Manual Chapter : System Settings
Applies To:
  • F5OS-C
    1.1.4, 1.1.3, 1.1.2, 1.1.1, 1.1.0
System Settings
You can access system settings in the system controller webUI and chassis partition webUI but the settings are different in the two areas. The following table lists the available system settings in the system controller and the chassis partition webUIs:
System controller webUI Chassis partition webUI
Alarms and Events Alarms and Events
Controller Management High Availability
System Inventory Log Settings
Log Settings File Utilities
File Utilities Device Certificate
Time Settings General
Device Certificate
System Reports
Licensing
General
The Alarms & Events screen is available in both the system controller webUI and chassis partition webUI. This screen lists the alert information for all performance and network indicators that have currently crossed a performance or health threshold. Use this screen to identify the specific object affected.
  1. Log in to the VELOS system controller webUI or the chassis partition webUI using an account with admin access.
  2. On the left, click SYSTEM SETTINGS > Alarm & Events.
  3. The following actions are available:
      • To refresh the alarms or events list, click the Refresh icon on the right of the screen.
  • To display events result by time preference, click the down arrow next to Refresh icon, select a value from the list. The default value is one hour. For example, selecting five minutes would display any event that occurred in the last five minutes.
  • To display events by severity, select a value from the Severity list. The default value is WARNING.
    Severity Description
    Emergency Emergency system panic messages
    Alert Serious errors that require administrator intervention
    Critical Critical errors, including hardware and file system failures
    Error Non-critical, but possibly important, error messages
    Warning Warning messages that should be logged and reviewed
    Notice Messages that contain useful information, but may be ignored
    Informational Messages that contain useful information, but may be ignored
    Debug Verbose messages used for troubleshooting
It is a good idea to create a backup of the system controller configuration before you update the system. From the system controller CLI, type:
system database config-backup name ccs_backup
Configuration file backups are stored in /mnt/var/confd/configs. To export the configuration file, use File Utilities or the file export command.
You can update system controller software while the system is up and running. The software update is applied to both of the system controllers.
Note: Updating the system controller software reboots both system controllers and might impact production traffic.
  1. Log in to the system controller webUI using an account with admin access.
  2. On the left, click SYSTEM SETTINGS > Controller Management > .
  3. For Update System Controller Software:
    • To install a full F5OS version release, select Bundled.
    • To install F5OS and service version releases independently, select Unbundled.
  4. For ISO Image, select the full version release ISO image from the drop-down.
    This field is available when Bundled is selected.
  5. For Base OS Version, select the F5OS version from the drop-down.
    This field is available when Unbundled is selected.
  6. For Service Version, select the service version release from the drop-down.
  7. Click Save.
The software on the system controllers is updated.
The system controllers work together as a redundant pair. The default mode for system controller high availability (HA) is Auto, which automatically selects the system controller that is best suited at the time as the active controller, and fails over as needed. You should not need to change the default configuration, but you can change the configuration as described here, or initiate a failover from the active controller to the standby.
  3. If, for some reason, you want to change the way high availability is working, for the Preferred Node field, select System Controller 1 or System Controller 2 to act as an active system controller or choose Auto (recommended).
    Note: Changing the Preferred Node configuration creates a failover event, and ends the session if selecting the system controller currently acting as the standby. Wait 30 seconds and then start a new session with either the floating IP address or the active system controller IP address after the change has completed.
    Hardware health conditions of the system controllers always take precedence. If one of the controllers is not healthy, the chassis partition will ignore the preference and synchronize with the healthy system controller.
  4. To force a failover to occur now, click Failover.
    Note: The Failover button is available only when Preferred Node field is set to Auto.
    You would only do this if for some reason you want to change which controller is being used from the current active controller to the current standby controller.
High availability is already implemented for chassis partitions on the VELOS system. You should not need to change the default configuration, but you can change it as described here, or initiate a failover from the active chassis partition to the standby.
