp, Version and Description.  Click Show to display the information.
  • Status of Firmware upgrade under Firmware Install Status, which include Name, Installed Version, Desired Version, Configurable state, Update Status, and Restart Required.  Click Show to display the information.
Before you begin, you must also have added or uploaded an updated software image before you can do the update.
You can update Base OS software while the system is up and running from the webUI.
Important: During a software update, there is an interruption to traffic, so F5 recommends that you perform the update during a maintenance window
  3. In the Update Base OS Software section, for Update Software:
    • To install a full F5OS-A version release, select Bundled.
    • To install F5OS-A and service version releases independently, select Unbundled.
  4. For ISO Image, select the full version release ISO image from the drop-down.
    This field is available when Bundled is selected.
  5. For Base OS Version, select the F5OS version from the drop-down.
    This field is available when Unbundled is selected.
  6. For Service Version, select the service version release from the drop-down.
You can install independent system or service packages on the system from the CLI.
    config
  3. Verify the version compatibility of a package on the system.
    system packages package <*package-name*> check-version version <*version*>
    This example checks the version compatibility of a package:
    appliance-1(config)# system packages package optics-mgr-independent-pkg
      check-version version 4.0.0.2022_08_02_16_17_05.s3a9dffb4
    response Compatibility verification succeeded.
  4. Install a new version of a package.
    system packages package <*package-name*> set-version version <*version*> proceed { no | yes }
    This example sets a new version of a package:
      set-version version 4.0.0.2022_08_02_16_17_05.s3a9dffb4 proceed
    Possible completions:
      no  yes
    commit
You can remove independent system or service packages from the system from the CLI.
    config
  3. Remove an independent package from the system.
    system packages package <*package-name*> remove version <*version*>
    This example removes a specified package version:
      remove version 4.0.0.2022_08_02_16_17_05.s3a9dffb4
    commit
You can view the system software install data, which include os version, service version, cluster and firmware version from the CLI.
  2. Display the system software upgrade status:
    show system install
    A summary to this example displays:
    appliance-1# show system install
                                                SERVICE     INSTALL       NODE                          INSTALLED       DESIRED                         UPDATE    RESTART
    NODE        OS VERSION      VERSION         STATUS      STATUS        NAME                          VERSION         VERSION         CONFIGURABLE    STATUS    REQUIRED
    platform    1.8.0-10876     1.8.0-10876     successful  Complete    fw-version-bios-me              2.02.145.1      2.02.145.1         false        none        -
        fw-version-bios-me              4.4.4.603       4.4.4.603          false        none        -
        fw-version-cpld                 02.0B.00         02.0B.00          false        none        -
        fw-version-drive-u.2.slot1      VDV10184         VDV10184          false        none        -
        fw-version-drive-u.2.slot2      VDV10184         VDV10184          false        none        -
        fw-version-lcd-app              1.01.069.00.1    1.01.069.00.1     false        none        -
        fw-version-lcd-bootloader       1.01.027.00.1    1.01.027.00.1     false        none        -
        fw-version-lcd-ui               1.13.12          1.13.12           false        none        -
        fw-version-lop-app              2.00.357.0.1     2.00.357.0.1      false        none        -
        fw-version-lop-bootloader       1.02.062.0.1     1.02.062.0.1      false        none        -
        fw-version-sirr                 1.1.72               1.1.72        false        none        -
    NODE      STAGE                       STATUS  TIMESTAMP                  VERSION               DESCRIPTION
    platform  FlannelInstall             done     2024-05-29 08:59:22+00:00  0.13.1                 Flannel installation/verification is successful
                    MultusInstall        done     2024-05-29 08:59:45+00:00  3.7.0                   Multus installation/verification is successful
                    KubevirtInstall      done     2024-05-29 09:00:29+00:00   2.9.0                 Kubevirt installation/verification is successful
                    K3SClusterInstall    done     2024-05-29 08:58:48+00:00  1.21.1.1.11.6          K3s installation/verification is successful
                    K3SClusterUpgrade    done     Not Available                Not Available        K3s upgrade not required
                    clusterDeployment    done     2024-05-29 09:00:56+00:00   Not-Applicable     Cluster deployment is successful
The DNS screen on the webUI includes options for configuring Domain Name System (DNS) lookup servers and search domains for use with the system.
You can configure DNS for the system from the webUI. This is used for name resolution such as when setting up the system.
  2. On the left, click SYSTEM SETTINGS > DNS.
  3. Under DNS Lookup Servers, specify the name servers that the system uses to validate DNS lookups, and resolve host names. For each name server you want to add:
    1. Click Add.
    2. For Lookup Server, enter the IP address of the name server that you want to add to the list.
    3. Click Save & Close.
  4. Under DNS Search Domains, specify the domains that the system searches for local domain lookups and to resolve local host names. For each domain you want to add:
    1. Click Add.
    2. For Search Domain, enter the domain name of the name server that you want to add to the list.
      For example, DNSsearch.com.
DNS lookup servers and search domains are now specified for the system.
You can configure DNS for the system from the CLI. This is used for name resolution such as when setting up the system.
    config
  4. Configure a DNS lookup server.
    system dns servers server <*ip-address*> port <*port*>
    This example configures a DNS server at 192.0.2.20:
    appliance-1(config)# system dns servers server 192.0.2.20
    commit
The webUI includes options for configuring remote log servers and the log severity level for individual software components and services.
From the webUIwebUIs you can generate a system report, or QKView file, to collect configuration and diagnostic information from the rSeries system if you have any concerns about your system operation. The QKView file contains machine-readable (JSON) diagnostic data and combines the data into a single compressed tar.gz format file. You can upload the QKView file to F5 iHealth where you can get help to verify proper operation of the system and get help with troubleshooting and understanding any issues you might be having and ensure that the system is operating at its maximum efficiency.
You can view event logs and configure secure remote logging from the CLI. You can also send host log files, which are in the /var/log directory, as well as audit.log files to the remote server from the CLI.
You can add and display information about configured remote log servers from the webUI. You can also change the log severity level for individual software components and services.
  2. On the left, click SYSTEM SETTINGS > Log Settings.
  3. To include hostname configured for your system in the logs, select True from the Include Hostname field dropdown.
    Note: By default, the Include Hostname dropdown value is set to true.
  4. To add access to a Remote Log Server, click Add.
    1. In the Server field, enter the IPv4 address, IPv6 address, or fully qualified domain name (FQDN) of the remote server. After the remote log server is saved, you cannot modify the server address.
    2. In the Port field, enter the port number of the remote server.
      The default port value is 514.
    3. For Protocol, select UDP or TCP to choose between TCP or UDP input.
      Note: The Authenticationfield is displayed only when the TCP protocol is selected.
    4. From the Selectors field,
      • Select LOCAL0 or AUTHPRIV
      • From the Severity list, select the severity level of the messages to log
        Option Description
        Debug Verbose messages used for troubleshooting
      Note: To add more selectors, click the + button. To remove the existing selectors, select it and click the x button.
    5. For Authentication, select the enable or disable option from the list. The default value is Disabled. This option is visible when the TCP protocol is selected while configuring the remote log server. If the UDP protocol is selected, the authentication value is saved as N/A.
    6. Click Save & Close
  5. To delete a remote log server, select the server and click Delete.
  6. To view the Host Log Settings, click Show.
    1. For Host Log Forwarding, select the enable or disable button for remote forwarding. The default value is Disabled.
    2. For Selectors, select the required facility and severity options from the list. To add more selectors, click the add + icon. To remove the existing selectors, click the remove (X) icon.
    3. To add the required host log files to the Selected Files panel, click the required host log files checkboxes. Click on directories to view the files and sub-directories and select individual files within the directory.
      The Selected Files option allows the host logs files to be forwarded from the directory and subdirectories.
    4. For Custom Log File, enter the log file in the text box and click Add to manually add host log file names to the Selected Files panel.
  7. For TLS Certificate & Key, click Show. It displays TLS Certificate and TLS Key options. If the authentication value is set as enabled for any of the remote log servers, you cannot be able to clear the TLS configuration fields.
  8. For CA Bundles, click Add to enter the name and TLS CA certificate. When any of the remote server authentication is enabled, you cannot delete the CA bundle.
  9. On the Log Settings screen, review the software component log levels for individual software components and adjust them as needed. Click Save if you made changes.
    The log levels determine at what level events (and all higher levels) are logged for each service. Informational is the default so all except debug-level events are logged.
    Component
    Description
    alert-service
    Software component that handles ‌alerts and events at the system level. These components use ConfD to process updates and manage the status of the Alarm LED depending on the severity of the alert.
    dagd-service
    Software component that manages the distribution of Tenant traffic.
    fips-service
    Software component for System FIPS configuration and handles system integrity check requests.
    kubehelper
    Software component triggered during tenant deployment and runs as a assistant task before tenant container is created. For BIG-IP
    • Covert qcow2 image to raw format for BIG_IP tenant only.
    • Reserves huge pages for the tenant
    • Creates host-net interface for host and tenant communication purposes.
    • Creates a tenant management interface for BIG-IP NEXT tenants and includes route integration.
    lldpd
    Software component for LLDP configuration.
    orchestration-agent
    Software component for Tenant Orchestration which includes tenant configuration and deployments.
    platform-monitor
    The Monitoring Agent is responsible for: - Creating telemetry pipelines that query data periodically.
    • Applying processors to the data.
    • Sending the data to various destinations.
    rsyslog-configd
    Software component for remote syslog configuration handling.
    sys-host-config
    Software component responsible for: - Setting up management IP to access the device, collecting management interface stats, and enabling/disabling of management interface.
    • Setting up DNS configurations.
    • Updating required files for internal subnet changes.
    • Exchanging internal subnet changes to LCD server.
    • Updating Base MAC and MAC pool size in ConfD.
    • Addition/Deletion of SSH IP table rules.
