Updated Date: 08/12/2026
System Settings
You can access system settings in the system controller webUI and chassis partition webUI. Each webUI provides different settings.
This table lists the available system settings in the system controller and chassis partition webUIs:
| System controller webUI | Chassis partition webUI |
| Alarms and Events | Alarms and Events |
| Controller Management | Cluster Details |
| System Inventory | High Availability |
| Log Settings | Log Settings |
| File Utilities | File Utilities |
| Time Settings | SNMP Configuration |
| SNMP Configuration | Configuration Backup |
| Configuration Backup | General |
| Licensing | |
| Software Install Status | |
| General |
You can view active system alarms and events in the system controller webUI and CLI.
The Alarms & Events screen is available in both the system controller and chassis partition webUIs. This screen lists the alert information for all performance and network indicators that have currently crossed a performance or health threshold. Use this screen to identify the specific object that is affected.
Log in to the VELOS system controller webUI or the chassis partition webUI using an account with admin access.
On the left, click SYSTEM SETTINGS > Alarm & Events.
Choose from one of these actions:
- To refresh the alarms or events list, click the Refresh icon on the right of the screen.
- To display events result by time preference, click the down arrow next to Refresh icon, select a value from the list. The default value is one hour. For example, select five minutes to display any event that occurred in the last five minutes.
- To display events by severity, select a value from the Severity list. The default value is WARNING.
Option Description Emergency Emergency system panic messages Alert Serious errors that require administrator intervention Critical Critical errors, including hardware and file system failures Error Non-critical, but possibly important, error messages Warning Warning messages that should be logged and reviewed Notice Messages that contain useful information, but might be ignored Informational Messages that contain useful information, but might be ignored Debug Detailed messages used for troubleshooting
You can view information about active system alarm conditions from the system controller CLI.
Connect using SSH to the system controller floating management IP address.
Log in to the command line interface (CLI) of the system controller using an account with admin access.
When you log in to the system, you are in user (operational) mode.
View a list of active system alarm conditions.
show system alarms | tabThis example shows a power supply unit (PSU) redundancy fault:
syscon-1-active# show system alarms ID RESOURCE SEVERITY TEXT TIME CREATED –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––- 65796 psu-controller WARNING PSU redundancy fault detected 2021-07-01-11:11:11.992270499 UTC 65793 psu-2 ERROR PSU fault detected 2021-07-01-11:11:11.999825828 UTC
You can configure system controller high availability (HA) from Controller Management screen on the system controller webUI. The system controllers work together as a redundant pair. The default mode for system controller HA is Auto, which automatically selects the system controller that is best suited at the time as the active controller and fails over only as needed.
The High Availability screen on the chassis partition webUI includes options for configuring chassis partition HA. High availability is already implemented for chassis partitions on the VELOS system.
You should not need to change system controller high availability (HA) to something other than the default configuration (Auto), but you can opt to change the configuration or initiate a failover from the active controller to the standby from the system controller webUI.
Log in to the VELOS system controller webUI using an account with admin access.
On the left, click SYSTEM SETTINGS > Controller Management.
For the Preferred Node field, select System Controller 1 or System Controller 2 to act as an active system controller, or choose Auto (recommended).
Note: Changing the Preferred Node configuration creates a failover event and ends the session if you select the system controller that is currently acting as the standby. Wait 30 seconds and then start a new session with either the floating IP address or the active system controller IP address after the change has completed.
Hardware health conditions of the system controllers always take precedence. If one of the system controllers is not healthy, the chassis partition will ignore the preference and synchronize with the healthy system controller.
To force a failover to occur immediately, click Failover.
Note: The Failover button is available only when Preferred Node field is set to Auto.
You would do this only if you want the current standby system controller to become the active system controller.
The System Inventory screen on the system controller webUI enables you to see an inventory of all components on the VELOS system, including the system controllers, blades, power supply units (PSU), PSU controller, fan tray, and LCD. The inventory includes the component name, status, part number, and serial number.
You can view an inventory of all of the system components on the VELOS system, including the system controllers, blades, power supply units (PSU), PSU controller, fan tray, and LCD from the system controller webUI. The inventory includes the component name, status, part number, and serial number.
On the left, click SYSTEM SETTINGS > System Inventory.
The system inventory displays, and you can review the information about the components on the VELOS system. An example is shown here.
The system controller and chassis partition webUIs include options for configuring remote log servers and the log severity level for individual software components and services.
From the webUIs you can generate a system report, or QKView file, to collect configuration and diagnostic information from the VELOS system if you have any concerns about your system operation. The QKView file contains machine-readable (JSON) diagnostic data and combines the data into a single compressed tar.gz format file. You can upload the QKView file to F5 iHealth where you can get help to verify proper operation of the system and get help with troubleshooting and understanding any issues you might be having and ensure that the system is operating at its maximum efficiency.
You can view event logs and configure secure remote logging from the CLI. You can also send host log files, which are in the /var/log directory, as well as audit.log files to the remote server from the CLI.
You can add and display information about configured remote log servers from either the system controller or chassis partition webUIs. You can also change the log severity level for individual software components and services.
On the left, click SYSTEM SETTINGS > Log Settings.
To add access to a Remote Log Server, click Add.
In the Server field, enter the IPv4 address, IPv6 address, or fully qualified domain name (FQDN) of the remote server. After the remote log server is saved, you cannot modify the server address.
In the Port field, enter the port number of the remote server.
The default port value is 514.
For Protocol, select UDP or TCP to choose between TCP or UDP input. When the TCP protocol is selected, the Authentication field displays.
From the Facility list, select LOCAL0.
F5OS supports only the LOCAL0 logging facility. All logs are directed to this facility, and it is the only one that you can use for remote logging.
From the Severity list, select the severity level of the messages to log.
Option Description Emergency Emergency system panic messages Alert Serious errors that require administrator intervention Critical Critical errors, including hardware and file system failures Error Non-critical, but possibly important, error messages Warning Warning messages that should be logged and reviewed Notice Messages that contain useful information, but might be ignored Informational Messages that contain useful information, but might be ignored Debug Detailed messages used for troubleshooting -
Click Save & Close.
On the Log Settings screen, review the software component log levels for individual software components and adjust them as needed. Click Save if you made changes.
The log levels determine at what level events (and all higher levels) are logged for each service. Informational is the default so all except debug-level events are logged.
To delete a remote log server, select the server and click Delete.
The system logs events to the velos.log file located in the /var/log_controller directory. To list files and view the contents of log files, you use the file command from either the system controller or chassis partition CLI.
Connect using SSH to the system controller floating management IP address or chassis partition management IP address.
Log in to the command line interface (CLI) of the system controller or chassis partition using an account with admin access.