  1. Log in to the chassis partition webUI using an account with admin access.
  2. On the left, click SYSTEM SETTINGS > High Availability.
  3. For Preferred Node, select the system controller to run the active instance of the chassis partition, or choose Auto to let the system decide.
    Note: Using Auto is recommended.
  4. If you really want to indicate a preference and have selected one of the system controllers (not auto):
    1. Set Auto Failback to Enabled.
    2. In the Failback Delay field, type the number of seconds to delay before initiating the failback.
  5. To force a failover to occur now, click Failover.
The System Inventory screen is available in the system controller webUI. You can display an inventory all of the system components on the VELOS system that includes system controllers, blades, power supply units (PSU), PSU controller, fan tray, and LCD. The inventory includes the component name, status, part number, and serial number.
  2. On the left, click SYSTEM SETTINGS > System Inventory.
The system inventory is displayed and you can review the information about the components on the VELOS system. An example is shown here.
The Log Settings screen is available in both the system controller webUI and chassis partition webUI. Here you can add and display configured remote log servers. You can also change the log severity level for individual software components and services.
  2. On the left, click SYSTEM SETTINGS > Log Settings.
  3. To add access to a Remote Log Server, click Add.
  4. For the Host field, type either the IPv4 IP address or the Fully Qualified Domain Name (FQDN) of the remote server.
  5. In the Port field, type the port number of the remote server.
    The default port value is 514.
  6. For Protocol, select UDP or TCP to choose between TCP or UDP input.
  7. From the Facility list, select LOCAL0.
    F5OS supports only the LOCAL0 logging facility. All logs are directed to this facility, and it is the only one that you can use for remote logging.
  8. In the Severity list, select the severity level of the messages to log.
  9. Click Save & Close to add the remote log server.
  10. On the Log Settings screen, review the software component log levels for individual software components, adjust them as needed. Click Save if you made changes.
    The log levels determine at what level events (and all higher levels) are logged for each service. Informational is the default so all except debug-level events are logged.
  11. To delete a remote log server, select the server and click Delete.
File Utilities are available in both the system controller or chassis partition webUIs. You can use File Utilities to import, export, and/or delete files asynchronously depending on which directory you select to work in. All file transfers are done using HTTPS protocol.
On the system controller, you can import files into
  • /var/import/staging
  • /var/export/chassis/import
  • /var/shared
On the chassis partition, you can import files into
  • /var/f5/partition/shared
  • /var/f5/partition/configs
  • /var/f5/partition/IMAGES
You can export files from all the directories in both the system controller and chassis partition webUIs; and delete files from the ../shared directories on both.
  2. On the left, click SYSTEM SETTINGS > File Utilities.
  3. From the Base Directory list, browse the directories and click subfolders to view their contents and the commands that are available from each one.
    From a subfolder, click the left arrow next to the path to navigate back to the main folder.
  4. To import a file, click Import.
    1. In the popup, type the URL of the file to import.
    2. Provide the Username and Password only if required by the remote host.
    3. Select Ignore Certificate Warnings if you want to skip warnings when importing files (such as if the remote host does not have a valid CA signed certificate).
    4. Click Import File to begin the import.
  5. To export a file, select the file and click Export.
    1. In the popup, type the Server URL for where to export the file.
    3. Select Ignore Certificate Warnings if you want to skip warnings when importing files.
    4. Click Export File to begin the export.
  6. To delete a file, select the file and click Delete.
    On the system controller, you can delete files from /var/shared, and on the chassis partition from /var/f5/partition/shared.
You can view the status of a file transfer operation to view its progress and see if it was successful. If an operation fails, hover over the warning icon to see the error that occurred.
Note: A runtime error is displayed in the File Transfer status area, if an invalid operation is performed.
The Time Settings screen is available in the system controller webUI. After the license of the VELOS system is activated, you can configure the Network Time Protocol (NTP) servers and time zone. The NTP server ensures that the VELOS system clock is synchronized with Coordinated Universal Time (UTC). You can specify a list of servers that you want the system to use when updating the time on network systems.
