Updated Date: 07/23/2026
Platform Specifications
This table lists general specifications for system features for rSeries platforms.
Item |
Specification |
Transceiver modules hot swap |
Support for hot swap of optical transceiver modules |
Power supply unit hot swap |
Support for hot swap of the power supply units (PSUs) in dual supply systems |
Jumbo frames |
Support for maximum Ethernet frame size of 9216 bytes and MTU of 9128 bytes |
This table lists hardware specifications for r2000 Series platforms.
Item |
Specification |
Dimensions |
H: 1.72 inches (4.37 cm) x W: 17.1 inches (43.43 cm) x D: 18.70 inches (47.50 cm) (per unit) 1U industry standard rack-mount chassis |
Weight |
Processor |
Communication interfaces |
4 x 25G/10G/1G SFP+/SFP28/SFP ports 4 x 10G/1G RJ45 ports 1 x 1000Base-T management port 1 x RJ45 serial console port 1 x USB 3.0 interface |
Storage drive capacity |
1 x 480 GB M.2 solid-state drive (SSD) |
Memory |
32 GB |
AC power supply unit |
1 to 2 x 250W AC; 100-240 VAC, 50/60 Hz, 5 A per cord x 2 (max 5 A total) 1 x universal power cords |
DC power supply unit |
1 to 2 x 650W DC; -48 to -60 VDC, 6 A per cord (max 6 A total) or 220 to 380 VDC, 4 A per cord (max 4 A total) Operating range: 44-72 VDC Minimum start up voltage: 44 VDC power supply unit will not start below 44 VDC. Note: power supply unit will not start below 44 VDC. |
Important: Specifications are subject to change without notification.
This table lists hardware specifications for r4000 Series platforms.
| Item | Specification |
| Dimensions | H: 1.72 inches (4.37 cm) x W: 17.1 inches (43.43 cm) x D: 18.70 inches (47.50 cm) (per unit) 1U industry standard rack-mount chassis |
| Weight |
20.0 pounds (9.07 kg) with one power supply unit (per unit)
| Processor | 1 x 16-Core Intel Atom processor |
| Storage drive capacity | 1 x 480 GB M.2 solid-state drive (SSD) |
| Memory | 64 GB |
1 to 2 x 650W DC; -48 to -60 VDC, 6 A per cord (max 6 A total) or 220 to 380 VDC, 4 A per cord (max 4 A total) Operating range: 44-72 VDC Minimum start up voltage: 44 VDC Power supply unit will not start below 44 VDC. |
This table lists power specifications for r2000 Series platforms.
| Item | Single PSU | Dual PSU |
| Idle power draw (AC power) | 110VAC input: 75W 230VAC input: 75W |
110VAC input: 85W 230VAC input: 85W |
| Idle power draw (DC/HVDC power) | 53DC input: 75W 240HVDC input: 350W |
53DC input: 85W 240HVDC input: 360W |
| Typical power draw (AC power; 50% load; temp 25°C) | 110VAC input: 95W 230VAC input: 95W |
110VAC input: 110W 230VAC input: 105W |
| Typical power draw (DC/HVDC power; 50% load; temp 25°C) | 53DC input: 95W 240VDC input: 95W |
53DC input: 110W 240VDC input: 105W |
| Maximum power draw (AC power) | 110VAC input: 115W 230VAC input: 115W |
110VAC input: 130W 230VAC input: 125W |
| Maximum power draw (DC/HVDC power) | 53DC input: 115W 240HVDC input: 115W |
53DC input: 130W 240HVDC input: 125W |
| Typical heat generated (AC power) | 110VAC input: 325 BTU/hour 230VAC input: 325 BTU/hour |
110VAC input: 380 BTU/hour 230VAC input: 360 BTU/hour |
| Typical heat generated (DC/HVDC power) | 53DC input: 325 BTU/hour 240HVDC input: 325 BTU/hour |
53DC input: 380 BTU/hour 240HVDC input: 360 BTU/hour |
| Maximum heat generated (AC power) | 110VAC input: 395 BTU/hour 230VAC input: 395 BTU/hour |
110VAC input: 445 BTU/hour 230VAC input: 430 BTU/hour |
| Maximum heat generated (DC/HVDC power) | 53DC input: 395 BTU/hour 240HVDC input: 395 BTU/hour |
53DC input: 430 BTU/hour 240HVDC input: 430 BTU/hour |
| Idle power draw (AC power) | 110VAC input: 65W 230VAC input: 65W |
110VAC input: 75W 230VAC input: 70W |
| Typical power draw (AC power; 50% load; temp 25°C) | 110VAC input: 85W 230VAC input: 85W |
110VAC input: 95W 230VAC input: 90W |
| Maximum power draw (AC power) | 110VAC input: 105W 230VAC input: 105W |
110VAC input: 110W 230VAC input: 110W |
| Typical heat generated (AC power) | 110VAC input: 295 BTU/hour 230VAC input: 295 BTU/hour |
110VAC input: 325 BTU/hour 230VAC input: 310 BTU/hour |
| Maximum heat generated (AC power) | 110VAC input: 360 BTU/hour 230VAC input: 360 BTU/hour |
110VAC input: 380 BTU/hour 230VAC input: 380 BTU/hour |
This table lists power specifications for r4000 Series platforms.