    • Additionally, it offers backend code support for various ConfD configurations such as:
      • Hostname
      • Date
      • Motd Banner
      • System Reboot
      • SSH idle timeout
    utils-agent
    Software component that manages file transfer operations such as import, export, delete, and download/upload.
    api-svc-gateway
    Software component that manages requests and subscriptions for Tenants on the appliance.
    datapath-cp-proxy
    Software component that manages Tenant datapath setup requests and configuration.
    firewall-manager
    One software component that enables the setting up of a whitelist for designated source IP addresses and destination ports such as HTTP, HTTPS, RESTCONF, SNMP, and vConsole.
    l2-agent
    Software component responsible for managing the setup and status of physical connections (such as interfaces and portgroups) and the configuration and status of Layer-2 components (such as VLANs, LAGs, and FDB).
    lopd
    Software component to manage communication with the LOP (AOM).
    partition-common
    The system component incorporates standard ConfD utility functions that enhance the CLI interface.
    platform-stats
    Software component responsible for capturing the various utilization stats of the CPU, drives and memory and storing the data in TMSTAT stat tables.
    snmp-service
    Software component used to configure system SNMP configuration such as community, target, and user.
    system-control
    System component that implements configuration backup and restore.
    vconsole
    Software component for providing authenticated virtual console access to F5OS tenants.
    appliance-orchestration-manager
    Appliance Onboard Monitoring Daemon (OMD) is a service daemon that oversees the internal coordination of tasks via Kubernetes (K3S). It is responsible for setting up and controlling all required device plugins that enable communication with different hardware components.
    diag-agent
    The Diagnostic Agent is responsible for running various diagnostic profiles, gathering and exporting telemetry data and providing system health information and producing the hardware alerts.
    http-server
    Software component responsible for running the apache HTTPD server.
    lacpd
    Daemon responsible for negotiation of LACP over system interfaces.
    network-manager
    Software component responsible for managing datapath related resources, such as MAC Addresses. It also manages datapath tables that route traffic between Tenants and Interfaces.
    platform-diag
    Software component for providing statistics reports and measurements on top of the low-level hardware.
    platform-stats-bridge
    Software components responsible for handling the platform statistics to display on user interfaces.
    snmp-trapd
    Software component that process the system alerts/events as traps and sends it to SNMP manager.
    tmstat-agent
    Software component for providing the framework which can be used to store the statistics data in centralized location on each host.
    audit-service
    Software component for capturing the system configuration related logs in audit log.
    diag-data
    Software component for primarily tasked with collecting important information periodically from an F5OS device and sending that data back to F5 for analysis purposes.
    ihealth-upload-service
    Software component for providing secure way of transporting support package to F5 to different target destination. This service offers historical track records of support package uploads with configurable data retention policy.
    lacpd-proxy
    Daemon responsible for reporting the results of LACP negotiation from lacpd.
    nic-manager
    Software component which manages the datapath network interfaces.
    platform-fwu
    Software component responsible for updating and reporting firmware.
    qat-confd-service
    Service for communicating QAT device tenant assignments to ConfD tables.
    sshd-crypto
    Service that manages all the crypto algorithms configuration for sshd.
    tmstat-merged
    Software component for providing framework to integrate and divide statistics streams.
    authd
    Software component responsible for managing the configuration settings for various AAA (Authentication, Authorization, Accounting) mechanisms supported by the F5OS system.
    disk-usage-statd
    None
    ihealthd
    Software component responsible for handling ihealth configuration parameters and start a qkview upload by sending a request to ihealth.
    license-service
    Software component responsible for system licensing installation.
    node-agent
    Software component triggered during tenant deployment and node reboots. - Creates a tenant management interface for BIG-IP NEXT tenants and includes route integration.
    • Adds water-marking rules for BIG-IP NEXT tenants.
    • In charge of allocating large pages for chassis during tenant deployments.
    platform-hal
    Software component that provides other services with access to platform/hardware data and configuration.
    qat-plugin
    Kubernetes device plugin for reporting and managing QAT device resources and resource activities related to their respective tenant assignments.
    stpd
    Software component for configuring STP L2 protocol in platform.
    upgrade-service
    Software component for processing the system image and package upgrade requests.
    confd-key-migrationd
    The software component for transfering ConfD configuration from one system to another requiring the same encryption key. This is necessary to migrate encrypted element values successfully.
    dma-agent
    Software component for Core Offload feature that functions as a buffer broker, allowing multiple tenants to share access to the FPGA while remaining isolated from one another.
    image-agent
    A software module that manages the validation of imported tenant images and displays the current status of both tenant and platform images on the user interface.
    line-dma-agent
    Software component which is an fundamental layer of tcpdump in the rSeries family.
    optics-mgr
    Software component that is responsible for storing the tuning values for supported optics. When provided with an optic, returns the proper tuning.
    platform-mgr
    This software component displays the versions of platform components, CPUs, memory, and firmware. It also automatically initiates firmware upgrades when upgrading or installing a new ISO and rebooting.
    qkviewd
    Software component designed to create diagnostic snapshots in containerized systems, known as QKView. A QKView file is a compressed file with diagnostic info from containers, the host, and other systems.The main qkviewd service operates within a container, while qkviewd-host service collects data on the host. A peer system is another system running the qkviewd daemon.
    sw-rbcast
    Software component that is responsible for forwarding broadcast traffic received on a shared VLAN to the tenants which share that VLAN. A secondary responsibility is to forward DLF (destination look-up failures) requests to the fpgamgr component, so that they can be resolved.
    user-manager
    Software component responsible for the management and configuration of local users on the system such as user accounts, groups/roles, and passwords.
    fpgamgr
    Software component, which manages the datapath FPGAs. ‌This includes ‌front panel interfaces, L2 functionality, and other advanced FPGA features.
    lcd-webserver
    Software component providing a webserver to operate the LCD user interface.
    sshd-crypto
    Software component for handling sshd crypto agility configurations.
  10. Click Save to save the log settings.
The system logs events to the appliance.log file located in the log/host directory. To list files and view the contents of log files, you use the file command from the CLI.
  3. List all files in the log directory.
    file list path [ log/confd/ | log/host/ | log/system/ }
    This example shows an excerpt of the contents of the log/host/ directory:
    appliance-1# file list path log/host
    entries {
        name anaconda/
        date Thu May 12 17:01:36 UTC 2022
        size 4.0KB
    entries {
        name ansible.log
        date Fri Jun 17 16:18:02 UTC 2022
        size 0B
    entries {
        name appliance.log
        date Fri Jun 17 16:18:19 UTC 2022
        size 9.8KB
    entries {
        name audit/
        date Fri Jun 17 14:59:04 UTC 2022
        size 4.0KB
    entries {
        name boot.log
        date Thu May 12 17:02:35 UTC 2022
        size 105B
  4. Show the contents of a log file.
    file show [ log/confd/<*filename*> | log/host/<*filename*> | log/system/<*filename*> ]
    This example shows the contents of the log/host/boot.log file:
    appliance-1# file show log/host/boot.log
    May 12 10:02:35 localhost NET[1605]: /etc/sysconfig/network-scripts/ifup-post : updated /etc/resolv.conf
  5. Show only the most recent entries in a log file.
    file tail [ log/confd/<*filename*> | log/host/<*filename*> | log/system/<*filename*> ]
    This example shows the last ten lines of the appliance.log file and uses the -f option to append output as the file grows:
    appliance-1# file tail -f log/host/appliance.log
    2022-06-17 16:18:03.267761 - OMD log is initialized
    2022-06-17 16:18:03.267761 - 8:-738199808 - applianceMainEventLoop::Orchestration manager startup.
    2022-06-17 16:18:03.270244 - 8:-754985216 - Can now ping appliance-1.chassis.local (100.65.60.1).
    2022-06-17 16:18:03.723485 - 8:-754985216 - Successfully ssh'd to appliance 127.0.0.1.
    2022-06-17 16:18:14.399076 - 8:-738199808 - Appliance 1 is ready in k3s cluster.
    2022-06-17 16:18:14.399095 - 8:-738199808 - K3S cluster is ready.
    appliance-flannel_image|localhost:2003/appliance-flannel:0.13.0
    No Image Changes Found for normal reboot
    appliance-multus_image|localhost:2003/appliance-multus:3.6.3
    _
The system logs events to the appliance.log file located in the var/log directory and enables you to send these logs to a remote server. By configuring secure remote logging from the CLI, you can send logs in audit.log to a remote server. Secure logging is disabled by default.
    config
  4. Configure secure remote logging. The default value is disabled.
    system logging remote-servers remote-server <*ip-address*> config proto { udp | tcp | remote-port <*port-number*> authentication { disabled | enabled }
    The default protocol is upd, and the default port number is 514.
    This example enables secure remote logging:
    appliance-1(config)# system logging remote-servers remote-server
      192.0.2.58 config proto tcp remote-port 80 authentication enabled
  5. Add certificate or key details for secure remote logging.
    system logging tls { certificate | key } <*string*>
  6. Add CA bundle details for secure remote logging.
    system logging tls ca-bundles ca-bundle <*name*> config name <*name*> content <*ca-cert-contents*>
    Note: The certificate bundle that you specify must include the certificate chain of the certificate authority.
    commit
    end
  9. Verify the authentication, certificate, key, and CA bundle configuration.
    show running-config system logging tls { certificate | key | ca-bundles } <*string*>
You can disable secure remote logging from the CLI.
    config
  4. Disable secure remote logging.
    This example disables secure remote logging:
      192.0.2.58 config proto tcp remote-port 80 authentication disabled
  5. Remove authentication details from secure remote logging.
    no system logging remote-servers remote-server <*ip-address*> config authentication
  6. Remove certificate or key details from secure remote logging.
    no system logging tls { certificate | key } <*string*>
  7. Remove CA bundle details from secure remote logging.
    no system logging tls ca-bundles ca-bundle
  8. Commit the configuration changes.
    commit
  9. Return to user (operational) mode.
    end
  10. Veify the authentication, certificate, key, and CA bundle configuration.
You can import, export, download, or delete files asynchronously depending on which directory you select to work in. All file transfers are done using the HTTPS protocol.
You can import a file from an external server into the system from either the webUI or the CLI. HTTPS is the supported protocol. The remote host should be an HTTPS server with PUT/POST enabled and have a valid CA-signed certificate.
Note: If you want to import the contents of a tar file, you need to extract the contents first before you can import them onto the F5 system.
You can import files into these directories on the system:
  • configs/
  • diags/shared
  • images/import/services
  • images/staging
  • images/tenant
  • images/import/iso/
  • images/import/os/
You can download files in these directories from the system to your local workstation from the webUI:
  • log/host
  • configs
  • diags/core
  • diags/crash
  • diags/shared
  • log/confd
  • log/system
You can upload files in these directories from your local workstation to the system from the webUI:
  • configs
  • images/staging
  • images/tenant
  • images/import/os/
  • images/import/services/
You can export a file from the system to an external server from either the webUI or the CLI. HTTPS is the supported protocol. The remote host should be an HTTPS server with PUT/POST enabled and have a valid CA-signed certificate.
You can export files into these directories from the system:
  • configs
  • log/
  • log/confd
  • log/controller
  • log/host
  • log/system
  • diags/
  • diags/core
  • diags/crash
  • diags/shared
  • images/
  • images/import
  • images/staging
  • images/tenant
  • images/import/os/
You can delete files (to which you have file permissions) on the system only from the diags/shared or configs directories from either the webUI or the CLI.
File Utilities are available in the webUI. You can use File Utilities to upload, download, import, export, and/or delete files asynchronously depending on which directory you select to work in. All file transfers are done using HTTPS protocol.
  2. On the left, click SYSTEM SETTINGS > File Utilities.
  3. From the Base Directory list, browse the directories and click subfolders to view their contents and the commands that are available from each one.
    From a subfolder, click the left arrow next to the path to navigate back to the main folder.
  4. To import a file:
    1. Click Import.
    2. In the popup, enter the URL of the file to import.
    3. Provide the Username and Password only if required by the remote host.
    4. Select Ignore Certificate Warnings if you want to skip warnings when importing files (such as if the remote host does not have a valid CA-signed certificate).
    5. Click Import File to begin the import.
  5. To export a file:
    1. Select the file and click Export.
    2. In the popup, enter the Server URL for where to export the file.
    4. Select Ignore Certificate Warnings if you want to skip warnings when importing files.
    5. Click Export File to begin the export.
  6. To upload the file, select the file from your system and click Upload button.
    The selected file will be uploaded.
  7. To download the file, select the file and click Download button.
    The selected file will be downloaded.
  8. To delete a file, select the file and click Delete.
    You can delete files only from the diags/shared directory.
You can view the status of a file transfer operation to view its progress and see if it was successful. If you want to cancel an in-progress file transfer operation, click Cancel button. If an operation fails, hover over the warning icon to see the error that occurred.
Note: A runtime error displays in the File Transfer status area, if an invalid operation is performed.
You can view the contents of a file from the CLI.