  2. On the left, click SYSTEM SETTINGS > Time Settings.
  3. To synchronize the system clock with an NTP server, for NTP Service, click Enable.
    The NTP Service is set to Disable, by default.
  4. To specify an NTP server, click Add.
  5. In the NTP Server field, type the IPv4 IP address or the Fully Qualified Domain Name (FQDN) of the NTP server.
    Note: If specifying an FQDN, a resolvable DNS server must be configured for the system.
  6. To set the time zone, select the time zone area from the Locations list.
  7. Click Save.
Before you can install device certificates, LDAP needs to be enabled as an authentication method in the system controller or partition in which you are working in USER MANAGEMENT > Auth Settings.
If using LDAP with transport layer security (TLS) for user authentication, you have the option of requiring TLS Certificate Validation in the Auth Settings. You can view or replace TLS device certificates in both the system controller webUI and chassis partition webUI. The device certificates apply only to the area in which you are working.
  2. On the left, click SYSTEM SETTINGS > Device Certificate.
  3. To display a TLS Certificate or TLS Key that was previously installed, click Show.
    A text area opens and displays the certificate or key.
  4. To install a TLS Certificate, paste the text of the local certificate for client TLS authentication.
  5. To install a TLS Key, paste the text of the local certificate for client TLS authentication.
  6. Click Save.
If you have any concerns about your system operation, you can use the qkview utility to generate a system report to collect configuration and diagnostic information from the VELOS system. The QKView report contains machine-readable (JSON) diagnostic data and combines the data into a single compressed tar.gz format file. You can upload the QKView file to F5 iHealth where you can get help to verify proper operation of the system, with troubleshooting and understanding any issues you may be having, and ensure that the system is operating at its maximum efficiency.
You can generate a system controller QKView from the system controller webUI, and a chassis partition QKView from the chassis partition webUI. Both reports contain diagnostic information such as configuration data, log files, and platform information.
  2. On the left, click SYSTEM SETTINGS > System Reports.
    The System Reports screen displays. A list of QKView reports that were previously generated is shown along with any reports that were uploaded to iHealth.
  3. To generate a system report, click Generate QKView in the upper right corner of the screen.
    Note: The system runs many commands to collect the diagnostic information, so generating the report might affect its performance.
    It takes a few minutes for the system to finish creating the report and list it on the screen. The QKView Status says File generated successfully when it is done.
  4. If you want to upload the report to the F5 iHealth server, select the check box next to the QKView name, and click Upload to iHealth.
    To do the upload, the system must have DNS configured, and have Internet access to these services using the HTTPS/443 remote service/port:
    • api.f5.com
    • ihealth-api.f5.com The QKView tar file is uploaded to iHealth where you can get help to diagnose the health and proper operation of the system.
  5. To delete a QKView report, select it and click Delete.
You can license the VELOS system from the system controller webUI. There is one license per VELOS system, which is used by the partitions, and any Classic BIG-IP tenants.
There are two ways to license the system:
  • Automatically: If your system is connected to the Internet, use the Automatic method to prompt the VELOS system to contact the F5 license server and activate the license.
  • Manually: If your system is not connected to the Internet, use the Manual method to retrieve the activation key from a system that is connected to the Internet, and transfer it to the VELOS system.
Related information
VELOS system licensing overview
You can license the VELOS system automatically from the webUI, as long as the system has Internet access.
  2. On the left, click SYSTEM SETTINGS > Licensing.
  3. For the Base Registration Key field, the registration key is auto-populated.
    You can choose to overwrite this field with a new registration key.
  4. For the Add-On Keys field, the associated add-on keys are auto-populated.
    You can click + or x to add or remove additional add-on keys.
    Note: To add add-on keys to a licensed system, type the keys in the Add-On Keys field and click Reactivate.
  5. For the Activation Method, select Automatic.
  6. Click Activate.
    The End User License Agreement (EULA) displays.