List all files in the log directory.
file list path [ log/confd/ | log/controller/ | log/host/ }This example shows an excerpt of the contents of the
log/controller/directory:syscon-1-active# file list path log/controller/ entries { name afu-cookie date Wed Jun 15 19:52:37 UTC 2022 size 33B } entries { name cc-confd date Wed Jun 15 20:25:49 UTC 2022 size 581KB } entries { name cc-confd-hal date Wed Jun 15 19:52:10 UTC 2022 size 0B } ... -
Show the contents of a log file.
file show [ log/confd/<*filename*> | log/controller/<*filename*> | log/host/<*filename*> ]This example shows the contents of the
log/controller/velos.logfile and uses themoreoption to paginate the output:syscon-1-active# file show log/controller/velos.log | more 2022-04-21T08:18:28-07:00 localhost.localdomain notice boot_marker: ---===[ BOOT-MARKER ]===--- 2022-04-21T08:19:39-07:00 controller-1.chassis.local notice boot_marker: ---===[ BOOT-MARKER ]===--- 2022-04-21T15:27:39.925830+00:00 controller-1 alert-service[8]: priority="Notice" version=1.0 msgid=0x2201000000000001 msg="Alert Service Starting..." version="3.10.2" date="Fri Apr 8 09:42:10 2022". 2022-04-21T15:27:39.926245+00:00 controller-1 alert-service[8]: priority="Info" version=1.0 msgid=0x6602000000000005 msg="DB is not ready". 2022-04-21T15:27:39.926264+00:00 controller-1 snmp-trapd[9]: priority="Notice" version=1.0 msgid=0x2101000000000007 msg="SNMP Trap Service Starting..." version="3.2.3" date="Fri Apr 8 09:43:28 2022". 2022-04-21T15:27:39.926274+00:00 controller-1 alert-service[8]: priority="Info" version=1.0 msgid=0x6602000000000005 msg="DB is not ready". -
Show only the most recent entries in a log file.
file tail [ log/confd/<*filename*> | log/controller/<*filename*> | log/host/<*filename*> }This example shows the last ten lines of the
velos.logfile and uses the-foption to append output as the file grows:syscon-1-active# file tail -f log/controller/velos.log 2022-06-16T23:24:36.170220+00:00 controller-1 switchd[8]: priority="Notice" version=1.0 container="VCC-SWITCHD" msgid=0x1001000000000485 msg="Linkstatus change" PORT="1/mgmt0" LINKSTAT="DOWN". 2022-06-16T23:24:36.176481+00:00 controller-1 vcc-lacpd[82]: priority="Info" version=1.0 msgid=0x330100000000004e msg="" info_str="check_if_op_modify(): new oc_if_oper_status: 2 (1:UP 2:DOWN ... )". 2022-06-16T23:24:36.176820+00:00 controller-1 vcc-lacpd[82]: priority="Info" version=1.0 msgid=0x330100000000004e msg="" info_str="check_if_op_modify(): new oc_eth_port_speed: ns: 1857063266 id: 1980508219 ". 2022-06-16T23:24:36.267589+00:00 controller-1 switchd[8]: priority="Notice" version=1.0 container="VCC-SWITCHD" msgid=0x1001000000000485 msg="Linkstatus change" PORT="1/mgmt0" LINKSTAT="DOWN". 2022-06-16T23:24:36.425971+00:00 controller-1 vcc-lacpd[82]: priority="Info" version=1.0 msgid=0x330100000000004e msg="" info_str="CCLacpdWriteHdlr::delete_member(memberName=1/mgmt0) from ConfD". 2022-06-16T23:24:36.434091+00:00 controller-1 vcc-lacpd[82]: priority="Info" version=1.0 msgid=0x330100000000004e msg="" info_str="InterfaceCmObj::modifyOp: if_name=1/mgmt0 mode=FULL DUPLEX status=DOWN speed=10000#012". 2022-06-16T23:24:36.434371+00:00 controller-1 vcc-lacpd[82]: priority="Info" version=1.0 msgid=0x330100000000004e msg="" info_str="InterfaceCmObj::modifyOp: if_name=1/mgmt0 mode=FULL DUPLEX status=DOWN speed=0#012". 2022-06-16T23:25:09.324530+00:00 controller-1 platform-hal[8]: priority="Info" msg="NEBS is assumed to be true as chassis SEEPROM NEBS option couldn't be read" interface="job-2648493" apogeeUuid="a519fa20-ece4-11ec-a487-024264410634" $parent.jobId=0 $parent.apogeeUuid="a519fa20-ece4-11ec-a487-024264410634" $parent.treeUuid="90151e75-edcb-11ec-a487-024264410634" $parent.appKey="hal" actionKey="GET:chassis/nebs-capable" jobId=2648493 jobTreeUuid="90151e75-edcb-11ec-a487-024264410634" 2022-06-16T23:25:09.399391+00:00 controller-1 platform-hal[8]: priority="Info" msg="NEBS is assumed to be true as platform SEEPROM NEBS option couldn't be read" interface="job-2648493" actionKey="GET:chassis/nebs-capable" jobId=2648493 jobTreeUuid="90151e75-edcb-11ec-a487-024264410634" apogeeUuid="a519fa20-ece4-11ec-a487-024264410634" $parent.jobId=0 $parent.apogeeUuid="a519fa20-ece4-11ec-a487-024264410634" $parent.treeUuid="90151e75-edcb-11ec-a487-024264410634" $parent.appKey="hal" 2022-06-16T23:25:09.429431+00:00 controller-1 platform-hal[8]: priority="Info" msg="NEBS is assumed to be true as platform SEEPROM NEBS option couldn't be read" interface="job-2648493" actionKey="GET:chassis/nebs-capable" jobId=2648493 jobTreeUuid="90151e75-edcb-11ec-a487-024264410634" apogeeUuid="a519fa20-ece4-11ec-a487-024264410634" $parent.jobId=0 $parent.apogeeUuid="a519fa20-ece4-11ec-a487-024264410634" $parent.treeUuid="90151e75-edcb-11ec-a487-024264410634" $parent.appKey="hal" _
You can use File Utilities to import, export, download, or delete files asynchronously depending on which directory you select to work in. All file transfers are done using the HTTPS protocol.
You can import a file from an external server into the system controller or chassis partition from either the webUI or the CLI. HTTPS is the supported protocol. The remote host should be an HTTPS server with PUT/POST enabled and have a valid CA-signed certificate.
Note: If you want to import the contents of a tar file, you need to extract the contents first before you can import them onto the F5 system.
You can import files into these directories on a system controller :
- images/staging
- configs
You can import files into these directories on a chassis partition:
- configs
- images/import
- images/staging
- images/tenant
You can export a file from a system controller or chassis partition to an external server from either the webUI or the CLI. HTTPS is the supported protocol. The remote host should be an HTTPS server with PUT/POST enabled and have a valid CA-signed certificate.
You can export files in these directories from a system controller:
- configs
- log/confd
- log/controller
- log/host
- diags/core
- diags/crash
- diags/shared
- images/import
- images/staging
You can export files in these directories from the chassis partition:
- configs
- diags/core
- diags/shared
- images
- log
You can download files in these directories from a system controller to your local workstation from the webUI:
- configs
- diags/core
- diags/crash
- diags/shared
- log/confd
- log/controller
You can download files in these directories from a chassis partition to your local workstation from the webUI:
- configs
- diags/core
- diags/shared
- log
You can upload files in these directories from your local workstation to a system controller from the webUI:
- configs
- images/staging
You can upload files in these directories from your local workstation to a chassis partition from the webUI:
- configs
- images
You can delete files (to which you have file permissions) on a system controller or a chassis partition only from the diags/shared or configs directories from either the webUI or the CLI.