  2. View the contents of a file.
    file show <*local-file-path*>
    This example shows how to view the contents of the platform.log file:
    appliance-1# file show log/system/platform.log | until 5
    2022-12-27T21:34:24.718946+00:00 appliance-1 tmstat-agent[1]: priority="Info" version=1.0 msgid=0x1601000000000008 msg="TMSTAT directory set from command line." directory="cluster".
    2022-12-27T21:34:24.719592+00:00 appliance-1 ihealthd[8]: priority="Info" version=1.0 msgid=0x6602000000000005 msg="DB is not ready".
    appliance-1# file show log/system/platform.log | until 15
    2022-12-27T21:34:24.720155+00:00 appliance-1 alert-service[9]: priority="Notice" version=1.0 msgid=0x2201000000000001 msg="Alert Service starting." version="3.11.7" date="Thu Nov  3 13:25:15 2022".
You can import a file from an external server onto your system from the CLI.
  2. Import a file.
    file import remote-url <*ip-address-and-file-path*> local-file <*local-file-path*> username <*user*> password [ remote-port <*port-number*> } [ protocol [ https | scp | sftp ]] [insecure]
    Note: The insecure option ignores certificate warnings during the transfer.
    This example shows how to import a Base OS ISO to the system:
    appliance-1# file import remote-url https://files.company.com/images/F5OS-A-1.6.x-xxxxx.R5R10.iso
      local-file images/staging username admin password
    Enter the password at the prompt:
         Value for 'password' (<string>): ********
    result File transfer is initiated.(images/staging/F5OS-A-1.6.x-xxxxx.R5R10.iso)
    Note:
    • If the file import doesn’t work, you can alternatively use secure copy (SCP) to copy the image file to the images/staging directory of the system.
    • When importing a file using the remote-url argument, you must wrap the URL in double quotes (""). This prevent special characters from being incorrectly interpreted as shell commands. For example: remote-url "https://example.com/file-path?params"
      Example: Transfer a file named {}myfile.iso{} from the remote URL https://files.example.com on port 443 to the images/staging directory on the system:
      file import local-file images/staging remote-url "https://files.example.com/images.myfile.iso" remote-port 443 protocol https
  3. Optionally, you can check the file transfer status.
    appliance-1# file transfer-status
    When the file transfer completes, the Status displays Complete.
  4. Export a file.
    file export remote-url <*ip-address-and-file-path*> local-file <*local-file-path*> username <*user*> password [ remote-port <*port-number*> } [ protocol [ https | scp | sftp ]] [insecure]
    appliance-1# file export local-file configs/backup1.xml remote-file /tmp/backup1.xml
      remote-host 192.51.100.75 username root
    The system requests the password for the remote account.
    result File transfer is initiated.(configs/backup1.xml)
  5. Delete a file.
    file delete local-file diags/shared/<*file-name.xml*>
    This example shows how to delete a file:
    appliance-1# file delete local-file diags/shared/backup1.xml
    You can only delete files from the diags/shared or configsdirectory.
You can cancel an in-progress file import onto your system from the CLI.
  2. Get the operation identifier for the file transfer process.
    show file transfer-operations
    appliance-1# show file transfer-operations
    file transfer-operations transfer-operation images/import/iso/F5OS-A-1.6.0-1234.iso
      files/F5OS-A/images/F5OS-A-1.6.0-1234.iso "Import file" "HTTPS   "
     operation-id IMPORT-C16QYpun
     status       "In Progress (13.0%)"
     timestamp    "Fri Mar 24 23:05:54 2023"
  3. Cancel the specified file transfer.
    file abort-transfer operation-id <*id*>
    This example shows canceling a specified in-progress file transfer:
    appliance-1# file abort-transfer operation-id IMPORT-C16QYpun
    Aborting will stop the file transfer. Do you want to proceed? [yes/no] yes
    result File transfer abort operation initiated.
You can export a file to an external server from your system from the CLI.
  2. Export a file.
    file export insecure local-file <*local-file-path*> protocol { https | scp | sftp } remote-file <*remote-file-path*> remote-host <*ip-address-or-fqdn*> remote-port <*port-number*> remote-url <*ip-address-or-fqdn*> username <*user*> web-token <*remote-system-token*>
You can delete files from the CLI.
  2. Delete a file.
    You can delete files only from the diags/shared or configsdirectories.
You can configure Network Time Protocol (NTP) for the rSeries system. An NTP server ensures that the system clock is synchronized with Coordinated Universal Time (UTC). The system also provides authentication support for NTP, which can enhance security by ensuring that the system sends time-of-day requests only to trusted NTP servers. You can also configure the time zone and set the time and date manually, if NTP is disabled. You can use either the CLI or webUI to configure time settings.
After the system license is activated, you can configure Network Time Protocol (NTP) servers, including authentication support for NTP, time zone, and manual configuration of date and time, if NTP is disabled. The NTP server ensures that the system clock is synchronized with Coordinated Universal Time (UTC). You can specify a list of servers that you want the system to use when updating the time on network systems. You can configure time settings for the system from the webUI.
  2. On the left, click SYSTEM SETTINGS > Time Settings.
  3. To synchronize the system clock with an NTP server, for NTP Service, click Enabled.
    The NTP Service is set to Disabled, by default.
  4. To manually set the time and date:
    1. For NTP Service, select Disabled.
    2. In the Manual Time & Date Settings area, click the calendar to set the date and time.
  5. To use authentication support for NTP:
    1. For NTP Authentication, select Enabled.
      The NTP Authentication is set to Disabled by default.
    2. For NTP Keys, click Add.
      The Add NTP Key screen displays.
    3. For Key ID, enter an identifier used by the client and server to designate a secret key.
      The client and server must use the same key ID.
    4. For Key Type, select the encryption type used for the NTP authentication key.
      The default value is F5_NTP_AUTH_SHA256.
      Select from these options:
      • F5_NTP_AUTH_MD5
      • F5_NTP_AUTH_SHA1
      • F5_NTP_AUTH_SHA256
      • F5_NTP_AUTH_SHA384
      • F5_NTP_AUTH_SHA512
    5. For Key Value, paste the text of the NTP authentication key.
    6. Click Save & Close.
  6. To specify an NTP server:
    1. Click Add.
    2. In the NTP Server field, enter the IPv4 address, IPv6 address, or the fully qualified domain name (FQDN) of the NTP server.
      Note: If specifying an FQDN, you must configure a resolvable DNS server for the system.
    3. Set iburst Mode to True if necessary. By default, it is set to False.
    4. Select a Key ID, if you have defined an NTP key, select it from the list.
    5. Click Save & Close.
  7. To set the time zone, from Locations, select the time zone region.
  8. Click Save & Close.
You can manually configure the date and time for your system from the CLI.
    config
  4. Change the system date and/or time.
    Note: You can opt to change only the time or only the date by including only the relevant option (either time or date).
    system set-datetime date <*YYYY-MM-DD*> time <*HH:MM-SS*>
    In this example, you change the system date to 2022-01-01 and the system time to be 12:01:00:
    appliance-1(config)# system set-datetime date 2022-01-01 time 12:01:00
The system date and time are now updated.
You can configure Network Time Protocol (NTP) for your rSeries system from the CLI.
Note: If you want to enable NTP authentication, see Configure NTP authentication from the CLI.
    config
  4. Enable NTP.
    system ntp config enabled
  5. Add an NTP server.
    system ntp servers server <*ip-address*>
    In this example, you configure an NTP server at pool.ntp.org:
    appliance-1(config)# system ntp servers server pool.ntp.org
    commit
  7. Return to user (operational) mode.
    end
  8. Verify that NTP is enabled and a server is configured.
    appliance-1# show system ntp
    system ntp state enabled
    system ntp state enable-ntp-auth false
     state address    pool.ntp.org
     state port       123
     state version    4
     state association-type SERVER
     state iburst     false
     state prefer     false
     state stratum    4
     state root-delay 34
     state root-dispersion 36
     state offset     244
     state poll-interval 6
     state authenticated false
You can configure Network Time Protocol (NTP) authentication for your rSeries system from the CLI. NTP authentication enhances security by ensuring that the system sends time-of-day requests only to trusted NTP servers.
    config
  4. Enable NTP.
  5. Enable NTP authentication.
    system ntp config enable-ntp-auth true
  6. Add the key associated with your server to the system.
    system ntp ntp-keys ntp-key <*public-key-id*> config key-id <*secret-key-id*> key-type [ F5_NTP_AUTH_MD5 | F5_NTP_AUTH_SHA1 | F5_NTP_AUTH_SHA256 | F5_NTP_AUTH_SHA384 | F5_NTP_AUTH_SHA512 ] key-value HEX:<*ntp-auth-key-value*>
    Important: The key ID, key type, and key value on this client system must match the server exactly.
    appliance-1(config)# system ntp ntp-keys ntp-key 11
      config key-id 11 key-type F5_NTP_AUTH_SHA1 key-value
      HEX:E27611234BB5E7CDFC8A8ACE55B567FC5CA7C890
  7. Add an NTP server and associate the key ID you added with the server.
    In this example, you configure an NTP server at the IP address 192.0.2.118:
    appliance-1(config)# system ntp servers server 192.0.2.118
    appliance-1(config-server-192.0.2.118)# config key-id 11
    commit
    end
  10. Verify that NTP with authentication is enabled and a server is configured.
    appliance-1# show system ntp servers
     state address    192.0.2.118
     state port       123
     state version    4
     state iburst     false
     state prefer     false
     state stratum    8
     state root-delay 0
     state root-dispersion 0
     state offset     251333
     state key-id     11
     state authenticated true
Simple Network Management Protocol (SNMP) is an industry-standard protocol that enables you to use a standard SNMP management system to remotely manage network devices. F5 rSeries systems support SNMPv1, SNMPv2c, and SNMPv3. You can configure the system from both the CLI and webUI.
SNMP support is available in different ways, depending on which F5OS software version you are using. On F5 rSeries systems, SNMP is available from both the CLI and webUI.
F5 recommends using the newer system snmp commands, which include support for SNMP versions 1, 2c, and 3. For more information on the older commands, see:
F5OS-A software version
Older CLI (v1/v2c only)
Newer CLI (v1/v2c/v3)
1.2.0
SNMP-COMMUNITY-MIB
SNMP-NOTIFICATION-MIB
SNMP-TARGET-MIB
SNMP-VIEW-BASED-ACM-MIB
SNMPv2-MIB
system snmp communities system snmp engine-id
system snmp targets
system snmp users
Before you configure SNMP access for F5 rSeries systems:
You can view SNMP information in the /log/system/snmp.log file. You can download the log file to your local workstation from the File Utilities screen in the webUI (on the left, click SYSTEM SETTINGS > File Utilities, and then from Base Directory, select log/system, select snmp.log, and click Download). For more information about managing files from the webUI or CLI, see File utilities overview.
SNMPWALK is an application on an SNMP management system that performs SNMP GETNEXT requests to query a network device for information. You can provide an object identifier (OID) to specify which portion of the object identifier space to search using GETNEXT requests. The SNMP management system queries all variables in the subtree below the specified OID, displays these values to the user, and stops when it returns results that are no longer inside the range of the specified OID.
These SNMP system object IDs (OIDs) are defined for each F5 rSeries system type:
  • 1.3.6.1.4.1.12276.1.3.1.1 (f5OsAppR5x00)
  • 1.3.6.1.4.1.12276.1.3.1.2 (f5OsAppR10x00)
  • 1.3.6.1.4.1.12276.1.3.1.3 (f5OsAppR2x00)
  • 1.3.6.1.4.1.12276.1.3.1.4 (f5OsAppR4x00)
The IDs display in text format when the corresponding MIB is loaded in your SNMP management system. If the MIB is not loaded, the walk displays in OID format.