  7. Click Agree to accept the EULA, .
The system is now licensed. If a base registration key or add-on key fails to activate, try re-activating the license or contact support.f5.com.
You can use the webUI to manually license the VELOS system for systems without access to the Internet.
  5. For the Activation Method, select Manual.
  6. For the Device Dossier, click Get Dossier.
    The VELOS system refreshes and displays the dossier.
  7. Copy the dossier text into the Device Dossier field.
  8. Click Click here to access F5 Licensing Server.
    The Activate F5 Product page displays.
  9. Paste the dossier in the Enter Your Dossier field.
  10. Click Next.
    The license key text displays.
  11. Copy the license key text.
    Alternatively, you can use the F5 license activation portal at activate.f5.com/license.
  12. In the License Text field, paste the license key text.
  13. Click Activate.
  14. Click Agree to accept the EULA.
You activate the VELOS system license from the system controller CLI. There is one license per VELOS system, which is used by the partitions, and any Classic BIG-IP tenants.
Related information
For automatic VELOS system licensing, the system needs to be able to connect to the F5 licensing server either through the Internet or another means of networking. You need to have the Base Registration Key (five sets of characters separated by hyphens) provided by F5, and any add-on keys (two sets of 7 characters separated by a hyphen) that you have purchased. The Base Registration Key with associated add-on keys are pre-installed on a new VELOS system.
You can activate the VELOS system license automatically using the command-line interface (CLI).
  1. Connect using SSH to the system controller floating management IP address.
  2. Log in to the command line interface (CLI) of the system controller using an account with admin access.
    When you log in to the system, you are in user (operational) mode.
  3. Change to config mode.
    config
    The CLI prompt changes to include (config).
  4. Apply a license to the chassis.
    system licensing install [registration-key <*key*>]
    The registration key is optional. If it is not included, the system uses the one already pre-installed. If no registration key is found, you receive an error.
    Example:
    syscon-1-active(config)# system licensing install registration-key
     I1234-12345-12345-12345-1234567
    result License installed successfully.
  5. Apply any add-on keys.
    system licensing install add-on-keys <*add-on-keys*>
    Example:
     add-on-keys [1234567-1234567 2345678-2345678 3456789-3456789]
    This example enables the additional features associated with the 3 add-on-keys along with the entitlements of the base registration key.
The VELOS system is licensed. The license and any add-on keys apply to all partitions and classic BIG-IP tenants.
You can activate the VELOS system license manually using the command-line interface (CLI).
    config
  4. Get the system dossier.
    Example: system licensing get-dossier [registration-key XXXXX-XXXXX-XXXXX-XXXXX-XXXXXXX]
    The dossier for the system is displayed.
  5. Get the license file using the dossier output you just received by going to the F5 siteactivate.f5.com/license/dossier.jsp.
  6. Install the license.
    1. Copy the license file text.
    2. Issue the command:
      system licensing manual-install license <Press Enter>
    3. Paste the license file content in multiline mode, then press Crtl-D.
    Example:
    syscon-1-active(config)# system licensing manual-install license
    Value for 'license' (<string>):
    [Multiline mode, exit with ctrl-D.]
The VELOS system is licensed. The license applies to all of the partitions and classic BIG-IP tenants.
You can display the license of a VELOS system using the CLI.