File Utilities are available in both the system controller and chassis partition webUIs. You can use File Utilities to import, export, download, upload, or delete files asynchronously depending on which directory you select to work in. All file transfers are done using the HTTPS protocol.
On the left, click SYSTEM SETTINGS > File Utilities.
From the Base Directory list, browse the directories and click subfolders to view their contents and the commands that are available from each one.
From a subfolder, click the left arrow next to the path to navigate back to the main folder.
To import a file, click Import.
In the popup, enter the URL of the file to import.
Provide the Username and Password only if required by the remote host.
Select Ignore Certificate Warnings if you want to skip warnings when importing files (such as if the remote host does not have a valid CA-signed certificate).
Click Import File to begin the import.
To export a file, select the file and click Export.
In the popup, enter the Server URL for where to export the file.
Select Ignore Certificate Warnings if you want to skip warnings when importing files.
Click Export File to begin the export.
To upload or download a file:
Select the file and click Upload or Download.
The selected file will be uploaded or downloaded.
To delete a file, select the file and click Delete.
On the system controller and chassis partition, you can delete files from
diags/shared.
You can view the status of a file transfer operation to view its progress and see if it was successful. If an operation fails, hover over the warning icon to see the error that occurred.
Note: A runtime error displays in the File Transfer status area, if an invalid operation is performed.
MIB files can be managed from the File Utilities page in both the system controller and chassis partition webUIs. You can use File Utilities to export or download MIB files. File transfers are done using the HTTPS protocol.
From the Base Directory list, select mibs.
To export a MIB file, select the file and click Export.
To download a file:
Select the file and click or Download.
The selected file will be downloaded.
You can view the contents of a file from either the system controller or chassis partition CLI.
View the contents of a file.
file show <*local-file-path*>This example shows how to view the contents of the
velos.logfile:default-1# file show log/velos.log 2022-02-26T18:23:05.160009+00:00 controller-1(p1) partition-bladesd[7]: priority="Info" version=1.0 msgid=0x6602000000000005 msg="DB is not ready". 2022-02-26T18:23:05.161038+00:00 controller-1(p1) tcpdumpd-master[10]: priority="Notice" version=1.0 msgid=0x5402000000000002 msg="tcpdumpd-master starting" VERSION="1.3.18" DATE="Wed Feb 10 17:04:45 2021". 2022-02-26T18:23:05.161047+00:00 controller-1(p1) tcpdumpd-master[10]: priority="Notice" version=1.0 msgid=0x5402000000000004 msg="tcpdumpd-master args." ARGS="/usr/bin/tcpdumpd_master". 2022-02-26T18:23:05.161053+00:00 controller-1(p1) tcpdumpd-master[10]: priority="Notice" version=1.0 msgid=0x5402000000000004 msg="tcpdumpd-master args." ARGS="-r". 2022-02-26T18:23:05.161057+00:00 controller-1(p1) tcpdumpd-master[10]: priority="Notice" version=1.0 msgid=0x5402000000000004 msg="tcpdumpd-master args." ARGS="1". 2022-02-26T18:23:05.161062+00:00 controller-1(p1) tcpdumpd-master[10]: priority="Notice" version=1.0 msgid=0x5402000000000004 msg="tcpdumpd-master args." ARGS="-l". 2022-02-26T18:23:05.161067+00:00 controller-1(p1) partition-bladesd[7]: priority="Info" version=1.0 msgid=0x6602000000000005 msg="DB is not ready". ...
You can import a file from an external serve onto your system from either the system controller or chassis partition CLI.
Import a file.
file import [ remote-port <*port-number*> } username <*user*> password <*password*> remote-host <*ip-address-or-fqdn*> remote-file <*remote-file-path*> remote-url <*full-remote-url*> local-file <*local-file-path*> [insecure] web-token <*remote-system-token*>Note: The insecure option ignores certificate warnings during the transfer.
This example shows how to import a file to the system controller:
file import username admin password remote-url https://files.company.com/images/BIGIP-1x.x.x.x-x.x.xxx.ALL-F5OS.qcow2.zip local-file images/stagingThis example shows how to import a file to the chassis partition:
file import username admin password remote-url https://files.company.com/images/BIGIP-1x.x.x.x-x.x.xxx.ALL-F5OS.qcow2.zip local-file imagesNote: When importing a file using the
remote-urlargument, you must wrap the URL in double quotes (""). This prevent special characters from being incorrectly interpreted as shell commands. For example:remote-url "https://example.com/file-path?params"Example: Transfer a file named {}myfile.iso{} from the remote URL
https://files.example.comon port 443 to the images/staging directory on the system:``` file import local-file images/staging remote-url "https://files.example.com/images.myfile.iso" remote-port 443 protocol https ``` -
Return to user (operational) mode.
end -
Optionally, you can check the file transfer status.
file transfer-status file-name <*local-file-path*>
You can export files to an external server from your system from either the system controller or chassis partition CLI.
Export a file.
file export insecure local-file <*local-file-path*> protocol { https | scp | sftp } remote-file <*remote-file-path*> remote-host <*ip-address-or-fqdn*> remote-port <*port-number*> remote-url <*ip-address-or-fqdn*> username <*user*> web-token <*remote-system-token*>
You can delete files from either the system controller or chassis partition CLI.
Delete a file.
file delete file-name <*local-file-path*>
You can configure Network Time Protocol (NTP) for the VELOS system. An NTP server ensures that the system clock is synchronized with Coordinated Universal Time (UTC). The system also provides authentication support for NTP, which can enhance security by ensuring that the system sends time-of-day requests only to trusted NTP servers. You can also configure the time zone and set the time and date manually, if NTP is disabled. You can use either thesystem controller CLI or webUI to configure time settings.
After the VELOS system license is activated, you can configure Network Time Protocol (NTP) servers, including authentication support for NTP, time zone, and manual configuration of date and time, if NTP is disabled. The NTP server ensures that the system clock is synchronized with Coordinated Universal Time (UTC). You can specify a list of servers that you want the system to use when updating the time on network systems. You can configure time settings for the system from the system controller webUI.
On the left, click SYSTEM SETTINGS > Time Settings.
To synchronize the system clock with an NTP server, for NTP Service, select Enabled.
The NTP Service is set to Disabled by default.
To set the time and date manually:
For NTP Service, select Disabled.
In the Manual Time & Date Settings area, click the calendar to set the date and time.
To use authentication support for NTP:
For NTP Authentication, select Enabled.
The NTP Authentication is set to Disabled by default.
For NTP Keys, click Add.
The Add NTP Key screen displays.
For Key ID, type an identifier used by the client and server to designate a secret key.
The client and server must use the same key ID.
For Key Type, select the encryption type used for the NTP authentication key.
The default value is F5_NTP_AUTH_SHA256.
Select from these options:
- F5_NTP_AUTH_MD5
- F5_NTP_AUTH_SHA1
- F5_NTP_AUTH_SHA256
- F5_NTP_AUTH_SHA384
- F5_NTP_AUTH_SHA512
For Key Value, paste the text of the NTP authentication key.