| Idle power draw (AC power) | 110VAC input: 80W 230VAC input: 80W |
110VAC input: 90W 230VAC input: 95W |
| Idle power draw (DC/HVDC power) | 53DC input: 80W 240HVDC input: 80W |
53DC input: 90W 240HVDC input: 90W |
| Typical power draw (AC power; 50% load; temp 25°C) | 110VAC input: 110W 230VAC input: 110W |
110VAC input: 120W 230VAC input: 125W |
| Typical power draw (DC/HVDC power; 50% load; temp 25°C) | 53DC input: 100W 240VDC input: 110W |
53DC input: 105W 240VDC input: 120W |
| Maximum power draw (AC power) | 110VAC input: 135W 230VAC input: 135W |
110VAC input: 150W 230VAC input: 150W |
| Maximum power draw (DC/HVDC power) | 53DC input: 135W 240HVDC input: 135W |
53DC input: 150W 240HVDC input: 145W |
| Typical heat generated (AC power) | 110VAC input: 380 BTU/hour 230VAC input: 345 BTU/hour |
110VAC input: 410 BTU/hour 230VAC input: 360 BTU/hour |
| Typical heat generated (DC/HVDC power) | 53DC input: 380 BTU/hour 240HVDC input: 380 BTU/hour |
53DC input: 410 BTU/hour 240HVDC input: 410 BTU/hour |
| Maximum heat generated (AC power) | 110VAC input: 465 BTU/hour 230VAC input: 445 BTU/hour |
110VAC input: 515 BTU/hour 230VAC input: 445 BTU/hour |
| Maximum heat generated (DC/HVDC power) | 53DC input: 465 BTU/hour 240HVDC input: 465 BTU/hour |
53DC input: 495 BTU/hour 240HVDC input: 495 BTU/hour |
| Idle power draw (AC power) | 110VAC input: 70W 230VAC input: 70W |
| Typical power draw (AC power; 50% load; temp 25°C) | 110VAC input: 105W 230VAC input: 100W |
| Maximum power draw (AC power) | 110VAC input: 135W 230VAC input: 130W |
| Typical heat generated (AC power) | 110VAC input: 360 BTU/hour 230VAC input: 345 BTU/hour |
This table lists platform environmental operating specifications.
Item |
Specification |
Operational temperature |
32 to 104°F (0 to 40°C) |
Operational relative humidity |
5% to 85% (40°C) non-condensing Up to 93% (40°C) non-condensing for a maximum of 96 hours |
Non-operational temperature |
-40 to 158°F (-40 to 70°C) |
Non-operational relative humidity |
5% to 93% (40°C) non-condensing |
This table lists acoustic levels and operational altitude specifications for F5 rSeries platforms.
| Specification type | Detail | Value | Notes |
| Acoustic | Sound power | 79.87 dBA | A-weighted Sound Power at 27°C full system load. Declared A weighted 82.87 |
| Altitude | Operational | 6,000 Feet | Per Telcordia GR-63-CORE, section 4.1.3: This unit is functional when installed at elevations between 60m (197 feet) below sea level and 1800m (6000 feet) above sea level at the aisle ambient temperatures of 40°C. |
| Non-operational | 40,000 Feet |
This table lists airflow movement specifications for F5 r2000/r4000 Series platforms.
Note: Fan tray airflow measurements are taken at 100% duty cycle and in open air.
| Platform | Value (max) |
| r2000/r4000 | 92 CFM |