  3. Display the system license in a simple form:
    show system licensing
    Example:
    syscon-1-active#show system licensing
     system licensing license
            Licensed version    7.4.0
            Registration Key    Gxxxx-xxxxx-xxxxx-xxxxx-xxxxxxxx
            Licensed date       2021/01/01
            License start       2021/04/16
            License end         2022/01/01
            Service check date  2021/12/02
            Platform ID         F101
            Appliance SN        chs600144s
            Active Modules
            Local Traffic Manager, CX410 (Exxxxxx-xxxxxx)
            Best Bundle, CX410
            APM-Lite
            Carrier Grade NAT (AFM ONLY)
            Max Compression, CX410
            Rate Shaping
            Max SSL, CX410
            Advanced Firewall Manager, CX410
            Access Policy Manager, Base, CX410
            Anti-Virus Checks
            Base Endpoint Security Checks
            Firewall Checks
            Machine Certificate Checks
            Network Access
            Protected Workspace
            Secure Virtual Keyboard
            APM, Web Application
            App Tunnel
            Remote Desktop
            Advanced Routing, CX410
            Advanced Web Application Firewall, CX410
            DNS, Max QPS, CX410
  4. To display the raw license file content that was received from the F5 license server:
    show running-config system licensing
The VELOS system can be run in appliance mode. Appliance mode adds a layer of security by restricting user access to root and the bash shell. When enabled, the root user cannot log in to the device by any means, including from the serial console.
You can enable appliance mode at each of the following levels:
  • System controller
  • Chassis partition
  • Tenant
Appliance mode is disabled at all levels, by default. You can enable it using the webUI or the CLI. The appliance mode option for system controllers and partitions is available to users with admin access under SYSTEM SETTINGS > General in the respective webUIs. For tenants, it is available in the chassis partition webUI under TENANT MANAGEMENT > Tenant Deployments.
Following are the effects of enabling appliance mode at each of the different levels.
System controller appliance mode
  • Root or bash access is disabled on both system controllers.
  • The AOM menu on the system controllers is unavailable.
  • Users can access the system controllers through the webUI or CLI.
  • Console access: Root or bash access is disabled on both system controller consoles. Users can log in to the system controller CLI from the console using an admin account.
Chassis partition appliance mode
  • Root access to the partition is disabled by all means. Bash access is disabled for admin and operator accounts.
  • The AOM menu is unavailable on the blades in the partition.
  • Users can access the partition through the webUI or the CLI.
  • Console access is disabled on all blades in a partition. Users cannot log in to blades (only the root account is generally present on blades. The root account gets disabled on blades).
Tenant appliance mode
  • Root access to the tenant is disabled by all means. Bash access is disabled for users (with a terminal shell flag enabled) inside the tenant.
  • Users can access the tenant only through the webUI of the CLI.
  • Tenant console access: Users can log in to the CLI from the virtual console using an admin account (with a terminal shell flag enabled).
Enable appliance mode if you want to disable all root and bash shell access.
Note: For greater security, it is highly recommended that you configure the system controllers and chassis partitions to run in appliance mode.
From the system controller webUI, appliance mode disables root and bash access to the controllers. From the chassis partition webUI, appliance mode limits access to the specific partition you are logged in to. Use the following procedure to enable or disable the appliance mode for system controllers and partitions.
Note: The appliance mode option for tenants is available in the chassis partition webUI under TENANT MANAGEMENT > Tenant Deployments.
  2. On the left, click SYSTEM SETTINGS > General.
  3. For Appliance Mode, select Enable to enable it, or Disable to disable it.
  4. Click Save.
If you are having an issue with a chassis partition (such as unusually high CPU or memory usage or lockup), it is possible that rebooting a blade in the partition may help to resolve the issue.
When there is a problem, the system sends alerts that you would see on the dashboard or on the Alarms & Events screen. Blade status of Not ready for a prolonged time on the General screen can also indicate the need to reboot the blade. However, you should rarely have to reboot a blade, because typically if the VELOS system needs to reboot a blade, it will do so automatically without administrator intervention. F5 recommends working with customer support if you think a blade reboot is necessary.
  3. Review the status of each of the blades in the partition.
    The Reboot button will not be available for slots that do not have blades present, or for blades that are currently being rebooted.
  4. If you have tenants running on the partition you may want to warn users that their service may be interrupted temporarily.
  5. If you decide that a reboot is necessary, click Reboot on the right of the slot containing the blade you want to reboot.
    It takes a few minutes for the blade to reboot. The status will show Reboot in progress, then Not ready, and when reboot is complete, it says Ready.