Click Save & Close.
To specify an NTP server, from NTP Servers:
Click Add.
For NTP Server, type the IPv4 address, IPv6 address, or Fully Qualified Domain Name (FQDN) of the NTP server. This information will be displayed in the Name column of the table on the Time Settings screen.
Note: If specifying an FQDN, you must configure a resolvable DNS server for the system. The resolved IP address will display in the NTP Server column of the table on the Time Settings screen. If the FQDN is unresolvable, this will be indicated in the NTP Server column, although this could be a transitional state.
Note: If specifying an IPv4 or IPv6 address, the address will display in both the Name and the NTP Server columns.
Set iburst Mode to True if necessary. By default, it is set to False.
Select a Key ID, if you have defined an NTP key, select it from the list.
Click Save & Close.
To set the time zone, from Locations, select the time zone region.
Click Save & Close.
You can manually configure the date and time for your system from the CLI.
Change to config mode.
configThe CLI prompt changes to include
(config). -
Change the system date and/or time.
Note: You can opt to change only the time or only the date by including only the relevant option (either time or date).
system set-datetime date <*YYYY-MM-DD*> time <*HH:MM-SS*>In this example, you change the system date to 2022-01-01 and the system time to be 12:01:00:
syscon-1-active# system set-datetime date 2022-01-01 time 12:01:00
The system date and time are now updated.
You can configure Network Time Protocol (NTP) for your VELOS system from the system controller CLI.
Note: If you want to enable NTP authentication, see Configure NTP authentication from the CLI.
(config). -
Enable NTP.
system ntp config enabled -
Add an NTP server.
system ntp servers server <*ip-address*>In this example, you configure an NTP server at pool.ntp.org:
syscon-1-active(config)# system ntp servers server pool.ntp.org -
Commit the configuration changes.
commit -
end -
Verify that NTP is enabled and a server is configured.
syscon-1-active# show system ntp system ntp state enabled system ntp state enable-ntp-auth false system ntp servers server pool.ntp.org state address pool.ntp.org state port 123 state version 4 state association-type SERVER state iburst false state prefer false state stratum 4 state root-delay 32 state root-dispersion 45 state offset 0 state poll-interval 8 state authenticated false
You can configure Network Time Protocol (NTP) authentication for your VELOS system from the system controller CLI. NTP authentication enhances security by ensuring that the system sends time-of-day requests only to trusted NTP servers.
(config). -
Enable NTP.
Enable NTP authentication.
system ntp config enable-ntp-auth true -
Add the key associated with your server to the system.
system ntp ntp-keys ntp-key <*public-key-id*> config key-id <*secret-key-id*> key-type [ F5_NTP_AUTH_MD5 | F5_NTP_AUTH_SHA1 | F5_NTP_AUTH_SHA256 | F5_NTP_AUTH_SHA384 | F5_NTP_AUTH_SHA512 ] key-value HEX:<*ntp-auth-key-value*>Important: The ID, key type, and key value on this client system must match the server exactly.
syscon-1-active(config)# system ntp ntp-keys ntp-key 11 config key-id 11 key-type F5_NTP_AUTH_SHA1 key-value HEX:E27611234BB5E7CDFC8A8ACE55B567FC5CA7C890 -
Add an NTP server and associate the key ID you added with the server.
system ntp servers server <*ip-address*>In this example, you configure an NTP server at the IP address pool.ntp.org:
syscon-1-active(config)# system ntp servers server pool.ntp.org syscon-1-active(config-server-pool.ntp.org)# config key-id 11 -
commit -
end -
Verify that NTP with authentication is enabled and a server is configured.
syscon-1-active# show system ntp servers system ntp servers server pool.ntp.org state address pool.ntp.org state port 123 state version 4 state association-type SERVER state iburst false state prefer false state stratum 8 state root-delay 0 state root-dispersion 0 state offset 251333 state poll-interval 6 state key-id 11 state authenticated true
Before VELOS systems can exchange data with one another, they need to exchange device certificates, that is, digital certificates and keys used for secure communication.
If you are using LDAP with transport layer security (TLS) for user authentication, you can choose to require TLS Certificate Validation in the authentication settings. You can add a certificate and key into the system, and when you create a certificate signing request (CSR), it saves the generated key and certificate to these directories:
system/aaa/tls/config/keysystem/aaa/tls/config/certificate
When you install an SSL certificate, you also install a certificate authority (CA) bundle, which is a file that contains root and intermediate certificates. The CA bundle and server certificate complete the SSL chain of trust.
You can replace TLS device certificates, and select or configure CA certificate bundles from the webUI.
You can create a self-signed certificate from either the system controller or chassis partition webUI.
On the left, click SYSTEM SETTINGS > Certificate Management.
In the Self-Signed Certificate area, click Create Certificate.
For Name, type the common name of the certificate.
For Email, type the contact email for the certificate.
For City, type the city or locality.
For State, type the state, county, or region.
For Organization, type the full name of the certificate originator organization.
For Unit, type the organizational unit or division.
For Version, type the certificate version. The default value is 1.
For Days Valid, type the number of days for which the certificate is valid. The default value is 30.
For Key Type, select RSA or ECDSA.
For Store TLS, select whether to store the key and certificate in system/aaa/tls/config/key and system/aaa/tls/config/certificate. The default value is False.
Click Save.
Before you can install device certificates, you must enable LDAP as an authentication method in the system controller or chassis partition in which you are working (USER MANAGEMENT > Auth Settings).
You can view or replace TLS device certificates from either the system controller or chassis partition webUI. The device certificates apply only to the area in which you are working.
To display a TLS Certificate or TLS Key that was previously installed, click Show.
A text area opens and displays the certificate or key.
To install a TLS Certificate, paste the text of the local certificate for client TLS authentication.
To install a TLS Key, paste the text of the local certificate for client TLS authentication.
Click Save.
You can create a Certificate Signing Request (CSR) from either the system controller or chassis partition webUI.
In the Certificate Signing Request area, click Create CSR.
For Country, type the country.
Click Save.
You can add or delete a CA bundle from either the system controller or chassis partition webUI.
In the CA Bundles area, click Add.
For Name, type the bundle name.
For TLS CA Certificate, paste the certificate text.
Click Save.
To delete a CA bundle, under CA Bundles, click the name of the bundle in the table and click Delete.
You can configure TLS device certificates from the CLI.
You can create a private key and a self-signed certificate from either the system controller or chassis partition CLI.
(config). -
Create a private key and self-signed certificate.
system aaa tls create-self-signed-cert name <name> email <email-address> city <city> region <region> country <country> organization <org-name> unit <org-unit> version <cert-version> days-valid <number> key-type { rsa | ecdsa } store-tls { true | false }The store-tls option stores the private key and self-signed certificate in system/aaa/tls/config/key and system/aaa/tls/config/certificate instead of returning in the CLI output.