To more accurately map these system OIDs, you must download the F5-OS-SYSTEM-MIB.mib file and load it into your SNMP management system. To download the F5 MIB files, use File Utilities in the webUI (on the left, click SYSTEM SETTINGS > File Utilities, and then from Base Directory, select mibs, select a .tar.gz file, and click Download).
You can configure the SNMP port from the rSeries webUI.
  1. Log in to the webUI using an account with admin access.
  2. On the left, click SYSTEM SETTINGS > SNMP Configuration.
  3. For Port, enter the required value. The allowed values for the Port are either 161 or in the ranges of [1024-7000, 7033-8887, 8889-65535]. To check whether a port is valid or not, we have inline validation.
    Note: The port configured in the SNMP Configuration area is reflected on the Allow List Entry screen of the Allowed IP Addresses section under System Security in the System Settings chapter. When an allowlist is created with an SNMP port, the user is not allowed to change the SNMP Port on the SNMP Configuration area, which can cause an error. For more information, see Configure the system allow list from the webUI.
  4. Click Save & Close.
You can configure the SNMP properties from the webUI.
  3. Under the Properties area, enter values in the required fields.
    • System Contact
    • System Location
    • System Name Note: The maximum number characters limit is 255.
You can configure SNMP communities with either version 1, version 2c, or both security models from the webUI.
  3. In the Communities area, click Add.
    The Add Community screen displays.
  4. For Community, enter a descriptive name.
  5. For Security Model, select from these security models: v1, v2c, and v1 and v2c.
You can configure SNMP version 3, which is a user-based security model, from the webUI. This model provides support for additional authentication and privacy protocols.
  3. In the Users area, click Add.
    The Add v3 User screen displays.
  4. For User, enter the user name.
  5. For Authentication Protocol, select from these protocols: MD5, SHA, or None.
  6. For Authentication Password, enter the password for the specified user.
  7. For Privacy Protocol, select from these protocols: AES128, DES, or None.
Before you can add an SNMP target, you must have already configured either the SNMPv1/v2c community or SNMPv3 user.
You can configure SNMP targets from the webUI. These are required to send system-generated traps to a manager. You can choose either community (v1/v2c) or user-based (v3) security.
  3. In the Targets area, click Add.
    The Add Target screen displays.
  4. For Name, enter a descriptive name.
  5. For Security Model, select from these security models: v1, v2c, or v3.
  6. Select one of these options, depending on the selected security model:
    • If you selected v1 or v2c, for Community, select the community that you created with that security model.
    • If you selected v3, for User, select the user that you created.
  7. For IPv4/IPv6, select either IPv4 or IPv6.
  8. For Address, enter the IPv4 address, IPv6 address, or fully qualified domain name (FQDN) of the target.
  9. For Port, enter the port number for the target.
    The default value is 162, and the range is from 1024 to 65535
  10. Click Save & Close.
You can configure the SNMP port from the CLI.
  1. Log in to the command line interface (CLI) of the system using an account with admin access.
    When you log in to the system, you are in user (operational) mode.
  2. Change to config mode.
    config
    The CLI prompt changes to include (config).
  3. Configure SNMP port
    system snmp config port <*value*>
    he following example configures SNMP port ‘5000’:
    appliance-1(config)# system snmp config port 5000
    Note: The allowed values for the Port are either 161 or in the ranges of [1024-7000, 7033-8887, 8889-65535]. The port configured in the SNMP Configuration area is reflected on the Allow List Entry screen of the Allowed IP Addresses section under System Security in the System Settings chapter. When an allowlist is created with an SNMP port, the user is not allowed to change the SNMP Port in the SNMP Configuration area, which can cause an error. For more information, see Configure the system allow list from the webUI
  4. Commit the configuration changes.
    commit
You can configure the SNMP properties from the CLI.
    config
  3. Configure SNMP properties
    SNMPv2-MIB system sysName <*system name*> sysLocation <*location name*> sysContact <*contact details*>
    A summary of this example displays:
    appliance-1(config)# SNMPv2-MIB system sysName f5System sysLocation boston sysContact support@f5.com
    commit
You can configure SNMP communities with either version 1, version 2c, or both security models from the CLI.
  1. Connect using SSH to the management IP address.
  2. Log in to the command line interface (CLI) of the system using an account with admin access.
  3. Change to config mode.
    config
  4. Configure a community.
    system snmp communities community <*community-name*> config security-model { v1 | v2c }
    This example creates a community that uses the v2c security model:
    appliance-1(config)# system snmp communities community v2comm config
      security-model v2c
    This example creates a community that uses both v1 and v2c community models:
    appliance-1(config)# system snmp communities community v1v2c config
      security-model [ v1 v2c ]
    commit
  6. Return to user (operational) mode.
    end
  7. Verify the community configuration.
    show system snmp communities
    A summary similar to this example displays:
    appliance-1# show system snmp communities
                          SECURITY
    NAME       NAME       MODEL
    v1v2c      v1v2c     [ v1 v2c ]
    Note: This example shows both security models configured. If you configure only one security model, then only the configured model displays in the output.
You can configure SNMP version 3, which is a user-based security model, from the CLI. This model provides support for additional authentication and privacy protocols.
    config
  4. Configure a user, including authentication and privacy protocols.
    system snmp users user <*user-name*> config authentication-protocol { md5 | none | sha } privacy-protocol { aes | des | none } authentication-password
    This example creates a user that uses MD5 authentication and AES for password authentication:
    appliance-1(config)# system snmp users user jdoe config
      authentication-protocol md5 privacy-protocol aes authentication-password
    After you press Enter, you are prompted to enter the authentication password.
    (<string, min: 8 chars, max: 32 chars>): ********
    After you press Enter, configure the privacy password.
    appliance-1(config-user-v3-user)# config privacy-password
    After you press Enter, you are prompted to enter the privacy password.
    (<string, min: 8 chars, max: 32 chars>): *********
  5. Commit the configuration changes.
    commit
    end
  7. Verify the user configuration.
    show system snmp users
    appliance-1# show system snmp users
                      AUTHENTICATION  PRIVACY
    NAME     NAME     PROTOCOL        PROTOCOL
    jdoe     jdoe     md5             aes
You can configure SNMP targets with community-based security (SNMPv1/SNMPv2c) from the CLI. These are required to send system-generated traps to an SNMP management system.
    config
  4. Configure a target with community-based security.
    system snmp targets target <*target-name*> config community <*community-name*> security-model { v1 | v2c } { ipv4 | ipv6 } address <*ip-address*> port <*port-number*>
    This example creates a target with community-based security:
    appliance-1(config)# system snmp targets target v2c-target
      config community v2c-comm security-model v2c ipv4 address 192.0.2.24
      port 5001
    commit
    end
  7. Verify the target configuration.
    appliance-1# show system snmp targets
                                              SECURITY
    NAME       NAME       USER     COMMUNITY  MODEL     ADDRESS         PORT  ADDRESS  PORT
    v2c-target v2c-target jdoe     -          -         192.0.2.24      5001  -        -
You can configure SNMP targets with user-based security (SNMPv3) from the CLI. These are required to send system-generated traps to an SNMP management system.
    config
  4. Configure a target with user-based security.
    system snmp targets target <*target-name*> config user <*user-name*> { ipv4 | ipv6 } address <*ip-address*> port <*port-number*>
    This example creates a target with user-based security:
    appliance-1(config)# system snmp targets target v3-target
      config user jdoe ipv4 address 192.0.2.24 port 5001
    commit
    end
                                              SECURITY
    v3-target  v3-target  jdoe     -          -         192.0.2.24      5001  -        -
You can back up the system configuration from the webUI.
  2. On the left, click SYSTEM SETTINGS > Configuration Backup.
  3. Click Create.
    The Create Configuration Backup popup opens.
  4. In the Name field, enter a name for the backup (for example, system-12-21-21).
  5. Click Create.
    The backup is created and added to the list.
  6. To delete a backup file, select the file and click Delete.
System configuration backups are stored in configs/. Backups should be stored on off the system.
You can restore configurations from the CLI. For more information on saving and restoring the configuration, see Complete backup and restore overview.
You can activate a license for the rSeries system from either the CLI or webUI. There is one license per rSeries system, which is used by the chassis partitions and any tenants.
You can activate a license for the rSeries system from either the CLI or webUI. There is one license per rSeries system, which is also used by any tenants.
There are two ways to license the system:
If your system is connected to the internet, use the Automatic method to prompt the system to contact the F5 license server and activate the license.
If your system is not connected to the internet, use a management workstation that is connected to the internet to retrieve an activation key from F5 and then transfer it to the system.
Important:
Adding or reactivating a license on an active rSeries system might impact traffic on tenantsrunning on chassis partitions. Traffic processing will stop briefly on the tenants, and then restart automatically. This occurs when the tenant receives a new or reactivated license causing a configuration reload on the tenants. For more information, see these other references:
You can license a system using the automatic method from the webUI, as long as the system has Internet access.
  2. On the left, click SYSTEM SETTINGS > Licensing.
  3. For the Base Registration Key field, the registration key is auto-populated.
    You can choose to overwrite this field with a new registration key by clicking Reactivate and overwriting the field.
  4. For the Add-On Keys field, the associated add-on keys are auto-populated.
    You can choose to change these keys by clicking Reactivate and then click + or x to add or remove additional add-on keys.
  5. For the Activation Method, select Automatic.
  6. Click Activate.
    The End User License Agreement (EULA) displays.
  7. Click Agree to accept the EULA.
The system is now licensed. If a base registration key or add-on key fails to activate, try re-activating the license or contact F5 Support at support.f5.com.
You can license a system without access to the Internet using the manual activation method from the webUI.
  5. For the Activation Method, select Manual.
  6. For the Device Dossier, click Get Dossier.
    The system refreshes and displays the dossier.
  7. Copy the dossier text in the Device Dossier field.
  8. Click Click here to access F5 Licensing Server.
    The Activate F5 Product page displays.
  9. Paste the dossier in the Enter Your Dossier field.
  10. Click Next.
    The license key text displays.
  11. Copy the license key text.
    Alternatively, you can use the F5 license activation portal at activate.f5.com/license.
  12. In the License Text field, paste the license key text.
  13. Click Activate.
  14. Click Agree to accept the EULA.
You can activate the rSeries system license manually from the system CLI.
    config
  3. Get the system dossier.
    system licensing get-dossier [registration-key XXXXX-XXXXX-XXXXX-XXXXX-XXXXXXX]
    The registration key is optional. If it is not included, the system uses the one already pre-installed. If no registration key is found, you receive an error.
    The dossier for the system displays.
  4. Get the license file using the dossier output you just received by going to the F5 siteactivate.f5.com/license/dossier.jsp.
  5. Copy the license file text.
  6. Install the license.
    system licensing manual-install license
    Press Enter to enable multi-line mode and paste the contents. Press Ctrl-D to exit multi-line mode.
    appliance-1(config)# system licensing manual-install license
    Value for 'license' (<string>):
    [Multiline mode, exit with ctrl-D.]
The rSeries system is licensed. The license applies to the system and tenants.
For automatic rSeries system licensing, the system needs to be able to connect to the F5 licensing server either through the Internet or another means of networking. You need to have the Base Registration Key (five sets of characters separated by hyphens) provided by F5, and any add-on keys (two sets of 7 characters separated by a hyphen) that you have purchased. The Base Registration Key with associated add-on keys are pre-installed on a new rSeries system.
You can activate the rSeries system license automatically from the CLI.
    config
  3. Apply a license to the system.
    system licensing install registration-key <*key*>
    The registration key is optional. If it is not included, the system uses the one that is already pre-installed. If no registration key is found, you receive an error.
    This example applies a specified base registration license to the system:
    appliance-1(config)# system licensing install registration-key I1234-12345-12345-12345-1234567 result License installed successfully.
  4. Apply any add-on keys.
    system licensing install add-on-keys <*add-on-keys*>
    This example enables the additional features associated with the three specified add-on-keys, along with the entitlements of the base registration key:
     add-on-keys [1234567-1234567 2345678-2345678 3456789-3456789]
The rSeries system is licensed. The license and any add-on keys apply to the system and all tenants.
    config
    system licensing install registration-key <*key*> proxy-server <*protocol://domain name:port*> proxy-username <*name*> proxy-password <*input*>
    appliance-1(config)# system licensing install registration-key Y0922-72141-80658-12653-0642460 proxy-server http://192.0.2.20:3128 proxy-username root proxy-password
    Value for 'proxy-password' (<AES encrypted string>): *******
The rSeries system is licensed with proxy server. The license and any add-on keys apply to the system and all tenants.
You can display the license and associated information of an rSeries system from the CLI.
  2. Display the system license.
    show system licensing
    appliance-1# show system licensing
     system licensing license   Licensed version    1.1.0
           Registration Key    I1234-12345-12345-12345-1234567
           Licensed date       2022/02/08
           License start       2022/02/07
           License end         2022/03/11
           Service check date  2022/02/08
           Platform ID         C128
           Appliance SN        f5-nhlh-lule
           Active Modules
            Local Traffic Manager, r10900 (S680352-1548257)
              LTM to Best Upgrade, r109XX
              Rate Shaping
              DNSSEC
              Anti-Virus Checks
              Base Endpoint Security Checks
              Firewall Checks
              Machine Certificate Checks
              Network Access
              Protected Workspace
              Secure Virtual Keyboard
              APM, Web Application
              App Tunnel
              Remote Desktop
              DNS Rate Fallback, Unlimited
              DNS Licensed Objects, Unlimited
              DNS Rate Limit, Unlimited QPS
              GTM Rate Fallback, (UNLIMITED)
              GTM Licensed Objects, Unlimited
              GTM Rate, Unlimited
              Carrier Grade NAT (AFM ONLY)
              APM, Limited
              Routing Bundle
              Protocol Security Manager
              Access Policy Manager, Base, r109XX
              Advanced Web Application Firewall, r10XXX
              Max SSL, r10900
              Max Compression, r10900
              DNS Max, rSeries
              Advanced Firewall Manager, r10XXX
  3. Display the entire license file content received from the F5 license server.
    show running-config system licensing
F5 r10000 platforms include two storage drives that support drive mirroring using a redundant array of independent disks (RAID) by default. You can manage the software RAID array from either the CLI or the webUI.
Important: If you need to swap out a faulty drive, you must first remove the drive from the software RAID array before physically removing the drive from the platform.
You can configure a software RAID (redundant array of independent disks) for the system from the webUI.
  2. On the left, click SYSTEM SETTINGS > RAID Configuration.
  3. To remove a drive from the software RAID array:
    1. Select the drive to remove.
    2. Click Remove.
      When prompted, click OK to confirm drive removal.
  4. To add a drive to the software RAID array:
    1. Select the drive to add.
    2. Click Add.
      When prompted, click OK to confirm drive addition.
You can configure a software RAID (redundant array of independent disks) for the system from the CLI.
    config
  3. Remove a drive from the software RAID array.
    system raid remove drive ssd2
    appliance-1(config)# system raid remove drive ssd2
    status Remove of RAID SSD2 initiated.
    [11084.434517] md/raid1:md121: Disk failure on nvme1n1p3, disabling device.
    [11084.434517] md/raid1:md121: Operation continuing on 1 devices.
    [11084.449528] md/raid1:md122: Disk failure on nvme1n1p4, disabling device.
    [11084.449528] md/raid1:md122: Operation continuing on 1 devices.
    [11084.464098] md/raid1:md123: Disk failure on nvme1n1p5, disabling device.
    [11084.464098] md/raid1:md123: Operation continuing on 1 devices.
    [11084.478342] md/raid1:md124: Disk failure on nvme1n1p1, disabling device.
    [11084.478342] md/raid1:md124: Operation continuing on 1 devices.
    [11084.492509] md/raid1:md127: Disk failure on nvme1n1p2, disabling device.
    [11084.492509] md/raid1:md127: Operation continuing on 1 devices.
  4. Add the replacement drive to the array.
    system raid add drive ssd2
    appliance-1(config)# system raid add drive ssd2
    status Add RAID SSD2 initiated.
    The array status for the new drive should change to replicating, and the STAT LED should change to solid green. The replication process typically takes between 15 and 45 minutes.
You can configure general system settings for the rSeries system, such as system hostname, login banner, and message of the day (MOTD) banner. Depending on which setting you want to configure, you can use either the CLI or the webUI.
You can configure the hostname, login banner, message of the day (MOTD) banner, and an advisory banner for the system from the webUI. When enabled and configured, the advisory banner will display at the top of the webUI after authentication.
  2. On the left, click SYSTEM SETTINGS > General.
  3. For Hostname, enter a custom hostname for the system.
  4. For Login Banner, enter any text to be shown when users log in to the system.
  5. For MOTD Banner, enter any text to be used as a MOTD when users log in to the system.
  6. For Advisory Banner, select Enabled or Disabled.
  7. For Advisory Banner Color, select the color for the banner.
  8. For Advisory Banner Text, enter the text for the banner. The maximum number of characters is 80.
  9. Click Save.
You can manually configure the hostname for your system from the CLI. F5 recommends you to configure a Fully Qualified Domain Name (FQDN) hostname.
    config
  4. Change the hostname.
    system config hostname <*hostname*>
    The minimum length is 1 character, and the maximum length is 253 characters.
    In the examples below, you can see the hostname for the system either set to ’test-hostname’ or ‘f5lab.f5net.com’:
    appliance-1(config)# system config hostname test-hostname
    appliance-1(config)# system config hostname f5lab.f5net.co
    Note: You can set a Fully Qualified Domain Name (FQDN) or plain text as a hostname.
    commit
    Note: The system hostname is now updated. By default, the system hostname will be included in the subsequent logs.
  6. To verify the hostname included in the logs.
    show system logging state include-hostname
    In this example, the hostname is included in the logs:
    appliance-1# show system logging state include-hostname true
You can manually configure the log settings to include hostname that is configured for your system in the subsequent logs from the CLI.
    config
  4. To include hostname in the logs, set ‘include-hostame’ to true.
    system config include-hostname <*\{ false \| true \}*>
    Note: The default value is set to true.
    In this example, the configured system hostname is included in the logs:
    appliance-1(config)# system logging config include-hostname true
    commit
    end
  7. To verify the hostname is included in the subsequent logs.
    In the examples below, the system hostname “test-hostname” or “f5lab.f5net.com” is included in the logs:
    test-hostname# show system logging
    test-hostname#
    f5lab.f5net.com# show system logging
    f5lab.f5net.com#
The system hostname is now included in the subsequent logs.
You can configure the login banner for your system manually from the CLI. The login banner displays before users log in to each respective system.
    config
  4. Change the login banner text.
    system config login-banner
    In this example, you change the login banner text to indicate that unauthorized access is prohibited:
    appliance-1(config)# system config login-banner
    (<string>):
    UNAUTHORIZED ACCESS TO THIS DEVICE IS PROHIBITED
    commit
The login banner is now updated.
You can configure the message-of-the-day (MOTD) banner for your system manually from the CLI. The MOTD banner displays after users log in to each respective system.
    config
  4. Change the MOTD banner text.
    system config motd-banner
    In this example, you change the login banner text to notify users of upcoming system maintenance:
    appliance-1(config)# system config motd-banner
    (<string>):
    ATTENTION!
    This system is scheduled for maintenance in two days.
    commit
The MOTD banner is now updated.
You can verify the current MAC allocation data from the CLI.
  2. Display the current MAC allocation data.
    show system mac-allocation
    appliance-1# show system mac-allocation
    system mac-allocation state free-single-macs 17
    system mac-allocation state allocated-single-macs 3
    system mac-allocation state free-large-blocks 3
    system mac-allocation state allocated-large-blocks 0
    system mac-allocation state free-medium-blocks 0
    system mac-allocation state allocated-medium-blocks 0
    system mac-allocation state free-small-blocks 0
    system mac-allocation state allocated-small-blocks 0
    system mac-allocation state total-free-mac-count 113
    system mac-allocation state total-allocated-mac-count 3
    system mac-allocation state total-mac-count 116
You can verify the system uptime for the CLI:
  2. Display the system uptime.
    show system uptime
    appliance-1# show system uptime
    system uptime state up-time "6h, 26m, 0s"
If you are having an issue with the system (such as unusually high CPU or memory usage or lockup), it is possible that rebooting might help to resolve the issue.
When there is a problem, the system sends alerts that you would see on the dashboard or on the Alarms & Events screen. You should rarely have to reboot the system, however, because typically if the system needs to reboot, it will do so automatically without administrator intervention. F5 recommends working with customer support if you think a system reboot is necessary.
You can manually reboot the system from the CLI.
  3. Reboot the system.
    system reboot
    In this example, you reboot the system:
    appliance-1# system reboot
    The reboot of the system results in data plane and management connectivity
    to be disrupted. Proceed? [no,yes]
It takes a few minutes for the system to reboot, and you will be logged out from the SSH session.
You can reboot the system from the webUI.
  3. Review the system status.
    The Reboot button will not be available if the system is currently being rebooted.
  4. If you decide that a reboot is necessary, in the System Operations & Status area, click Reboot.
    A popup displays asking you to confirm the reboot operation.
    It takes a few minutes for the system to reboot, and you will be logged out from the webUI.
OpenTelemetry streamlines observability in distributed systems through standardized APIs, libraries, and tools for collecting telemetry data, including traces, metrics, and logs.
F5OS OpenTelemetry enables the efficient collection of streaming metrics and logs in a structured format from the F5OS product to display in your observability platform. All the metrics and logs will be exported through a gRPC connection. The F5OS supports gRPC endpoints and each OpenTelemetry Line Protocol (OTLP) endpoint is provided with the ability to toggle instrument based filtering.
Telemetry subsystem within the F5OS platform layer generates common attributes and different metrics to display in your observability platform.
An instrument is an area of metrics, which contain multiple metrics and can be enabled selectively. F5OS Resource includes instruments.
Summarizes the metrics that are associated with each tenant as they enters and exits the platform hardware at the DMA level.
The following tenant metrics are currently reported by the BIG-IP tenant into the F5OS platform layer. The metrics visible at the platform layer are only a limited subset of the total number of metrics available to the tenant. You can view the full tenant metrics by using the BIG-IP metric reporting capability.
F5OS OpenTelemetry exporter will only report the metrics that are associated with the Docker containers managed by the platform layer. For more information about the docker container metrics, see Docker stats documentation.
The platform hardware sensors represent physical sensors associated with the hardware which measure: temperature, current, power, voltage, RPM and percent humidity.