This example creates a private key and self-signed certificate with city, country, days valid, email, key type, name, organization, region, unit and version options specified, and with store TLS set to false:
syscon-1-active(config)# system aaa tls create-self-signed-cert city Seattle country US days-valid 365 email jdoe@company.com key-type ecdsa name Godzilla organization "Company" region Washington unit DEV version 1 curve-name prime239v2 store-tls false response -----BEGIN EC PRIVATE KEY----- MHECAQEEHiyJEVihDTnVi+v9RjfK3LhZ2PdSOXZFMJf3lyXaoaAKBggqhkjOPQMB BaFAAz4ABHFISUTEi8wEdG0iBF3iqTi5m5b62xUSbhOJrXR8d0S6h+anvpo9xrH3 QKbVuacF7ZSNMj2tX/wyqVNePg== -----END EC PRIVATE KEY----- -----BEGIN CERTIFICATE----- MIICAzCCAa4CCQCR5RKtuBFcxTAKBggqhkjOPQQDAjCBjTELMAkGA1UEBhMCVVMx EzARBgNVBAgMCldhc2hpbmd0b24xEDAOBgNVBAcMB1NlYXR0bGUxEzARBgNVBAoM CkY1IE5ldG9ya3MxEDAOBgNVBAsMB1NXRElBR1MxETAPBgNVBAMMCEdvZHppbGxh MR0wGwYJKoZIhvcNAQkBFg5qLm1vb3JlQGY1LmNvbTAeFw0yMTAzMjcwMjE2NTFa Fw0yMjAzMjcwMjE2NTFaMIGNMQswCQYDVQQGEwJVUzETMBEGA1UECAwKV2FzaGlu Z3RvbjEQMA4GA1UEBwwHU2VhdHRsZTETMBEGA1UECgwKRjUgTmV0b3JrczEQMA4G A1UECwwHU1dESUFHUzERMA8GA1UEAwwIR29kemlsbGExHTAbBgkqhkiG9w0BCQEW DmoubW9vcmVAZjUuY29tMFUwEwYHKoZIzj0CAQYIKoZIzj0DAQUDPgAEcUhJRMSL zAR0bSIEXeKpOLmblvrbFRJuE4mtdHx3RLqH5qe+mj3GsfdAptW5pwXtlI0yPa1f /DKpU14+MAoGCCqGSM49BAMCA0MAMEACHh38OAyBBjAsVRBklBXZUIuynHq3/tr4 3VUQsMtYHQIeeP3vCrRm2qjPtK62QwtbkqDA9h2qTvuDj6uYL8EI -----END CERTIFICATE----- -
commit
Before you can enable TLS encryption, you must have already configured a key and certificate on the system.
You can configure a TLS key and certificate from either the system controller or chassis partition CLI.
(config). -
Configure a certificate.
system aaa tls config certificate- Press Enter to enable multi-line mode and press ctrl-D to exit multi-line mode.
(<string>): [Multiline mode, exit with ctrl-D.] > ...- Enter the certificate value.
commit -
Configure a key.
system aaa tls config key- Press Enter to enable multi-line mode and press ctrl-D to exit multi-line mode.
(<string>): [Multiline mode, exit with ctrl-D.] > ...- Enter the key value.
commit -
end -
Verify that the certificate is configured.
show system aaa tls state certificatesyscon-1-active# show system aaa tls state certificate response Certificate: Data: Version: 3 (0x2) Serial Number: 322234828 (0x1334e9cc) Signature Algorithm: sha256WithRSAEncryption Issuer: C=US, ST=WA, L=Seattle, O=MyCompany, OU=IT, CN=localhost.localdomain/emailAddress=root@localhost.localdomain Validity Not Before: Mar 18 21:40:28 2020 GMT Not After : Mar 16 21:40:28 2030 GMT Subject: C=US, ST=WA, L=Seattle, O=MyCompany, OU=IT, CN=localhost.localdomain/emailAddress=root@localhost.localdomain Subject Public Key Info: Public Key Algorithm: rsaEncryption Public-Key: (2048 bit) Modulus: 00:bc:ba:b9:8d:51:c7:c9:fe:81:86:52:ea:ef:08: bf:af:68:df:dc:22:6d:a3:23:fa:a5:5b:cd:89:3e: be:fb:cb:92:c4:bc:d7:a6:a5:f3:8b:6b:84:fa:b4: 31:39:88:8b:9a:96:2a:35:1c:3f:ee:23:4a:25:8f: bf:ca:ae:fa:e2:38:5d:9f:43:9d:18:c2:8f:1f:f7: 27:a7:75:a1:12:71:2f:ec:8f:37:e2:a6:74:cc:59: d4:c4:68:26:0c:0d:b6:b0:92:76:38:59:86:e1:54: 40:0e:0e:5d:6e:d6:e7:21:07:94:9e:43:6d:f0:50: 25:5a:68:64:39:fe:a6:df:6d:3f:f8:3c:69:9b:68: 5d:e7:36:88:5c:67:5a:02:01:99:e3:2c:d9:08:cc: d5:9e:1c:cd:46:28:3a:85:76:59:fb:b3:f1:61:bc: 4f:03:57:2c:20:5d:6c:1d:11:1e:56:30:b2:91:67: 99:32:3f:d3:08:6d:4f:cd:a3:8d:f6:e6:34:9c:87: 04:8e:f2:79:f2:8c:1f:cc:1a:8b:2c:25:cf:b4:0c: c7:73:93:e4:49:d5:03:00:eb:1f:90:3c:04:c3:59: 10:90:c9:dd:29:32:cb:27:9f:04:37:f5:05:20:f9: 79:32:c1:50:66:76:1d:6d:2d:78:95:16:d2:65:7b: 4c:f1 Exponent: 65530 (x10001) Signature Algorithm: sha256WithRSAEncryption 47:21:0e:06:80:ab:df:05:9f:04:80:9f:d6:db:b9:2e:c8:d7: 39:8b:ac:6a:cf:cc:7b:5b:64:5c:59:2c:72:fe:57:d5:46:91: 0a:d4:40:0d:42:c1:95:a6:69:d9:1e:36:ac:d1:dd:f4:a1:b0: 08:3c:71:09:31:57:1a:0b:33:83:13:17:99:84:e4:70:82:85: f3:72:c7:fa:ba:0e:1a:fe:55:a1:ce:f7:96:2b:39:ef:4d:7a: 7a:23:71:44:01:c1:6c:10:58:e8:5f:6b:a8:b6:70:cc:8f:65: c8:cd:7b:aa:4b:e2:6a:bc:1c:fe:59:8f:c8:85:08:f0:46:67: 8d:15:a6:01:d0:a3:a2:fd:9c:db:c5:5b:51:07:6f:db:59:f8: bc:ba:9d:4a:30:ea:a7:7c:0c:fb:bb:9a:ea:c9:c2:a4:c1:82: e3:b8:2e:57:cd:32:6a:b1:a8:95:75:e3:82:8a:ea:c2:f8:37: c4:6f:a2:b4:e5:82:6c:3a:5d:c1:1f:a7:8e:da:7d:4c:51:d1: 49:36:da:97:31:4a:64:92:bf:bb:85:e3:bd:67:16:79:fe:53: 92:df:a8:3f:dc:8c:4e:e4:7c:b9:5e:ba:d6:ab:3d:7d:29:59: 01:27:d9:ca:52:10:58:60:00:02:19:f9:1d:74:07:5c:0d:f7: 5e:c2:d6:82
You can configure a Certificate Revocation List (CRL) entry from either the system controller or chassis partition CLI.
(config). -
To configure a CRL entry.
system aaa tls crls crl <crl-name>In this example, you configure a CRL named “bbb”:
syscon-1-active(config)# system aaa tls crls crl bbb- Press Enter to enable multi-line mode and press ctrl-D to exit multi-line mode.
Value for 'config revocation-key'(<string>): [Multiline mode, exit with ctrl-D.] > ...- Enter the Key value.
commit -
To delete a CRL entry.
no system aaa tls crls crl <crl-name>In this example, you delete a CRL entry named “bbb”:
syscon-1-active(config)# no system aaa tls crls crl bbb -
commit -
end -
View the CRLs currently on the system.
show system aaa tls crls crlThis example shows the CRLs currently on the system:
syscon-1-active# show system aaa tls crls crl DATE NAME ADDED -------------------- *name* 3/11/2021
You can create a text-based certificate signing request (CSR) from either the system controller or chassis partition CLI.
(config). -
Create a CSR.
system aaa tls create-csr name <name> email <email-address> city <city> region <region> country <country> organization <org-name> unit <org-unit> version <cert-version>This example creates a CSR with name, email, organization, and unit options specified:
syscon-1-active# (config): system aaa tls create-csr name company.com email dev@company.com organization "Company" unit engineering response -----BEGIN CERTIFICATE REQUEST----- MIIC0zCCAbsCAQEwgY0xCzAJBgNVBAYTAlVTMRMwEQYDVQQIEwpXYXNoaW5ndG9u MRAwDgYDVQQHEwdTZWF0dGxlMRQwEgYDVQQKFAtGNV9OZXR3b3JrczEUMBIGA1UE CxMLZGV2ZWxvcG1lbnQxGTAXBgkqhkiG9w0BCQEWCmRldkBmNS5jb20xEDAOBgNV BAMTB3Rlc3Rjc3IwggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEKAoIBAQCinnAV Dv/G6+qbiBVO7zIPmFFatYcrzdUnvpTGXfPuh6VBRqcW90jJy12FwtYOL8P6mED+ gfjpxRWe+vjnztjZSIDpyh7Dn+F3MRF3zkgnSKlYKI9qqzlRHRAwi2U7GfujeR5H CXrJ4uxYK2Wp8WVSa7TWwj6Bnps8Uldnj0kenBJ1eUVUXoQAbUmZQg6l+qhKRiDh 3E/xMOtaGWg0SjD7dEQij5l+8FBEHVhQKEr52d4OifR62/MZSnPw2MY5OJ69p2Wn k7Fr7m4I5z9lxJduYDNmiddVilpWdqRaCB2j29XCmpVJduF2v6EsMx693K18IJ1h iRice6oKL7eoI/NdAgMBAAGgADANBgkqhkiG9w0BAQUFAAOCAQEAGjWSAqKUPqMY eLlSDamuLAR+ckia5r/TITqamMN+m8TqQI8Pk0tAnwHCl8HHS+4cI8QuupgS/3aU ls7OtxceoQZ1VFX2sQFkrDJFe0ewZQLm5diip5kxFrnap0oA0wRy84ks0wxeiCWD New3hgSXfzyXI0g0auT6KNwsGaO8ZuhOX3ICNnSLbfb00aYbhfI9jKopXQgZG/LO pOct33fdpf/U6kQA9Rw/nzs3Hz/nsVleOrl3TH1+9veMMF+6eq8KKPpbYKh9bhA+ pYI3TtbZHuyRyQbq/r4gf4JkIu/PGszzy/rsDWy+b9g9nXMh1oFj+xhTrBjBk8a2 0ov+Osy2iA== -----END CERTIFICATE REQUEST----- -
commit
You can add or delete a CA bundle from either the system controller or chassis partition CLI.
(config). -
To add a CA bundle.
system aaa tls ca-bundles ca-bundle <ca-bundle-name> config name <ca-bundlename> content- Press Enter to enable multi-line mode and press ctrl-D to exit multi-line mode.
In this example, you add a CA bundle named “test_caaaa”:
syscon-1-active(config)# system aaa tls ca-bundles ca-bundle test_caaaa config name test_caaaa content -
commit -
To delete a CA bundle.
no system aaa tls ca-bundles ca-bundle <ca-bundle-name>In this example, you delete a CA bundle named “test_caaaa”:
syscon-1-active(config)# no system aaa tls ca-bundles ca-bundle test_caaaa -
commit
Simple Network Management Protocol (SNMP) is an industry-standard protocol that enables you to use a standard SNMP management system to remotely manage network devices. VELOS systems support SNMPv1, SNMPv2c, and SNMPv3. You can configure the system from both the CLI and webUI.
You can use SNMP to monitor VELOS systems at both the system controller and chassis partition levels. For more comprehensive monitoring, configure your system at both levels from the CLI or webUI. SNMP traps always send from the active system controller’s fixed management IP address as the source IP address.
SNMP support is available in different ways, depending on which F5OS software version you are using. On VELOS systems, SNMP is available from both the system controller and chassis partition CLIs and webUIs.
F5 recommends using the newer system snmp commands, which include support for SNMP versions 1, 2c, and 3. For more information on the older commands, see:
F5OS-C software version |
Older CLI (v1/v2c only) |
Newer CLI (v1/v2c/v3) |
webUI |
1.5.0 |
SNMP-COMMUNITY-MIB SNMP-NOTIFICATION-MIB SNMP-TARGET-MIB SNMP-VIEW-BASED-ACM-MIB SNMPv2-MIB |
system snmp communities system snmp engine-id system snmp targets system snmp users |
SYSTEM SETTINGS > SNMP Configuration |
Before you configure SNMP access for VELOS systems:
- Add the SNMP manager IP address to the system allow list. For more information, see Allow list overview.
- Add descriptions to front-panel interfaces. For more information, see Configure an interface from the CLI.
- Add descriptions to management interfaces. For more information, see Configure management IP addresses from the CLI.
- Add descriptions to LAGs, if needed. For more information, see Configure a static LAG interface from the CLI.
- Download the F5 MIB files from File Utilities in the system controller or chassis partition webUI (on the left, click SYSTEM SETTINGS > File Utilities, and then from Base Directory, select mibs, select a
.tar.gzfile, and click Download). - Configure a DNS name server if you would like to use a fully-qualified domain name (FQDN) instead of an IP address for the SNMP trap destination. For more information, see Configure DNS from the webUI.
You can view SNMP information in the /log/system/snmp.log file. You can download the log file to your local workstation from the File Utilities screen in the system controller or chassis partition webUI (on the left, click SYSTEM SETTINGS > File Utilities, and then from Base Directory, select log/system, select snmp.log, and click Download).
For more information about managing files from the system controller or chassis partition webUI or CLI, see File utilities overview.