The metric schema is heavily dependent upon the internal representation of the tmstat tables within F5OS.
Instument name Description
all All the logs and metrics produced by the F5OS platform layer
logs All the F5OS logs file
platform-log All the F5OS platform logs file
event-log All the F5OS ConfD event log
metrics All the F5OS metrics
platform Standard platform metrics such as memory, disk, CPU, and interface
hardware The low-level platform hardware sensors
optics The front-panel optic DDM metrics
tenant Tenant-initiated metrics such as memory, disk, CPU, and interface
datapath F5OS data-path metrics such as those generated by the FPGA and DMA
tmstat F5OS tmstat tables exported as metrics
container Docker container metrics for F5OS services
Note:
  • Support for the intrument “tenant” is provided only for BIG-IP tenants.
  • The intrument “Datapath” is applicable for F5 r5000/r10000/12000 platforms only.
This image provides a representation how the F5OS Resource includes instruments with multiple metrics:
The table lists the set of attributes that can be applied to all metrics produced by the platform.
The scope indicates which product the attribute applies to:
  • F5 - Applies to all metrics produced by F5
  • F5OS - Applies to all metrics produced by the F5OS product
Name
Value
Type
Scope
Description
host.name
<*name of host*>
string
F5
The host-name for F5OS, derived from ConfD system hostname.
f5.system.id
<*instance ID*>
string
F5
A unique instance ID per product.
f5.product.version
<*version string*>
string
F5
A version string, which represents the version of the product.
f5.product.name
<*product\_name*>
string
F5
The high-level F5 product generating the metric/log: - F5OS
  • BIGIP-Next
  • SPK
  • CNF
f5.product.type
<*v6h-hi*>
string
F5OS
The platform type.
f5.platform.serial_number
<*platform\_serial\_no*>
string
F5OS
Serial number of an appliance, blade, or controller.
f5.platform.role
<*platform\_role*>
string
F5OS
The appliance is straight-forward. However, for chassis products, the telemetry data can originate from multiple places. The role can help identify a location. - Blade - The data originated from a blade within a partition
  • Partition - The data originated from a partition-level service
  • Controller - The data originated from a system controller
f5.platform.pid
C137
string
F5OS
The platform ID
f5.platform.name
<*platform\_name*>
string
F5OS
The Platform Name - rSeries - The appliance products
  • VELOS - The chassis products
instrument.name
<*name*>
string
F5OS
F5OS Instrument name associated with the metric.
f5.data_type
<*f5os-analytics*>
string
F5
The attribute used by BIG-IP Central Manager to help direct F5OS specific metrics
f5.tenant.name
<*f5os\_tenant\_name*>
string
F5OS
The deployed tenant name
The following attributes apply for the tenant based metrics.
Name
Value
Type
Description
f5.tenant.name
<*tenant name*>
string
The name of the tenant which acts as a tenant ID
f5.tenant.image
<*image version*>
string
The tenant image version
f5.tenant.type
  • BIG-IP
  • BIG-IP Next
string
The tenant type name
Note: These metrics are relevant to Platforms.
Metric Name
Metric Type
Value Type
Attributes
Unit
f5.interface.packets
Counter
int64
interface.name="1.0"
direction="receive"
{packets}
Counter
int64
direction="transmit"
{packets}
f5.interface.bytes
Counter
int64
direction="receive"
Bytes
f5.interface.bytes
Counter
int64
Bytes
f5.interface.errors
Counter
int64
direction="receive"
{packets}
f5.interface.errors
Counter
int64
{packets}
f5os.interface.dropped
Counter
int64
direction="receive"
{packets}
Counter
int64
{packets}
f5.interface.broadcast
Counter
int64
direction="receive"
{packets}
f5os.interface.broadcast
Counter
int64
{packets}
f5os.interface.multicast
Counter
int64
direction="receive"
{packets}
f5.interface.multicast
Counter
int64
{packets}
f5os.interface.ethernet
Counter
int64
name="1.0"
state=<field>
{packets}
Reports the front-panel Optic DDM metrics.
Common Attributes include:
port.group=<string>
    -   The F5OS port group name associated with the Optic
port.name="1.0"..
-   The front-panel port number
channel=1..N
    -   For metrics which are per-channel, identifies the individual channel number
direction="transmit" | "receive"
-   An indication of transmit or receive direction
Metric Name
Metric Type
Value Type
Attributes
Unit
f5.optic.temperature
Gauge
float
port.group=<string>
port.name="1.0"
C
f5.optic.voltage
Gauge
float
port.group=<string>
port.name="1.0"
V
f5.optic.power
Gauge
float
port.group=<string>
port.name="1.0"
channel=1..N
dbm
f5.optic.tx-bias
Gauge
int64
port.group=<string>
port.name="1.0"
channel=1..N
f5.optic.los
Gauge
int64
port.group=<string>
port.name="1.0"
channel=1..N
f5.optic.tx-fault
Gauge
int64
port.group=<string>
port.name="1.0"
channel=1..N
The schema of the CPU metrics is based on the OpenTelemetry semantic conventions. For more information, see Metrics Semantic Conventions
Metric Name
Metric Type
Value Type
Attributes
Unit
system.cpu.time
Counter
int64
cpu=cpu0..cpuN
thread=0...N
state=<field>
Seconds
system.cpu.utilization
Gauge
float64
pu=cpu0...cpuN
thread=0..N
state=<field>
{percent}
The Disk IO Metrics are based on the OpenTelemetry semantic conventions. For more information, see Metrics Semantic Conventions
Metric Name
Metric Type
Value Type
Attributes
Unit
system.disk.io_time
Counter
float64
device=<name>
direction=total
Seconds
system.disk.operations
Counter
int64
device=<name>
direction=read
{operations}
Counter
int64
device=<name>
direction=write
{operations}
system.disk.io
Counter
int64
device=<name>
direction=read
Bytes
system.disk.io
Counter
int64
device=<name>
direction=write
Bytes
system.disk.merged
Counter
int64
device=<name>
direction=read
{operations}
system.disk.merged
Counter
int64
device=<name>
direction=write
{operations}
system.disk.operation_time
Counter
float64
device=<name>
direction=read
Seconds
Counter
float64
device=<name>
direction=write
Seconds
system.disk.usage
Counter
float64
device=<name>
Bytes
The Memory Metrics are based on the OpenTelemetry semantic conventions. For more information, see Metrics Semantic Conventions
Metric Name
Metric Type
Value Type
Attributes
Unit
system.memory.usage
Counter
int64
state="<*field*>"
Bytes
system.memory.utillization
Gauge
float64
state=used
{percent}
system.memory.utilization
Gauge
float64
state=platform
{percent}
Gauge
float64
state=available
{percent}
The File system Metrics are based on the OpenTelemetry semantic conventions. For more information, see Metrics Semantic Conventions
Metric Name
Metric Type
Value Type
Attributes
Unit
system.filesystem.usage
Gauge
int64
state = "free" || "total" || "used" system.device = </*dev/mapper/partition\_image-export\_chassis*> system.filesystem.mountpoint = <*/var/export/chassis*> system.filesystem.type = <*ext4*>
By
system.filesystem.utilization
Gauge
float64
state =used system.device = <*/dev/mapper/partition\_image-export\_chassis*> system.filesystem.mountpoint = <*/var/export/chassis*> system.filesystem.type = <*ext4*>
Percent
The Uptime Metrics are based on the OpenTelemetry semantic conventions. For more information, see Metrics Semantic Conventions
Metric Name
Metric Type
Value Type
Attributes
Unit
system.uptime
Counter
int64
S
The Raid Metrics are based on the OpenTelemetry semantic conventions. For more information, see Metrics Semantic Conventions
Note: Applicable for F5 r10000/12000 platforms with only two hard disks.
Metric Name
Metric Type
Value Type
Attributes
Unit
system.raid.blocks
Gauge
int64
state= "blocksTotal" || "blocks-synced"
system.raid.devices = <*nvme0n1p1,nvme1n1p1*>
system.raid.name = <*md124*>
Blocks
system.raid.state
Gauge
int64
state = "disks-total" || "disks-active" || "disks-failed" || "disks-down" || "disks-spare"
Count
system.raid.status
Gauge
int64
state = “active” || “blocks-synced”
{status}
system.raid.sync.estimation
Gauge
float64
Seconds
system.raid.sync.percent
Gauge
float64
Percent
system.raid.sync.speed
Gauge
float64
KbPerSecInterface Counter Metrics
Note: Applicable for F5 r5000/r10000/12000 platforms only.
Note: This metric is the sum of all internal tenant interfaces and independent of the F5 platform front-panel interface.
Metric Name
Metric Type
Value Type
Attributes
Unit
f5.datapath.packets
Counter
int
direction="transmit | receive"
f5.datapath.area="dma"
{packet}
f5.datapath.bytes
Counter
int
By
This table lists the attributes that are associated with the tenant-based metrics.
Metric Name Metric Type Value Type Attributes Unit
f5.tenant.cpu.utilization Gauge float64 state="<field-name>" cpu=cpuN Percent
f5.tenant.cpu.time Counter int64 state="<field-name>" cpu=cpuN s
Metric Name
Metric Type
Value Type
Attributes
Unit
f5.tenant.memory.utilization
Gauge
float64
state="<*field*>"
Percent
f5.tenant.memory.usage
Gauge
int64
state="<*field*>"
Bytes
Metric Name
Metric Type
Value Type
Attributes
Unit
f5.tenant.disk.operations
Counter
int64
device=<*name*>
direction=total
operation
Counter
int64
device=<*name*>
direction=read
operation
Counter
int64
device=<*name*>
direction=write
operation
f5.tenant.disk.io
Counter
int64
device=<*name*>
direction=read
Bytes
f5.tenant.disk.io
Counter
int64
device=<*name*>
direction=write
Bytes
f5.tenant.disk.merged
Counter
int64
device=<*name*>
direction=read
operation
Counter
int64
device=<*name*>
direction=write
operation
f5.tenant.disk.operation_time
Counter
float64
device=<*name*>
direction=read
s
Counter
float64
device=<*name*>
direction=write
s
Metric Name
Metric Type
Value Type
Attributes
Unit
f5.tenant.interface.packets
Counter
float64
interface.name="<interface-name>"
direction="receive"
packets
Counter
int64
packets
f5.tenant.interface.bytes
Counter
int64
direction="receive"
Bytes
Counter
int64
Bytes
Attributes
Metric value type
Description
container.name
string
The name of the container
container.image.name
string
The container image name
Metric Name
Metric Type
Value Type
Attributes
Unit
container.cpu.usage
Gauge
float
ns
container.memory.<*field-name*>
Gauge
float
By
container.memory.usage <*field-name*>
Gauge
float
By
container.memory.percent
Gauge
float
{percent}
container.blockio.io_service_bytes_recursive
Gauge
float
operation="read" | "write"
By
container.network.io.usage.<*field-name*>
Gauge
float
interface=<name>
By | {percent}
container.cpu.percent
Gauge
float
cpu=<name>
{percent}
  • f5os.sensor.name=<sensor name>
    Eamples:
    • Temperature:
      • Inlet
      • Outlet
      • Central
    • Voltage:
      • 12V
      • 3.3V BCM
    • Current:
      • 12V Main
      • Current In
    • Power:
      • Controller Power
      • Total Power Supply Unit (PSU) Power In
      • Total Power Supply Unit (PSU) Power Out
  • f5os.sensor.source=<component name>
    Eamples:
    • psu-[1..N]
    • fantray-[1..N]
    • psu-controller-[1..N]
    • blade-[1..N]
    • controller-[1..2]
    • platform
Metric Name
Metric Type
Value Type
Attributes
Unit
f5.sensor.temperature
Gauge
float64
sensor.name="<name of sensor>"
sensor.source="?<component name>"
C
f5.sensor.voltage
Gauge
float64
V
f5.sensor.current
Gauge
float64
A
f5.sensor.power
Gauge
float64
W
f5.sensor.humidity
Gauge
float64
{percent}
f5.sensor.fan.speed
Gauge
float64
RPM
Note: When you select instrument type as “all” and/or “metrics”, the instrument type “tmstat” is set to off and cannot be selected. You have to manualy enable the instrument “tmstat”. Using this instrument is more tailored to internal ‌F5 use cases, such as deep diagnostics.