SNMPWALK is an application on an SNMP management system that performs SNMP GETNEXT requests to query a network device for information. You can provide an object identifier (OID) to specify which portion of the object identifier space to search using GETNEXT requests. The SNMP management system queries all variables in the subtree below the specified OID, displays these values to the user, and stops when it returns results that are no longer inside the range of the specified OID.
The IDs display in text format when the corresponding MIB is loaded in your SNMP management system. If the MIB is not loaded, the walk displays in OID format.
To more accurately map these system OIDs, you must download the F5-OS-SYSTEM-MIB.mib file and load it into your SNMP management system. To download the F5 MIB files, use File Utilities in the system controller or chassis partition webUI (on the left, click SYSTEM SETTINGS > File Utilities, and then from Base Directory, select mibs, select a .tar.gz file, and click Download).
You can activate a license for the VELOS system from either the system controller CLI or webUI. There is one license per VELOS system, which is used by the chassis partitions and any tenants.
There are two ways to license the system:
- Automatically
- If your system is connected to the internet, use the Automatic method to prompt the system to contact the F5 license server and activate the license.
- Manually
- If your system is not connected to the internet, use a management workstation that is connected to the internet to retrieve an activation key from F5 and then transfer it to the system.
Important:
Adding or reactivating a license on an active VELOS system might impact traffic on tenantsrunning on chassis partitions. Traffic processing will stop briefly on the tenants, and then restart automatically. This occurs when the tenant receives a new or reactivated license causing a configuration reload on the tenants. For more information, see these other references:
- VELOS Systems: Installation and Upgrade at Documentation - F5OS-C and VELOS
- K31810358: Activating the license on a VELOS system causes a brief traffic disruption on tenants
- K7752: Licensing the BIG-IP system
- For information about BIG-IP Next licensing, also see the documentation on my.f5.com and clouddocs.f5.com.
You can license the system automatically from the webUI, as long as the system has internet access.
On the left, click SYSTEM SETTINGS > Licensing.
For the Base Registration Key field, the registration key is auto-populated.
You can choose to overwrite this field with a new registration key.
For the Add-On Keys field, the associated add-on keys are auto-populated.
You can click + or x to add or remove additional add-on keys.
Note: To add add-on keys to a licensed system, enter the keys in the Add-On Keys field and click Reactivate.
For the Activation Method, select Automatic.
Click Activate.
The End User License Agreement (EULA) displays.
Click Agree to accept the EULA, .
The system is now licensed. If a base registration key or add-on key fails to activate, try re-activating the license or contact support.f5.com.
You can use the system controller webUI to manually license the VELOS system for systems without access to the internet.
For the Activation Method, select Manual.
For the Device Dossier, click Get Dossier.
The VELOS system refreshes and displays the dossier.
Copy the dossier text into the Device Dossier field.
Click Click here to access F5 Licensing Server.
The Activate F5 Product page displays.
Paste the dossier in the Enter Your Dossier field.
Click Next.
The license key text displays.
Copy the license key text.
Alternatively, you can use the F5 license activation portal at activate.f5.com/license.
In the License Text field, paste the license key text.
Click Activate.
Click Agree to accept the EULA.
You can view information about the software license activated on your system, including license activation and expiration dates, service check date, and licensed modules, from either the system controller or chassis partition webUIs.
View the license information for the system.
For automatic VELOS system licensing, the system needs to be able to connect to the F5 licensing server either through the internet or another means of networking. You need to have the Base Registration Key (five sets of characters separated by hyphens) provided by F5, and any add-on keys (two sets of 7 characters separated by a hyphen) that you have purchased. The Base Registration Key with associated add-on keys are pre-installed on a new VELOS system.
You can activate the VELOS system license automatically from the system controller CLI.
(config). -
Apply a license to the chassis.
system licensing install registration-key <*key*>The registration key is optional. If it is not included, the system uses the one that is already pre-installed. If no registration key is found, you receive an error.
This example applies a specified base registration license to the system:
syscon-1-active(config)# system licensing install registration-key I1234-12345-12345-12345-1234567 result License installed successfully. -
Apply any add-on keys.
system licensing install add-on-keys <*add-on-keys*>This example enables the additional features associated with the three specified add-on-keys, along with the entitlements of the base registration key:
syscon-1-active(config)# system licensing install add-on-keys [1234567-1234567 2345678-2345678 3456789-3456789] result License installed successfully.
The VELOS system is licensed. The license and any add-on keys apply to all partitions and tenants.
You can activate the VELOS system license manually from the system controller CLI.
(config). -
Get the system dossier.
system licensing get-dossier [registration-key XXXXX-XXXXX-XXXXX-XXXXX-XXXXXXX]The registration key is optional. If it is not included, the system uses the one already pre-installed. If no registration key is found, you receive an error.
The dossier for the system displays.
Get the license file using the dossier output you just received by going to the F5 siteactivate.f5.com/license/dossier.jsp.
Install the license.
Copy the license file text.
Run the manual install command and press Enter:
system licensing manual-install license -
Paste the license file content in multiline mode, then press Ctrl+D.
syscon-1-active(config)# system licensing manual-install license Value for 'license' (<string>): [Multiline mode, exit with ctrl-D.] > -
The VELOS system is licensed. The license applies to all of the chassis partitions and tenants.
You can display the license of a VELOS system from the system controller CLI.
Display the system license in a simple form.
show system licensingA summary similar to this example displays:
syscon-1-active# show system licensing system licensing license Licensed version 7.4.0 Registration Key Gxxxx-xxxxx-xxxxx-xxxxx-xxxxxxxx Licensed date 2021/01/01 License start 2021/04/16 License end 2022/01/01 Service check date 2021/12/02 Platform ID F101 Appliance SN chs600144s Active Modules Local Traffic Manager, CX410 (Exxxxxx-xxxxxx) Best Bundle, CX410 APM-Lite Carrier Grade NAT (AFM ONLY) Max Compression, CX410 Rate Shaping Max SSL, CX410 Advanced Firewall Manager, CX410 Access Policy Manager, Base, CX410 Anti-Virus Checks Base Endpoint Security Checks Firewall Checks Machine Certificate Checks Network Access Protected Workspace Secure Virtual Keyboard APM, Web Application App Tunnel Remote Desktop Advanced Routing, CX410 Advanced Web Application Firewall, CX410 DNS, Max QPS, CX410 -
Display the raw license file content that was received from the F5 license server.
show running-config system licensing
You can run the system in appliance mode. Appliance mode adds a layer of security removing user access to Root and Bash. Enabling appliance mode disables all Root and Bash shell access for the system.
You can enable appliance mode at each of these levels:
- System
- Tenant
Appliance mode is disabled at all levels, by default. You can enable it from the webUI or the CLI. The appliance mode option for the system is available to users with admin access under SYSTEM SETTINGS > General in the webUI. For tenants, it is available in the webUI under TENANT MANAGEMENT > Tenant Deployments.
These are the effects of enabling appliance mode at each of the different levels.
System-level appliance mode
- Root or Bash access is disabled on the system.
- Console access: Root or Bash access is disabled on the system. Users can log in to the system CLI from the console using an admin account.
Tenant appliance mode
- Root access to the tenant is disabled by all means. Bash access is disabled for users (with a terminal shell flag enabled) inside the tenant.