Metric Name
Metric Type
Value Type
Attributes
Unit
f5.tmstat.<*table*>
Gauge
int
f5.tmstat.column=<*name*>
You can configure an exporter from the webUI.
  2. On the left, click SYSTEM SETTINGS > Telemetry.
    The Telemetry screen displays.
  3. Under the Telemetry exporters area, click Add.
    The Add Exporter screen displays.
  4. Enter Name of the Exporter (up to 20 characters).
    The first character in the name cannot be a number. After that, only lowercase alphanumeric characters and hyphens are allowed.
  5. For Endpoint
    • For IP Address, enter the IPv4 address, IPv6 address, or Fully Qualified Domain Name (FQDN) for an exporter.
    • For Port, enter the port number of the Server.
  6. For Enable, select True if you want to enable and send the telemetry data to the exporter or False to disable it.
  7. For Instruments, select one or more instruments for an exporter.
    Option Description
    all Reports all logs and metrics produced by the F5OS platform layer
    logs Reports all F5OS logs file through the OpenTelemetry ’log’ API
    platform-log Exports the F5OS platform log through the OpenTelemetry ’log’ API
    event-log Exports the F5OS confd event log through the OpenTelemetry ’log’ API
    metrics Report all F5OS metrics through the OpenTelemetry ‘metric’ API
    platform F5OS platform metrics such as memory, disk, cpu, interface, file system, and RAID stats
    hardware F5OS hardware sensors such as voltage, current, temperature, power, fan-speeds
    optics F5OS front-panel Optic DDM metrics
    tenant Low level tenant reported metrics such as memory, disk, cpu, interface stats
    container F5OS Per-Container metrics such as cpu, block-io, network, memory
  8. For Compression, select the compression type. By default gzip will be selected.
  9. For Attributes, specify the attributes for the exporter.
    You can then click + or x to add or remove additional attributes.
    Attributes are reference data which can be associated with the exporter. Attributes can be specified in the key & value format.
  10. For Secure input, select True to enable and configure the Transport Layer Security (TLS) to secure the connections. The default option is False.
    Note: Before you can enable TLS encryption, you must configure a key and certificate on the system.
  11. You can secure connections by using one of these methods:
    • Server Authentication only:
      • For TLS CA Certificate, paste the contents of the certificate (self-signed or from a CA) for server TLS authentication.
    • Both Server and Client Authentication
      1. For TLS CA Certificate, paste the contents of the certificate (self-signed or from a CA) for server TLS authentication.
      2. In the TLS Certificate field, paste the text of the local certificate for client TLS authentication.
      3. In the TLS Key field, paste the text of the private key for client TLS authentication.
  12. For Reload Interval, specify the duration to reload the certificate within the specified timeframe.
    Note: You can only specify the duration value in nanoseconds (ns), microseconds (us (or µs)), milliseconds (ms), seconds, minutes, and hours.
  13. Click Save & Close.
You can delete an exporter from the webUI.
    The Telemetry screen displays the existing exporter and associated details.
  3. To delete an exporter, in the Telemetry exporters area, select the exporter from the list and then click Delete.
  4. Click Save.
Attributes are reference data which can be associated with the exporter. Attributes can be specified in the key:value format. Spaces must be included between each entry. You can add attributes to all the configured exporters from the webUI.
  3. Under Telemetry Attributes, specify the attributes.
  4. Click Save.
Before configuring an exporter, you can display supported instruments from the CLI.
  3. Show the total and available instruments:
    show system telemetry instruments
    This example displays the available instruments:
    appliance-1# show system telemetry instruments
    NAME           DESCRIPTION
    all           Report all logs and metrics produced by the F5OS platform layer
    logs          Report all F5OS logs file through the OpenTelemetry 'log' API
    platform-log  Export the F5OS platform log through the OpenTelemetry 'log' API
    event-log     Export the F5OS confd event log through the OpenTelemetry 'log' API
    metrics       Report all F5OS metrics through the OpenTelemetry 'metric' API
    platform      F5OS platform metrics such as: memory, disk, cpu, interface, file system, and RAID stats
    hardware      F5OS hardware sensors such as: voltage, current, temperature, power, fan-speeds
    tenant        Low level tenant reported metrics such as: memory, disk, cpu, interface stats
    container     F5OS Per-Container metrics such as: cpu, block-io, network, memory
An exporter defines an OpenTelemetry gRPC endpoint to which the F5OS Platform will push metrics/logs.
Note: You can enable ‌Transport Layer Security (TLS) and secure the connections for telemetry streaming. Before you can enable TLS encryption, you must generate a private key and self-signed certificate.
You can configure the exporter from the CLI.
    config
  4. Configure the exporter.
    You must specify the IP address or DNS name of the server and the port number of the server on which OpenTelemetry (OTEL) is running
    system telemetry exporters exporter <*server name*> config endpoint address <*address*> port <*port number*> instruments <*instrument name*> tls sercure { false | true }
    appliance-1(config)# system telemetry exporters exporter test1 config endpoint address 10.144.74.171 port 4317 instruments [all] tls secure true
    Possible completions:
      ca-certificate    Specifies the CA Certificate content.
      certificate       Specifies the PEM-encoded telemetry client certificate (Configure for mTLS).
      key               Specifies the PEM-encoded telemetry client private key (Configure for mTLS)
      reload-interval   Specifies reload-interval in duration strings.
      <cr>
  5. You can secure the connections by using one of these methods:
    • To authenticate the server, add the certificate:
      system telemetry exporters exporter <*server name*> config ca-certificate
      Press Enter to enable multi-line mode and then paste the contents. Press Ctrl-D to exit multi-line mode.
      system telemetry exporters exporter test1 config ca-certificate
      (<string>):
      A summary to this example displays:
      appliance-1(config)# system telemetry exporters exporter test1 config endpoint address 10.144.74.171 port 4317 instruments [ all ] tls secure true ca-certificate
      (<string, min: 1 chars>):
      > -----BEGIN CERTIFICATE-----
      > MIIFmzCCA4OgAwIBAgIJAIQRlRZvPsmXMA0GCSqGSIb3DQEBCwUAMGQxCzAJBgNV
      > BAYTAlVTMRMwEQYDVQQIDApXYXNoaW5ndG9uMRAwDgYDVQQHDAdTZWF0dGxlMRQw
      > EgYDVQQKDAtGNSBOZXR3b3JrczELMAkGA1UECwwCUEQxCzAJBgNVBAMMAmNhMB4X
      > DTIzMTExMzA3NTUzNFoXDTI0MTExMjA3NTUzNFowZDELMAkGA1UEBhMCVVMxEzAR
      > BgNVBAgMCldhc2hpbmd0b24xEDAOBgNVBAcMB1NlYXR0bGUxFDASBgNVBAoMC0Y1
      > IE5ldHdvcmtzMQswCQYDVQQLDAJQRDELMAkGA1UEAwwCY2EwggIiMA0GCSqGSIb3
      > DQEBAQUAA4ICDwAwggIKAoICAQC4NiPFaDvwfajK1pLaisHrWFnji0GAiM4Dyn8C
      > ndJW5AptRr8xOPfESMvhkMq1MTp9lQCDNKVgfJuJe3xNWugVFvAMPMuTeMnjv+Xm
      > /9jzYFBCJ2ddof/8Uwd6/0X2nmAwfO+gGZZv6rviwtxt6YCPuxUWM48Mqdq5BjSQ
      > 5eSepXtMXhtubXr8VCjh1aFxAqnadOm8pykumcTUq7vnPElv/4DG5M6WL+vCpDes
      > XEjqhAp3wyOzCglew026xUBYvy3WAIxHVttd0VWP+7KNl2QlYXpJewZcUpHM917i
      > Uoui3+h66w1YrfoZTBBcdL7Lnb8v78Jg/6tBAjEcxIXRPQbM+qm1l0e6rCy0NMKP
      > i+v0wq9EUOfc4z+nMtF+ggyZlHUo6lJLr3+ZMtkBticvNpRpOZ2XjxsvjjoymZ0a
      > 7QBDeSbYtOam+UT2h1UiN4RJsQbtyUAgz9zMTyc82B2TonztVm12MrW2GuDD2+Nv
      > KdCi5trmgpmWagSFsi8dWK1qFpXUB34+83geAhp5sz5ngsQtiAWHcYbL67M86fKs
      > L9GP91p8LZm09LVzekwxbe6Bq/FM7SCHVMcK+lCLA3hTdX3PCuvjkjrXOH7zy8M7
      > R7RCmPj5hdPXxTYomGkwY1IW8JkurwukYvnfzn6pwNkRX6/1B5GZHMIi98nkA3lJ
      > /eUtKQIDAQABo1AwTjAdBgNVHQ4EFgQUTYPD7uZ2NLCxdyMdxeVQnTONkl4wHwYD
      > VR0jBBgwFoAUTYPD7uZ2NLCxdyMdxeVQnTONkl4wDAYDVR0TBAUwAwEB/zANBgkq
      > hkiG9w0BAQsFAAOCAgEARpehpSFWyKw0sPeZYk8LsiTiMhS5BX+WBIaZzGrQXW4p
      > lU9rOBtunhzjbH5Vf6bzJVL5Zi7kFIUa+8RrnY0+0+CVxRiFE3k1rOFZ7YsS1ILl
      > vQ7tVBTCRHJ6VAThlVlagYntfEI+bxTJQ3nnRzRe+znh5uqANEChZUoXX2lmDmhU
      > D+2lyzuZ9t6C8xcB2jfe0yUJeUQAdQh1x4k5Y2ssjnS4tLOa2Ly3xj3WudFHoA2D
      > kwu9myRKkJ1ruCO6DSRxi1BnfKISUOQtZ1DWaNpN/2fEzqtiW7klO9G2gwL6O/8J
      > 9cYn4HRTbA9DKITzPYs854TJnaOimn7US5hZkb1n9uy1c9cN1XfNxenHziEdG1BM
      > U7EsAmHYtf7k8N3XisKTfLEZ6AeAsqOp16Fi/ecp467DZtMnY4NXcadnj+IpIPeh
      > k6VkkayjrEZgWfcVHZ8L1vpVNTLnRuc0a3V4ioFoOGAKvoBVruQZWt0Sgtg/V/UH
      > i/otMqWYV5q366R4St55ZYfu8mdqhZljSU3Zrneco7DqTttFbWeWa3SaWhvP96VF
      > 4FTrgLyq4D6OlURqWMRbh98TxAzSbYw6cWoevRUpae5Eo0ST/c6dqjTlbq1YHr1H
      > MAhq2UPmh3/Uuc3a0dUWQ8gas0SEPFOHbnY5a/ae2cSdUV5uLR/dNsRWflZQaj4=
      > -----END CERTIFICATE-----
    • To authenticate the server and client, add the certificates and key.