- Users can access the tenant only through the webUI or the CLI.
- Tenant console access: Users can log in to the CLI from the virtual console using an admin account (with a terminal shell flag enabled).
You can enable appliance mode if you want to disable all root and Bash shell access.
Note: For greater security, it is highly recommended that you configure the system controllers and chassis partitions to run in appliance mode.
From the system controller webUI, appliance mode disables root and Bash access to the controllers. From the chassis partition webUI, appliance mode limits access to the specific chassis partition to which you are connected. You can enable or disable the appliance mode for system controllers and partitions from their respective webUIs.
Note: The appliance mode option for tenants is available in the chassis partition webUI under TENANT MANAGEMENT > Tenant Deployments.
On the left, click SYSTEM SETTINGS > System Security.
For Appliance Mode, in the Appliance Mode area, for Enable/Disable, select either Enabled or Disabled.
The default value is Disabled.
Click Save.
You can configure appliance mode from either the system controller or chassis partition CLI if you want to disable all root and Bash shell access.
From the system controller CLI, appliance mode disables root and Bash access to the controllers. From the chassis partition CLI, appliance mode limits access to the specific chassis partition to which you are connected.
Note: The appliance mode option for tenants is available in the chassis partition CLI using the tenants tenant <*tenant-name*> config appliance-mode command sequence.
(config). -
Enable appliance mode.
system appliance-mode config [ disabled | enabled ]In this example, you enable appliance mode on the system controllers:
syscon-1-active(config)# system appliance-mode config enabled -
commit
A cluster on a VELOS system is group of blades or nodes working together as a logical unit. The Cluster Details screen on the chassis partition webUI provides detailed information about clusters that might be useful when a chassis partition is made up of more than one slot/blade.
You can view detailed information about clusters from the chassis partition webUI.
Log in to the VELOS chassis partition webUI using an account with admin access.
On the left, click SYSTEM SETTINGS > Cluster Details.
Set the Auto Refresh interval for refreshing the data displayed or click the refresh icon to update the data immediately.
View the cluster detail information.
You can view detailed information about clusters from the chassis partition CLI.
Log in to the command line interface (CLI) of the chassis partition using an account with admin access.
Show all cluster details.
show clusterA summary similar to this excerpt displays:
default-1# show cluster cluster state cluster disk-usage-threshold state warning-limit 85 cluster disk-usage-threshold state error-limit 90 cluster disk-usage-threshold state critical-limit 97 cluster disk-usage-threshold state growth-rate-limit 10 cluster disk-usage-threshold state interval 60 cluster nodes node blade-1 state enabled true state assigned true state node-running-state running state present single state platform-id B60100 state slots [ 1 ] state platform fpga-state FPGA_RDY state platform dma-agent-state DMA_AGENT_RDY state slot-number 1 state node-info creation-time 2023-01-06T02:11:09Z state node-info cpu 28 state node-info pods 250 state node-info memory 131576224Ki state ready-info ready true ...
You can configure general system settings for the VELOS system, such as system hostname, login banner, and message of the day (MOTD) banner. Depending on which setting you want to configure, you can use either the CLI or the webUI.
You can configure general system settings, including hostname, login banner, message of the day (MOTD) banner, and an advisory banner from the system controller webUI. When enabled and configured, the advisory banner will display at the top of the webUI after authentication. The product name displays but cannot be changed.
On the left, click SYSTEM SETTINGS > General.
For Hostname, enter a custom hostname for the system.
For Login Banner, enter any text to be displayed when users log in to the system.
For MOTD Banner, enter any text to be displayed as a MOTD when users log in to the system.
For Advisory Banner, select Enabled or Disabled.
For Advisory Banner Color, select the color for the banner.
For Advisory Banner Text, enter the text for the banner. The maximum number of characters is 80.
Click Save.
You can manually configure the hostname for your system from either the system controller or chassis partition CLI. The hostname must be a fully-qualified domain name (FQDN).
(config). -
Change the hostname.
system config hostname <*hostname*>The minimum length is 1 character, and the maximum length is 253 characters.
In this example, you change the hostname for the system to test.company.com:
syscon-1-active# system config hostname test.company.com
The system hostname is now updated.
You can configure the login banner for your system manually from either the system controller or chassis partition CLI. The login banner displays before users log in to each respective system.
(config). -
Change the login banner text.
system config login-bannerIn this example, you change the login banner text to notify users that unauthorized access is prohibited:
syscon-1-active(config)# system config login-banner (<string>): [Multiline mode, exit with ctrl-D.] UNAUTHORIZED ACCESS TO THIS DEVICE IS PROHIBITED -
commit
The login banner is now updated.
You can manually configure the message-of-the-day (MOTD) banner for your system from either the system controller or chassis partition CLI. The MOTD banner displays after users log in to each respective system.
(config). -
Change the MOTD banner text.
system config motd-bannerIn this example, you change the login banner text to notify users of upcoming system maintenance:
syscon-1-active(config)# system config motd-banner (<string>): [Multiline mode, exit with ctrl-D.] ATTENTION! This system is scheduled for maintenance in two days. -
commit
The MOTD banner is now updated.
If you are having an issue with a chassis partition (such as unusually high CPU or memory usage or lockup), it is possible that rebooting a blade in the chassis partition might help to resolve the issue.
When there is a problem, the system sends alerts that you would see on the dashboard or on the Alarms & Events screen. A blade status of Not ready for a prolonged time on the General screen can also indicate the need to reboot the blade. You should rarely have to reboot a blade, however, because typically if the VELOS system needs to reboot a blade, it will do so automatically without administrator intervention. F5 recommends working with customer support if you think a blade reboot is necessary.
You can manually reboot a system controller in your VELOS system from the system controller CLI.
Reboot a system controller.
system reboot controllers controller { active | standby ]In this example, you reboot the standby system controller:
syscon-1-active# system reboot controllers controller standby
The specified system controller reboots.
You can reboot a system controller from the system controller webUI.
Review the status of the system controllers.
The Reboot button will not be available for a system controller that is currently being rebooted.
If you decide that a reboot is necessary, click Reboot to the right of the system controller that you want to reboot.
If the system controller has the active role, a popup displays asking you to confirm the reboot operation. This causes a failover to the standby controller.
The It takes a few minutes for the system controller to reboot. The status will show
Reboot in progress, thenNot ready, and when reboot is complete, it saysReady.
You can manually reboot a blade in your system from the chassis partition CLI.
Connect using SSH to the chassis partition management IP address.
Reboot a blade.
cluster nodes node <*blade-number*> rebootIn this example, you reboot blade-1:
default-1#(config) cluster nodes node blade-1 reboot
The specified blade reboots.
You can reboot a blade within a chassis partition from the chassis partition webUI.
Review the status of each of the blades in the chassis partition.
The Reboot button will not be available for slots that do not have blades present, or for blades that are currently being rebooted.
If you have tenants running on the chassis partition you might want to warn users that their service might be interrupted temporarily.
If you decide that a reboot is necessary, click Reboot to the right of the slot containing the blade that you want to reboot.
It takes a few minutes for the blade to reboot. The status will show