      system telemetry exporters exporter <*server name*> config tls certificate
      system telemetry exporters exporter server1 config tls certificate (<string>): [Multiline mode, exit with ctrl-D.] > ... appliance-1(config-exporter-test)# config tls key (<string>): [Multiline mode, exit with ctrl-D.] > appliance-1(config-exporter-test)# config tls certificate (<string>): [Multiline mode, exit with ctrl-D.] >
      appliance-1(config)# system telemetry exporters exporter test2 config endpoint address 10.144.74.171 port 4317 instruments [ all ] tls secure true ca-certificate
      (<string>):
      > MIIFajCCA1KgAwIBAgIJAN5Vgnsykm2mMA0GCSqGSIb3DQEBCwUAMGQxCzAJBgNV
      > DTIzMTExMzEwNTgyOFoXDTI0MTExMjEwNTgyOFowcDELMAkGA1UEBhMCVVMxEzAR
      > IE5ldHdvcmtzMQswCQYDVQQLDAJQRDEXMBUGA1UEAwwOMTAuMjM4LjE1Ny4yMzcw
      > ggIiMA0GCSqGSIb3DQEBAQUAA4ICDwAwggIKAoICAQCiQiZZbGgioRHXDOw6slU8
      > 9lzikxOFmkpcr0EonT3f1o+n46oNU4PmZ7saTDp3dffU3gflLIh0eseUCJosFd8H
      > iF/OZdq38YPDCmAI4GD341Gs959qIpRYiuXzv5+11H7bUewS4Uj0ZP7ByuV+PFYS
      > +mHjRjcDXDV2kNVPwiEz/wxsuX5QP2rLH/Kepknj+ldkE9/khy2/aaWtmlVy5VaO
      > L1PRUAJh1lbT95GGpAYcCdbzay17GV0FN7uSl2/pMv74ygIvQNcs4av4l7bAvVdF
      > sGNJm/AdvruOhw2y87KKPGjgrS072c8aYkri/jJh6IW1DJ9HS+4vU7RtB9JKcbw5
      > O01gZXKWRal5VUHRg/BBiYGwRqJg2fmcKzt9YHqOTzFPvudc5S8ij4CgVmXH5lHI
      > bPQjc8dn8CE0upwDAIUKOS2tPz5PcgBCqbCG1d5NtCSbZSa8udDCQmRXZ0mwPdn9
      > wLNymUBAnZvFuzaU0Q99P1WwPK4wJrCHUdF+ETK3VY+U4pwYeyNLt82cVSeuAZD+
      > 4hBXNPHDKrsylhRn5QqhORfs+XNaUjp94zs4Uth2dxCREG3yb/AsW3q+ddjfCk51
      > 2kSy73dUudtxbErbivHSuuvmOm4flzBTgQF8C8aP1P9AEj60lyNOPY72dRMdWf2y
      > hpfogHMaqkHRNxcazhZ7GQIDAQABoxMwETAPBgNVHREECDAGhwQK7p3tMA0GCSqG
      > SIb3DQEBCwUAA4ICAQAb85rbxzosNnG+OucXVD3Cxt0VKH816ZnEvCtz9DVZfMqj
      > IpLOmIpFr5MJp4bz3459BRRsJf/TvhQaofPoxUCf1mm8Vf889mJFBFQ4eUmqpv35
      > FDZfe8cNmTsJwebHr7ubSxytJR+IMwAwirbuW656oSMX3r0ERNYxdC2VYf7rWG2a
      > EiF2zMlTAsyjfToMIIpWncata3tGxJHXMDYrl8Y4tXl20PlRR3x/2QBj/Ghud9+E
      > JYIFsdFeIMDiPyu2S3saYZS5dwb+0Fmn/0qgzut3eZuYn0TiTpPj9i0c4Zmza0aK
      > uHjI7N/lzkReAfh4KT/o3uqxLMn+6eUwc2ai8EfQ7Jw+geL0N4JDrhW7Z9Qsp+yS
      > 9Gl3qGNAyU+7kZqixcLde2+aLFZoq169Ayo7IXx/wFSBW/Lif0ZoMLKZ7OVOeawb
      > Ct1tnQ3bQZwmWa7MFdF3aaATXBy6jKfcEH0vTIa2FiCxhEbynMzw5zIcFX1GLL4l
      > SBzPKkNz7sA6EzuKJNL8LwjOndAKHGAB2EkGy4/3PKmM5yF//shRneXrJx1xd1nI
      > 9ipFxZ1e6YwxJ4K6tIiZMineKK/csA7z6tLaImQ/ldFz0S0Qws+1csgfp9VIrxtG
      > ZwIVHO/QCZe7gB6XQESbBpW6M8eKj5zqk5ZTMAGihtE7nDEe3ZXWvzV0Vr0MPQ==
  6. Commit the configuration changes.
    commit
After you configure the exporter, you can display the state of the exporter from the CLI.
  2. Display the state of a specific exporter
    show system telemetry exporters exporter <*server name*>
    When you specify an exporter, a summary to this example displays:
    appliance-1# show system telemetry exporters exporter test-tls
    state enabled
    state endpoint address 10.144.74.171
    state endpoint port 4317
    state instruments [ all ]
    state tls secure true
    state tls ca-certificate "
    state options compression gzip
You can modify the configuration of an exporter from the CLI.
    config
  4. You can use the following commands to modify the exporter configuration:
    • Disable the exporter
      system telemetry exporters exporter <*server name*> config disabled
      appliance-1(config)# system telemetry exporters exporter server1 config disabled
    • Modify option retry-enabled
      system telemetry exporters exporter <*server name*> config retry-enabled
      appliance-1(config-exporter-server1)# system telemetry exporters exporter server1 config options retry-enabled
        false  true
      appliance-1(config)# system telemetry exporters exporter server1 config options retry-enabled false
    • Modify option timeout
      system telemetry exporters exporter server1 config options timeout <*new value*>
      appliance-1(config)# system telemetry exporters exporter server1 config options timeout 10
    • Modify option compression
      system telemetry exporters exporter server1 config options compression <*new value*>
      appliance-1(config)# system telemetry exporters exporter server1 config options compression zstd
    commit
    end
  7. You can verify the state of the exporter. see Display exporter state from the CLI.
You can add, modify, or delete the instruments that are configured for an exporter from the CLI.
    config
    • Add a new instrument
      system telemetry exporters exporter <*server name*> config instruments <*instrument name*>
      appliance-1(config)# system telemetry exporters exporter server1 config instruments hardware
    • Modify the instrument
      system telemetry exporters exporter <*server name*> config instruments [<*instrument name*>]
      appliance-1(config)# system telemetry exporters exporter server1 config instruments [ optics ]
    • Delete the instrument
      no system telemetry exporters exporter <*server name*> config instruments <*instrument name*>
      appliance-1(config)# no system telemetry exporters exporter server1 config instruments platform
    commit
    end
You can add attributes to all the configured exporters from the CLI
    config
  3. You can add attributes to all the configures exporters:
    system telemetry attributes attribute <*attribute name*> <*attribute value*>
    appliance-1(config)# system telemetry attributes attribute test.key config key test.key value test.vale
    appliance-1(config-attribute-test.key)# commit
    Commit complete.
    appliance-1(config-attribute-test.key)# exit
    appliance-1(config)# exit
    appliance-1# show system telemetry attributes
    KEY       KEY       VALUE
    test.key  test.key  test.vale
    commit
    config
  4. Delete the exporter:
    A summary similar to this example displays:appliance-1(config)# no system telemetry exporters exporter server1
    commit
    end
You can monitor data and metrics related to the usage, performance, and behavior of the system from the webUI. These statistics are crucial for monitoring, managing, and optimizing the system. You can monitor the following system details:
  • System CPU Usage: Shows the measurement of CPU utilization by the system.
  • System Memory Usage: Shows the measurement of memory utilization by the system.
  • System Disk Usage: Shows the measurement of disk utilization by the system.
To monitor the system’s statistics, follow the steps below:
  2. On the left, click SYSTEM SETTINGS > System Details.
    You can now see the following statistics and status of the system.
    • System CPU Usage: Displays the vCPU’s current utilization of the system by default. However, if multiple vCPUs are available, you can select a vCPU and change the time series to view the historical data and analyze the vCPU utilization.
    • System Memory Usage: Displays the current memory utilization of the system by default. However, you can change the time series to view the historical data and analyze ‌memory utilization.
    • System Disk Usage: Displays the disk’s current utilization of the system by default. However, if multiple disks are available, you can select a disk, data type, and change the time series to view the historical data and analyze ‌memory utilization
You can monitor data and metrics related to the usage, performance, and behavior of a system from the CLI. These statistics, tenant CPU usage, memory usage, and disk usage, are crucial for monitoring, managing, and optimizing the system.
    config
  3. Show ‌tenants status and statistics.
    tenants tenant <*tenant name*> state <*action*>
    Note: You can get the stats with an average of 10 seconds, 30 seconds, 1 minute, 5 minutes, and 10 minutes.
    This example displays the tenant status and statistics for a BIG-IP tenant running on the rSeries system.
    • For CPU stats:
      appliance-1(config)# tenants tenant cbip state cpu-thread-stats average 1m-avg
      averages {
              unix-seconds 1717588320
              cpu-threads {
                  cpu-thread {
                      thread-index 0
                      busy-percent 1
                  cpu-thread {
                      thread-index 1
                      busy-percent 0
                  cpu-thread {
                      thread-index 2
                      busy-percent 0
                  cpu-thread {
                      thread-index 3
                      busy-percent 4
                  cpu-thread {
                      thread-index 4
                      busy-percent 4
                  cpu-thread {
                      thread-index 5
                      busy-percent 4
                  cpu-thread {
                      thread-index 6
                      busy-percent 4
                  cpu-thread {
                      thread-index 7
                      busy-percent 12
                  cpu-thread {
                      thread-index 8
                      busy-percent 4
                  cpu-thread {
                      thread-index 9
                      busy-percent 1
                  cpu-thread {
                      thread-index 10
                      busy-percent 4
                  cpu-thread {
                      thread-index 11
                      busy-percent 4
                  cpu-thread {
                      thread-index 12
                      busy-percent 4
    • For disk stats:
      appliance-1(config)# tenants tenant cbip state disk-stats average 1m-avg
      averages {
              unix-seconds 1717588260
              used-percent 88
              disk-list {
                  disk {
                      disk-name nvme0n1
                      total-iops 0
                      read-iops 0
                      read-bytes 148
                      write-iops 154
                      write-bytes 1691163
    • For interface stats:
      appliance-1(config)# tenants tenant cbip state interface-stats average 1m-avg
      averages {
              unix-seconds 1717588380
              interface-list {
                  interface {
                      interface-name 1.0
                      ifc-bytes-in 1466
                      ifc-bytes-out 0
                      ifc-packets-in 0
                      ifc-packets-out 0
                  interface {
                      interface-name 2.0
                      ifc-bytes-in 135
                      ifc-bytes-out 0
                      ifc-packets-in 0
                      ifc-packets-out 0
    • For memory stats:
      appliance-1(config)# tenants tenant cbip state memory-stats average 1m-avg
      averages {
              unix-seconds 1717588440
              available 8493508881
              free 1060426615
              used-percent 93
              platform-total 16107667456
              platform-used 8114811835
